Old 01-09-2022, 02:27 AM #1
jdm-v35 jdm-v35 is online now
jdm-v35 is a jewel in the rough jdm-v35 is a jewel in the rough jdm-v35 is a jewel in the rough jdm-v35 is a jewel in the rough
Where are people mounting their winch power cutoff solenoid/switch
I have a Warn bumper I am going to put on but the winch has not arrived yet. In trying to plan the install I was wondering where in the engine bay people are mounting the master power cutoff switch/solenoid?
It is a HF Badland Apex 12k which comes with that manual knob switch box to cut off the power feed. I also purchased a Warn power solenoid just in case I wanted to mount that and activate it with my Switchpro 9100. Either method is fine with me depending on the best mounting location.
At this point I would probably prefer the included manual knob as this would take up my last button on the switchpro. The manual knob also has no exposed terminals like the Warn Solenoid does.
I am curious where others have mounted their power cutoffs? Thanks in advance.
jdm-v35 is online now   Reply With QuoteReply With Quote
Old 01-09-2022, 06:37 AM #2
Old Tanker Old Tanker is offline
Old Tanker has a spectacular aura about Old Tanker has a spectacular aura about Old Tanker has a spectacular aura about
Most people wire their winches directly to the battery without a cutoff. Some will run a Blue Sea 6006 switch somewhere under the hood.
2019 TRD ORP. BFG KM3 285/70R17. Hefty front tube bumper, LFD dual swing-out rear bumper. Warn Zeon 10S. RSG sliders. Sherpa roofrack. Goose Gear interior. Radflo 2.5 suspension.
Old Tanker is offline   Reply With QuoteReply With Quote
Old 01-09-2022, 10:32 AM #3
Thanks. I figured without some type of power cutoff it would be a constant small drain on the battery. I didn't know that leaving it hot all the time was really an option. I probably would still want a cutoff on it for safety purposes but did not know that was even an option.
Old 01-09-2022, 11:05 AM #4
Jetboy's Avatar
Jetboy Jetboy is offline
Jetboy's Avatar
Here's how mine is setup. Solenoid set stays on the winch. Control wires remote to a sealed box with the on/off master switch, wired remote plug and wireless relay set.
2015 TEP Hidden Winch Build/Install
Old 01-09-2022, 12:21 PM #5
Thanks! So you have something like this located with the winch:
Warn Upright Switch Solenoid Terminal | 72631|Northridge4x4
with that master switch controlling it?
Old 01-09-2022, 12:30 PM #6
Mudhorn's Avatar
Mudhorn Mudhorn is offline
Mudhorn is a jewel in the rough Mudhorn is a jewel in the rough Mudhorn is a jewel in the rough
Mudhorn's Avatar
I’ve seen most power switches, like Blue Sea, next to or on top of the battery. I placed mine next to the window washer fluid reservoir. I’ll try to add pics.
Ford Explorer - Jeep Liberty Renegade - GMC Yukon Denali - Hummer H2 - Ford Raptor SVT - BMW M6 - Suzuki Jimny - Mazda Demio - Daihatsu Naked - Will Cypha - Toyota 4Runner TRD ORP - Toyota RAV4 Limited Hybrid
Mudhorn is offline   Reply With QuoteReply With Quote
Old 01-09-2022, 12:42 PM #7
Yea I think that would be optimal. I seem to be running low on space in the engine bay though with the additions I have. Shrockworks dual battery with dual odyssey 34's, bandi mount with ARB twin compressor and the smog pump relocated under it, switchpros 9100 on driver side SDHQ mount, and I have a magnuson coming as well.
The only open space left may be right on top of the fuse box on drivers side
Old 01-09-2022, 07:33 PM #8
mrblah's Avatar
mrblah mrblah is offline
mrblah's Avatar
you can also mount it near passenger side headlight in space between radiator and bumper skin. Take off the engine/radiator splash guard, and look down.
Look for shrockworks front bumper installation instructions if you really want step by step instructions on how to do it. Alot of aftermarket bumpers require the solenoid box to be relocated there.
You have to cut a hole in your splash guard to access it, or keep the splash guard off.
I have a SSO slimeline bumper and i was able to mount my shittybilt solenoid box offset on the drum to the passenger side, and I had to bend the power steering line out of the way.
Not sure if that is possible with your winch or not.
Old 01-09-2022, 11:47 PM #9
matoolie's Avatar
matoolie matoolie is offline
matoolie has a spectacular aura about matoolie has a spectacular aura about
matoolie's Avatar
Mounted Blue Sea E-series switch on simple custom bracket mounted on the side of my second box battery on passenger side using the same bolts that secure the top bracket on the battery box for securing the battery. The switch is secured to the bracket using two of the four supports. The other two supports just rest on top of the battery/battery box. Very secure and plenty of hood clearance.
