Old 03-03-2020, 08:47 AM #1
mr.walleye mr.walleye is offline
mr.walleye will become famous soon enough
Negative 4 deg caster
I put a 3" toytec/Bilstein lift in and JBA UCAs, I've read on here in several threads that I need to get -4 deg caster. I took it to the dealership yesterday and told them that, they said they could do it but it'd cost more because it'd take more time because of all they needed to move around and they see no benifits in doing that. I told them to forget it and just aline it to factory specs. That's what they did and it drives perfect. I talked to the tech and he said the -4 caster is mostly for sport/race cars and is over kill for a 4 wheel drive. So, did I screw up going factory specs that were recommended by a certified tech or Should I have listened to the internet and insisted on -4?
mr.walleye is offline   Reply With QuoteReply With Quote
Old 03-03-2020, 08:52 AM #2
SlickTRD SlickTRD is offline
SlickTRD has a spectacular aura about SlickTRD has a spectacular aura about SlickTRD has a spectacular aura about
you need + caster not -
it should be +3 to +4 or so.
Cement, RCI Skids & Sliders, Nitto Ridge Grappler, Northstar AGM, Goose Gear Plate, Dometic CFX 65W, Dometic Fridge Slide, BPF Molle Panel, Pedal Commander, Compustar, BlackVue, Diode Dynamics SS3
SlickTRD is offline   Reply With QuoteReply With Quote
Old 03-03-2020, 09:04 AM #3
duggy duggy is offline
duggy is on a distinguished road
Take it to an offroad shop that has an alignment machine. You should be shooting for +3.5 or more of caster to clear the body mount. The benefit of added caster is that your vehicle will track straighter down the freeway.
duggy is offline   Reply With QuoteReply With Quote
Old 03-03-2020, 09:26 AM #4
if youre happy with how it drives leave it alone.
Old 03-03-2020, 01:33 PM #5
hwnrunner's Avatar
hwnrunner hwnrunner is offline
hwnrunner will become famous soon enough hwnrunner will become famous soon enough
hwnrunner's Avatar
post a pic of your alignment specs for review. Should be all green.
2019 SR5 Premium 2WD - TRD PRO Front Struts & Coils w/ Toytec 1" Perch Spacer / Dobinson's C59-505 Rear Springs / ICON VS 2.0 Rear Shocks / TRD PRO Grill & Valences/ TRD CAI /URD MAF Calibrator / TRD PRO Wheels / BFG KO2 275 70 17
hwnrunner is offline   Reply With QuoteReply With Quote
Old 03-03-2020, 05:58 PM #6
I made a mistake. It's 4 degrees POSITIVE caster I've read. The guy in the service dept taking my info said negative 4 degrees caster and I went with it. Looks like they did a good job.
Negative 4 deg caster-img_8082-jpg
Old 03-03-2020, 07:01 PM #7
daytonaviolet's Avatar
daytonaviolet daytonaviolet is offline
daytonaviolet is a splendid one to behold daytonaviolet is a splendid one to behold daytonaviolet is a splendid one to behold daytonaviolet is a splendid one to behold daytonaviolet is a splendid one to behold daytonaviolet is a splendid one to behold
typical casters setting ranges from 2.5 --> 4.0. it's all in the positive degree range. your 3.3 and 3.5. you have more you can go but if your not rubbing, your good.
daytonaviolet is offline   Reply With QuoteReply With Quote
Old 03-03-2020, 08:36 PM #8
catrains catrains is offline
catrains will become famous soon enough catrains will become famous soon enough
I like the work they did ... toe .17 perfect... caster 3.5 good...
catrains is offline   Reply With QuoteReply With Quote
caster , factory , specs , tech , told
Negative caster! seriouscoin1 5th gen T4Rs 3 04-16-2017 10:41 PM
I see so many negative posts about HID's and KO2's... adaml 5th gen T4Rs 19 12-23-2016 12:42 PM
metled negative negative terminal conecter secondary-system Classic T4Rs 4 10-19-2014 04:53 PM
metled negative negative terminal conecter secondary-system Classic T4Rs 0 10-18-2014 07:26 PM
Negative caster bad? Runner27 4th Gen T4Rs 2 08-27-2012 05:57 PM
