Old 03-02-2020, 12:01 PM #1
Mastr_chief's Avatar
Mastr_chief Mastr_chief is offline
Mastr_chief is on a distinguished road
2019 Offroad suspension compatible on 2016 4wd limited?
Hello all -
Any idea if the 2019 offroad OEM suspension work on a 2016 4wd limited? I know the limited has the XREAS, but not sure if it plays a factor or not.
Thanks guys
Mastr_chief is offline   Reply With QuoteReply With Quote
Old 03-02-2020, 01:03 PM #2
Grug556's Avatar
Grug556 Grug556 is offline
Grug556 is a jewel in the rough Grug556 is a jewel in the rough Grug556 is a jewel in the rough
Grug556's Avatar
Step 1...look at XREAS on truck..see how its shit
Step 2.... drink heavily..while preparing for what comes next
Step 3..take bolt cutters and cut those hardlines and rip that POS system right off the truck
Step 4...install KINGs or similar and enjoy.
Grug556 is offline   Reply With QuoteReply With Quote
Old 03-02-2020, 01:16 PM #3
dktxt4r's Avatar
dktxt4r dktxt4r is offline
dktxt4r will become famous soon enough dktxt4r will become famous soon enough
dktxt4r's Avatar
Originally Posted by Mastr_chief View Post
Hello all -
Thanks guys
If you want to change out the suspensions on the Limited, you're going to have to take out X-REAS. There is a way to keep the system intact when taking it off. There really isn't really a market for used X-REAS so I just had it gutted out and replaced. From my understanding, even a little loss of fluid from the system will make it useless. I also have a 2016 Limited.
dktxt4r is offline   Reply With QuoteReply With Quote
Old 03-02-2020, 01:33 PM #4
llDemonll llDemonll is offline
llDemonll is a glorious beacon of light llDemonll is a glorious beacon of light llDemonll is a glorious beacon of light llDemonll is a glorious beacon of light llDemonll is a glorious beacon of light
XREAS is better than a standard shock if you don't have KDSS to go with it.
Only reason for replacing XREAS is if you're getting a nicer aftermarket suspension, not an OEM take-off from an Off-Road model.
llDemonll is offline   Reply With QuoteReply With Quote
Old 03-02-2020, 01:38 PM #5
tm965 tm965 is offline
tm965 is a jewel in the rough tm965 is a jewel in the rough tm965 is a jewel in the rough
very much this. do not bother putting a stock OR suspension on a limited. so many better options out there ranging from inexpensive to mucho dinero
tm965 is offline   Reply With QuoteReply With Quote
Old 03-02-2020, 04:33 PM #6
Thanks for the info guys. I'm actually just trying to sell my somewhat used shocks on NextDoor. I've already upgraded my shocks and coils.
The guy that's interested is wondering if it'll fit on his '16 Limited. I'm basically just doing his homework...
Old 03-02-2020, 05:24 PM #7
To start, don't guarantee anything. Just say you're not sure. Otherwise he's going to come back later and ***** and moan at you when he finds out he has to remove all his suspension and cut it up in the process.
Just say something along the lines of "I'm not certain if they will just bolt right up but I know aftermarket kits use the same parts for the Off-Road and the Limited models"
Old 03-02-2020, 06:01 PM #8
Bumbo's Avatar
Bumbo Bumbo is offline
Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of
Bumbo's Avatar
It should be compatible, but the standard shock to replace the XREAS would be a downgrade. It would be silly to try and pawn them off to your neighbor unless he was trying to fix a problem.
The only time I would pull off XREAS would be because its leaking or to upgrade/lift.
Old 03-02-2020, 09:13 PM #9
niadh0 niadh0 is offline
niadh0 will become famous soon enough niadh0 will become famous soon enough
it will fit as long as you take out x-res. i also recommend change the matching rear coils. saying this because i put TRDFox set on my wife's 2010 Limited when one of her rear x-res needed to be replaced.
BUT like the others said, why should someone get rid of 2016 x-res and go with basic stock suspension... unless of course the buyer has x-res gone bad and doesn't want to spend the money to replace with equivalent or better after market. if so, the buyer might gain a bit of eight as i believe that the OffRoad shocks are a bit taller than the x-res
niadh0 is offline   Reply With QuoteReply With Quote
Old 03-03-2020, 12:14 PM #10
Yeah, he said his shocks were shot. I let him know upfront what you guys basically told me here.
Thanks again.
4wd , factor , limited , offroad , suspension
3rd Gen Tacoma Suspension Swap (2016-2019) runokc 4th Gen T4Rs 8 09-04-2020 01:20 AM
SOLD: VA 2016 Limited, mostly blacked out, OME suspension and 33" street tires sprygsxr For Sale: Vehicles 5 11-16-2019 02:27 PM
FS: 2019 TRD offroad wheels - MN - $500 MyToy4R For Sale: Suspension/Wheels/Tires 1 04-13-2019 12:57 PM
2018 4Runner TRD Offroad Suspension on 05 Limited? Matts05runner 4th Gen T4Rs 1 05-16-2018 08:22 AM
