Old 03-04-2020, 08:11 PM #1
rob_dixon's Avatar
rob_dixon rob_dixon is offline
rob_dixon will become famous soon enough
rob_dixon's Avatar
Need a good 12 volt to AC inverter to run a laptop up front
4runners have 4 12 volt plugs right in front, and the only AC adapter in the back. Lame!
What do you guys recommend I use to power my lappy up front?
rob_dixon is offline   Reply With QuoteReply With Quote
Old 03-04-2020, 08:18 PM #2
steelevo steelevo is offline
steelevo is on a distinguished road
I just use an extension cord on mine. No issues since 2016.
steelevo is offline   Reply With QuoteReply With Quote
Old 03-04-2020, 09:19 PM #3
rob_dixon's Avatar
rob_dixon's Avatar
Hah, you know, sometimes the simplest solution is the best.
Old 03-04-2020, 09:23 PM #4
Bumbo's Avatar
Bumbo Bumbo is offline
Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of
Bumbo's Avatar
Extension sounds ideal, but if you did want to buy another inverter I highly recommended Victron. They make a really high quality smaller pure sine units too, I use them in my portable projects, like a DIY Goal Zero or Yeti kinda setup.
Phoenix Inverter VE.Direct - Victron Energy
Old 03-04-2020, 09:59 PM #5
1000MPH's Avatar
1000MPH 1000MPH is offline
1000MPH is a name known to all 1000MPH is a name known to all 1000MPH is a name known to all 1000MPH is a name known to all 1000MPH is a name known to all 1000MPH is a name known to all
1000MPH's Avatar
Wait, the newer trucks don’t have this?
That sucks.
1000MPH is offline   Reply With QuoteReply With Quote
Old 03-05-2020, 01:17 AM #6
llDemonll llDemonll is offline
llDemonll is a glorious beacon of light llDemonll is a glorious beacon of light llDemonll is a glorious beacon of light llDemonll is a glorious beacon of light llDemonll is a glorious beacon of light
Whats wrong with the plug in the glovebox?
llDemonll is offline   Reply With QuoteReply With Quote
Old 03-06-2020, 01:28 AM #7
rob_dixon's Avatar
rob_dixon's Avatar
TRD Pro has no such thing unfortunately. If you have one on a 5th gen, it must be another model!
Old 03-06-2020, 03:07 AM #8
Mass 4runner's Avatar
Mass 4runner Mass 4runner is offline
Mass 4runner will become famous soon enough
That sucks.
Correct. My '10 had that but my '19 only has it in the trunk.
2023 4runner TRD Off Road
2013 Camaro SS
Mass 4runner is offline   Reply With QuoteReply With Quote
Old 03-06-2020, 05:29 AM #9
Sky Sky is offline
Sky will become famous soon enough Sky will become famous soon enough
Sky Sky is offline
My 19 TRD ORP does not have one in the glove box either...
2019 4Runner TRD Off Road Premium
2011 FJ Cruiser TRD
1974 FJ40 (wish I still had it)
Sky is offline   Reply With QuoteReply With Quote
Old 03-06-2020, 08:17 AM #10
SlickTRD SlickTRD is offline
SlickTRD has a spectacular aura about SlickTRD has a spectacular aura about SlickTRD has a spectacular aura about
any off the shelf brand with 150W or so from amazon should be fine. the rear inverter is not always on so that could be annoying to remember to hit the switch every time.
Cement, RCI Skids & Sliders, Nitto Ridge Grappler, Northstar AGM, Goose Gear Plate, Dometic CFX 65W, Dometic Fridge Slide, BPF Molle Panel, Pedal Commander, Compustar, BlackVue, Diode Dynamics SS3
SlickTRD is offline   Reply With QuoteReply With Quote
Old 03-06-2020, 08:39 AM #11
Crashnrondo Crashnrondo is offline
Crashnrondo is on a distinguished road
If it were me I'd get a 12 volt outlet charger that matches your computer. Otherwise your taking 12 volts from the 4runner converting it to 110 volts AC, then converting it back to 18-21 volts DC to charge the laptop.
2010 SR5 4x4--5100's @ 1.75" + 1.5" Daystar rears
Crashnrondo is offline   Reply With QuoteReply With Quote
Old 03-06-2020, 12:09 PM #12
Bumbo's Avatar
Bumbo's Avatar
Really good suggestion... a DC-DC boost converter would be small and efficient.
Easy DIY too if you dont mind a little cut and crimp action.
Old 03-06-2020, 04:40 PM #13
jhguth jhguth is offline
jhguth is a splendid one to behold jhguth is a splendid one to behold jhguth is a splendid one to behold jhguth is a splendid one to behold jhguth is a splendid one to behold jhguth is a splendid one to behold
Laptop DC power supplies for vehicles are cheap and easy to buy
jhguth is offline   Reply With QuoteReply With Quote
Old 03-06-2020, 04:54 PM #14
A10MileHusker's Avatar
A10MileHusker A10MileHusker is offline
Real Name: Doug
A10MileHusker is a jewel in the rough A10MileHusker is a jewel in the rough A10MileHusker is a jewel in the rough A10MileHusker is a jewel in the rough
Real Name: Doug
That sucks.
My 2017 TRDORP has that.
A10MileHusker is offline   Reply With QuoteReply With Quote
Old 03-06-2020, 05:58 PM #15
I thought the 5.5 gen juat had a 120W 12V
back , front , power , recommend , volt
Got a new laptop, what GPS ? 04rnr Off-Roading 7 11-19-2018 04:02 PM
Which Laptop? TRDteen Off Topic 19 08-27-2013 05:29 PM
What should my next laptop be? 20034RunnerV84x2 Off Topic 18 06-13-2013 09:58 PM
New Laptop!! 20034RunnerV84x2 Off Topic 0 03-10-2013 05:17 AM
Looking for a new laptop... ChaosStarter Off Topic 19 11-15-2012 02:06 PM