Michael
2021 Pro Lunar Rock: RCI tranny/transfer case/tank skids, Victory roof rack
2014 LE Nautical Blue: 285/70R17 Falken A/T3W, FX Pro wheels, Fox TRD Pro suspension with Wescott lift, Dobinson UCA's, Metal Tech sliders
matoolie is offline   Reply With QuoteReply With Quote
Old 01-10-2022, 01:30 AM #10
Jetboy's Avatar
Jetboy's Avatar
You don't need another solenoid to disconnect power to the winch. The solenoid set that comes with the winch already does that. It's an open circuit until the remote signals the solenoid in the normal winch control box to close the circuit. In my under hood box is a smaller size Bosch style relay then a fuse block that has fuses for the wired remote and the wireless controller module. The relay in the box isn't necessary if the switch can handle the relatively low load of the winch control wires. But those common cheap toggle switches like that are pretty weak, so I added one just to make sure it wouldn't be an issue.
So when the toggle switch on top of the box is "off" everything in the box is disconnected and you can't operate the winch wired or wirelessly. When is "on" then both will work.
I have IIRC a 200 amp fuse on the battery terminal connecting the winch positive cable. So a short circuit is protected by a fuse.
You could certainly use a relay like the one you showed inline on the positive cable as well. But my general experience those relays aren't all that reliable. So they end up more trouble than it's worth. I'd use a mechanical disconnect instead if you're doing that. There are also 12v circuit breakers you could use as an easy disconnect that also protect the circuit.
Also - a switch or relay cutting the big power wire is still not a replacement for a fuse or circuit breaker inline on the main power wire to the which. You still need one. A short on that heavy gauge wire will get really bad really fast.
Old 01-10-2022, 08:14 AM #11
Thanks for the detailed info. I didn't think about it but one of those circuit breakers would be a good dual purpose fix for swtched power as well as safety while it is on. I use them in my dual battery setup but did not think they were needed on a winch, and not sure if that load rating is high enough. Can't winches pull up to 400A? I would just need to fab up a mount for the breaker.
I got the winch installed yesterday and just need to get the power connected.
Old 01-10-2022, 01:53 PM #12
mscot mscot is offline
mscot is a glorious beacon of light mscot is a glorious beacon of light mscot is a glorious beacon of light mscot is a glorious beacon of light mscot is a glorious beacon of light
I have a write up in my build thread you can check out.
Build thread
mscot is offline   Reply With QuoteReply With Quote
Old 01-10-2022, 02:47 PM #13
Jetboy's Avatar
Jetboy's Avatar
Your probably right on amps. For some reason I thought 10klb class winches draw less than they claim. I don't remember why I was thinking that. But maybe I'm totally wrong and my fuse set is higher than I remember. I know my warn 8274 will pull a lot more amps than my super winch 9500. It'll kill a battery fast!
I've never blown my fuses. Most winches come with a fuse set in the box, but not all do. Obviously they size the fuse to roughly match the winch draw. The main goal is to stop a fire if the wire short circuits. So the fuse needs to be low enough to burn through with a direct short and high enough not to blow during normal use. Your winch probably has a spec sheet available that'll tell you the minimum amperage you'll need.
Circuit breakers come in a lot of sizes. I think you'll find them up to 400 amps of you look. I know I have a 300 amp on my camper system.
The only down side there is that I'm not sure how many cycles they're good for. The switch on a circuit breaker isn't made for thousands of on/of toggles. But how often will you turn it on and off? I probably use my winch 20 times a year or less. So it'd be fine I think. But I just use a fuse on mine.
You can also use fuses or circuit breakers in parallel to increase capacity. So if you find 50 or 100 amp fuses readily available, you can combine 2 x100 amp fuses for a 200 amp circuit. That's actually how mine is because it's what was included in the box with the winch. But it's worked well for 6 years so far.
Edit: I went and looked at the manual. I was wrong. My winch came with a set of I think 4 x 100 amp auto-recloser circuit breakers that I have always assumed were just fuses. They're mounted in parallel on a set of buss bars into a single package. I never paid much attention to what was really there. Haha. They look like one time use fuses. I learned something new!
knob , manual , mounting , power , warn
Switch-Pro 9100 power module mounting location hb216 5th gen T4Rs 5 08-02-2019 11:17 PM
Switch Pros horizontal mounting of the power module jayhat 5th gen T4Rs 3 08-02-2019 11:06 PM
Group buy : CBI winch cutoff switch bracket Okki 5th gen T4Rs 15 11-15-2016 09:40 PM
Group buy : CBI winch cutoff switch bracket Okki Group Buys 7 09-21-2016 10:20 PM
