Old 12-13-2020, 09:46 PM #16
rageandlove rageandlove is offline
rageandlove is a name known to all rageandlove is a name known to all rageandlove is a name known to all rageandlove is a name known to all rageandlove is a name known to all rageandlove is a name known to all
Originally Posted by jp.vegas View Post
And give up my seat heaters? Noooooo
It's a Limited ... the seat warmers are up in the console.
rageandlove is offline   Reply With QuoteReply With Quote
Old 12-13-2020, 10:58 PM #17
Originally Posted by jrandom View Post
Thanks, I’m glad I stumbled upon it.
I have a fused subsystem that is directly connected to the battery, it is controlled via “keyed” relay (the relay is triggered by the key when turned to “on” the step before accessory) that is where I pull the voltage from, so it is as close to the batteries “true” voltage.
You could easily wire it direct and throw a toggle/push inline so that it is on demand.
I would be super cool it the meter was a push button switch itself.
Thanks @jrandom . That's a great idea. I might email the good folks in Australia and suggest they give you a dozen as a royalty :-).
I'm more interested in watching the voltage when the vehicle isn't on, specifically when I am out doing trips to make sure I don't run down the battery too far at night when I use it for lighting etc. So I think I'll go with your second suggestion about an in-line switch.
I've never managed to find a toggle that fits in the 4Runner blank that can work without a relay ... anyone else out there ever seen one? The more stock looking the better.
Else, I guess I'll just drill a hole in one of the blanks next to where I put in the voltmeter and use something like this, which will still be pretty discrete hopefully.
Old 12-15-2020, 11:39 AM #18
jrandom's Avatar
jrandom jrandom is offline
jrandom is a name known to all jrandom is a name known to all jrandom is a name known to all jrandom is a name known to all jrandom is a name known to all jrandom is a name known to all
jrandom's Avatar
I am pretty sure you could use one of the regular ~3amp 150 Toyota push buttons, the voltage meter isn’t going to draw much power to run. I’d be really surprised if it drew anywhere near 3 amps.
Just checked, from their website: Dual Battery Volt Meter for Toyota Prado 150, Landcruiser 200, 2016 Hilux - Solid Kit
Low current draw, only 14 mA per panel (0.336 Ah per day)
There you go
2013 TE w/ KDSS Nav
=-> Get yer Custom "Trail" Edition Emblem/Badge 3d Print here! or maybe you just want to go "Pro"
jrandom is offline   Reply With QuoteReply With Quote
Old 12-15-2020, 07:40 PM #19
There you go
Thank you! I'll give it a whirl and use a 2A fuse just in case. I'll try and remember to report back when I get around to it - have some other wiring to take care of first.
Old 01-13-2021, 11:52 PM #20
Nobody Special's Avatar
Nobody Special Nobody Special is offline
Real Name: Special Ed
Nobody Special is a jewel in the rough Nobody Special is a jewel in the rough Nobody Special is a jewel in the rough
LOL. Looks like... With the logo
N̷̢̗̪̗̞̯͈̥̐̉͌͜͝O̴̢̨͚̭͕̾B̶̪̩̙̰̩̟̪͓̠̫̉̏̀͗̀̾͒̏̐̽O̵̾̏̈ ̨̡̖̬̀͂̒͂͂̃D̷̯̪͙͍͖͙̰͒̈Y̸͎̗̝͍͌̑̆͂̈́͘̕
Nobody Special is offline   Reply With QuoteReply With Quote
Old 01-05-2022, 11:59 AM #21
<<<<'s Avatar
<<<< <<<< is offline
<<<< is just really nice <<<< is just really nice <<<< is just really nice <<<< is just really nice <<<< is just really nice
<<<<'s Avatar
<<<< is offline   Reply With QuoteReply With Quote
Old 01-10-2022, 03:17 PM #22
OK, for anyone else that shows up on this thread and wants to know how to use an AOB switch (what I used) to power an in-dash voltmeter (like this one), here's what I did:
Note, the switch is on the negative because the gauge requires each volt meter to be wired independently to the battery ... this way one switch can still control both. Hence the funky red (switch) to ground (voltmeter).
blanks , dash , found , plenty , switch
Volt meter/ usb plugs Johnnie General Discussions 0 08-28-2019 11:02 PM
Thoughts on this volt/amp meter Rocket61 4th Gen T4Rs 1 02-25-2016 04:31 PM
Rear seat power port and volt meter concordcarlos 3rd gen T4Rs 8 11-15-2015 12:38 AM
!2 Volt power some place in dash? nathannookie 4th Gen T4Rs 4 03-05-2004 09:30 PM
