Old 03-05-2020, 01:38 PM #1
benhalleniii benhalleniii is offline
benhalleniii is on a distinguished road
Connecting dual battery system to shore power question
Hey there guys. So I'm designing a dual battery system using the Redarc BCDC1225D. My plan is to have a portable solar panel that I can use for longer trips to charge the batteries in addition to the alternator. I'm clear about how to set up this part of the system.
What I don't know is, how and where do I integrate a connection for shore power into this setup? If I'm at a campsite with power I'd like to be able to use that for charging and powering accessories when possible.
Any suggestions? My setup will look something like this:
Any suggestions from the electrically inclined would be greatly appreciated.
Ben
2017 TRD Off Road
benhalleniii is offline   Reply With QuoteReply With Quote
Old 03-05-2020, 01:55 PM #2
Bumbo's Avatar
Bumbo Bumbo is offline
Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of
Bumbo's Avatar
Use a completely separate AC to DC charger / battery tender and connect it directly to the battery as you would regularly. Noco makes a multi-channel unit as well so charge both starter and dual independent of each other.
It bypasses the Redarc setup because it has nothing to do with it.
NOCO - On-Board Battery Chargers
Old 03-05-2020, 05:44 PM #3
A ha. I see. The noco boxes are just like my Ctek one. That makes sense.
This is pretty handy looking too: NOCO - AC Port Plug - GCP1
2017 TRD Off Road
Old 03-05-2020, 10:33 PM #4
jhguth jhguth is offline
jhguth is a splendid one to behold jhguth is a splendid one to behold jhguth is a splendid one to behold jhguth is a splendid one to behold jhguth is a splendid one to behold jhguth is a splendid one to behold
If you havent already bought the charge controller, some charge controllers have 120V input
jhguth is offline   Reply With QuoteReply With Quote
Old 03-05-2020, 10:44 PM #5
Bumbo's Avatar
Bumbo's Avatar
Do you have a example?
Most of those applications that use a "charger/inverter" like used in RVs and motor homes were usually much larger in size.
Old 03-05-2020, 10:45 PM #6
Response from Redarc for anyone who's interested...
"If you only want to charge the auxiliary battery just wire it directly to the auxiliary battery terminals. If you want to charge BOTH batteries from mains power, hook the AC charger to the starting battery terminals. Once the starting battery reaches over 13.2v, the BCDC will turn on and send power to the auxiliary battery also. "
b
2017 TRD Off Road
Old 03-05-2020, 10:54 PM #7
Bumbo's Avatar
Bumbo's Avatar
Originally Posted by benhalleniii View Post
b
Their answer is essentially what I said… It’s still an AC to DC battery charger.
Yes, that will work. That said there are some conditions where that might not work as well as you might want it to which is why I recommended a dual channel charger. You could of course just use a single as well.
If you are charging from AC at a rate which is lower than the rate of the Redarc to the 2nd battery, you will eventually deplete the starter and hit the low disconnect voltage. Ultimately you are going to be cycling in and out of charge. If you have load on the 2nd battery, like a fridge, it wont be supported by the AC charger until the starter is satisfied. If you have a load on the starter, light factory loads, it may never be satisfied depending on your AC charger.
The solution is easy… just buy a big enough single battery charger which can support the Redarc charge current to prevent cycling. Or buy a dual channel charger.
Old 03-06-2020, 04:02 PM #8
Thanks for this thorough answer!
2017 TRD Off Road
dual , power , setup , suggestions , system
Dual Battery System Question (ML-ACR) MadKap 4th Gen T4Rs 3 12-02-2019 07:22 PM
Dual Battery System not working boodabill 5th gen T4Rs 76 09-20-2017 05:33 PM
How smart does a Dual Battery System need to be snowboardwcu General Discussions 17 06-08-2016 11:35 AM
Connecting Dual Battery Procedure JSparky 5th gen T4Rs 0 07-18-2015 05:46 PM
