Old 12-04-2022, 08:45 PM #16
<<<<'s Avatar
<<<< <<<< is offline
<<<< is just really nice <<<< is just really nice <<<< is just really nice <<<< is just really nice <<<< is just really nice
<<<<'s Avatar
Once it fails it stays closed. Reseting won't make it go away permanently. If it cleared now - it'll be back.
<<<< is offline   Reply With QuoteReply With Quote
Old 12-05-2022, 01:30 PM #17
tylertenny's Avatar
tylertenny tylertenny is offline
tylertenny will become famous soon enough
tylertenny's Avatar
I think I'll probably just order a new valve and replace it. I'm guessing that will resolve my problems and, if it doesn't, then I likely have bigger problems.
2016 SR5 Premium Pro Comp Series 32 Bandido wheels (17x9) * 265/70R17 KO2 C load * Eibach Stage 1 lift * JBA UCA * Energy bumps (F), Durobumps (R) * LFD 3/4 roof rack * BajaRack ladder * CTH TRD skid plate * CTH TRD Pro grille * TRD Pro front lower valance * Diode Dynamics SS3 Sport fog lights * R4T smoked sequential turn signals and CTH sequential side mirrors * black out emblems * Kicker Hideaway powered subwoofer
tylertenny is offline   Reply With QuoteReply With Quote
Old 12-05-2022, 04:25 PM #18
<<<<'s Avatar
<<<<'s Avatar
That's all it is, Tyler. If you OBD2 code "valve stuck closed" then replacing it is the fix. Make sure to replace one on the correct bank. Scanner fault code tells you Bank1 or Bank2. I've done mine eons ago as you see from original post and have no issues since. G.L.
Old 12-06-2022, 12:00 PM #19
tylertenny's Avatar
tylertenny's Avatar
My scanner showed that bank 2 was stuck closed. I found the OEM valve on eBay for $180 shipped so I think I'll pull the trigger. I did already order 2 air tube gaskets but I'm waiting for shipping confirmation. I appreciate the input and hope that the replacement install goes smooth!
Old 12-06-2022, 12:13 PM #20
CutthroatSlam CutthroatSlam is offline
CutthroatSlam is a splendid one to behold CutthroatSlam is a splendid one to behold CutthroatSlam is a splendid one to behold CutthroatSlam is a splendid one to behold CutthroatSlam is a splendid one to behold CutthroatSlam is a splendid one to behold CutthroatSlam is a splendid one to behold CutthroatSlam is a splendid one to behold
I did the same, split the case in half to inspect. That’s when I found the valve plate broken at its mounting screws. They do not sell the internal parts separately, just the entire valve.
I first ordered a used valve from a salvager off eBay. Then went and bought a new one from a Toyota dealer for $300+, which is the one I installed (driver’s side). I’d be will to sell the used driver’s side valve for $100.
CutthroatSlam is offline   Reply With QuoteReply With Quote
Old 12-06-2022, 12:40 PM #21
tylertenny's Avatar
tylertenny's Avatar
I'll likely just order the new one just to have a little more peace of mind. I do appreciate the offer, though!
air , injection , pump , secondary , valve
P2441, Secondary Air Injection System Switch Valve Stuck Closed (Bank 1) 71gs3504sp 5th gen T4Rs 8 09-28-2020 10:55 PM
secondary air injection help Txjcb5002 4th Gen T4Rs 10 08-27-2020 12:21 PM
P2443 Code/Secondary Air Injection GreenMountainOwl 5th gen T4Rs 3 12-24-2019 01:03 PM
Bad Secondary Air Injection on V8?? Soneill 4th Gen T4Rs 3 04-14-2017 01:41 PM
Code P2432, Secondary Air Injection b.miller123 Problems & Warranty Issues 4 12-11-2014 02:43 PM
