Old 08-02-2020, 12:33 PM #16
Joe-Runner's Avatar
Joe-Runner Joe-Runner is offline
Real Name: Joe-Runner
Joe-Runner has a spectacular aura about Joe-Runner has a spectacular aura about Joe-Runner has a spectacular aura about
Joe-Runner's Avatar
Originally Posted by bring_it_on View Post
Thanks. Had a few minutes and ripped it out.
Glad it worked out for you! I've done it with two 4Runners now and never had any rattle at all. They clicked right back in no problem. Enjoy the extra storage! 👍
2021 ORP, Naut Blue, sunroof, Gunmetal TRD wheels w/265 Falkens, NFAB steps, 1.75" 5100s front, 1" Cornfed spacer rear / 2̶0̶1̶3̶ T̶r̶a̶i̶l̶, K̶D̶S̶S̶, / 2̶0̶1̶7̶ O̶R̶P̶
https://badges.fuelly.com/images/sig-us/1038471.png
Joe-Runner is offline   Reply With QuoteReply With Quote
Old 08-10-2020, 03:55 PM #17
Das Capitolin Das Capitolin is offline
Das Capitolin is on a distinguished road
These trays are an abomination to the 4Runner series, and just one more thing I really dislike about my new 5th gen. What was so bad about the container lids used on the 3rd and 4th gen 4Runners? It would be great if somebody designed an aftermarket container that could be set into the space when the tray is removed.
Das Capitolin is offline   Reply With QuoteReply With Quote
Old 08-10-2020, 07:42 PM #18
bring_it_on's Avatar
bring_it_on bring_it_on is offline
bring_it_on will become famous soon enough bring_it_on will become famous soon enough
This! My next DIY is going to be to figure out a permanent mount for a battery box (either custom or a goal zero like system) there that is secure and can tap into the cables that run underneath it. My ultimate setup would be if I could find a way to permanently mount a 50Ah lithium battery there.
Any idea whether the area is safe to mount electronics inside the cavity? I've seen pictures that look like the area accumulates a lot of dust so was wondering if it is ok to mount an MPPT in there...
2019 TRD Off Road| 285x70xR17 Falken WP AT3W| Dobinson C59-314/GS59-700 & C59-505/GS59-701| Total Chaos UCA| RCI front skid plate (steel)| C4 Fab. Low Pro. Bumper| Extreme LED Light Bar (bumper)| Baja Designs Squadron Sport Fog Lights (Amber)| Bud Built Ultimate Rock Sliders| Front Runner slimline II full-size Roof Rack with Wind Fairing| C4 Fab Summit Hatch Ladder| ARB CKMA12 Air Compressor| Xenon Depot HID Low Beam Head Lights|Renogy-20 Amp DC-DC Charger|Battle Born LiFePO4 Auxiliary Battery| Goose Gear rear drawer system (8")|National Luna 52L Legacy Fridge/Freezer| Alu-Cab tilting fridge slide (Small/Medium)| ROAM Adventure 8' Awning
bring_it_on is offline   Reply With QuoteReply With Quote
Old 08-11-2020, 10:47 AM #19
grizzlypath's Avatar
grizzlypath grizzlypath is offline
grizzlypath will become famous soon enough
I'd be most curious about the effects of heat on a semi-permanently installed Li battery in there.
grizzlypath is offline   Reply With QuoteReply With Quote
Old 08-11-2020, 11:14 AM #20
My intention was/is to remove the tray and fab a flat, up-sized mount so that the battery sits on top not inside the storage cubby (basically a bolted on battery box that can accommodate a 50 Ah Battleborn), though I am considering mounting an MPPT in that storage space.
Old 04-08-2023, 05:21 PM #21
Angus McSpreading Angus McSpreading is offline
Angus McSpreading is on a distinguished road
I did manage to remove both rear wheel well trays on my 2016 5th gen without breaking the clips.
It is tight to say the least getting a (big) hand in there but with patience it can be done. Further, the temp today was 80F+ so I suspect that helps with pliability. I'm sure my attempt would have resulted in breaking the screw tabs if this was being done in the cold.
Viewing the attached pic (below): The 4 problem children (aka the screws) are near center on the white rag. The tools used to remove the 4 problem children are on the white rag as well. The tools not on the white rag, well we all know what happened during the removal of the passenger (inverter) side tray, best to not give it attention.
Last edited by Angus McSpreading; 04-09-2023 at 09:36 AM. Reason: pic didn't embed correctly
Angus McSpreading is offline   Reply With QuoteReply With Quote
Old 04-10-2023, 11:11 PM #22
Sarge61 Sarge61 is offline
Sarge61 is on a distinguished road
Nice 4R! I just bought a 2019 SR5 4 x 4 in Nautical Blue. Only 43K on the odometer and I put 1500 of those miles on myself. Very nice truck.
Sarge61 is offline   Reply With QuoteReply With Quote
Old 04-11-2023, 03:12 PM #23
So I decided to carry the removable trays one step further.
First, I had some leftover indoor/outdoor carpet from my 4runner sleeping platform project (I'll be posting about that soon). So I cut out pieces to pad the tray bottoms. Seem to fit nicely.
I deferred gluing them down in case during my project journey I find the need to do any drilling on the tray bottom (eg. for hangers or clips on the underside to hold things in the wheel well).
Next I added clips in an attempt to provide the ability to pull/remove the trays.
I'll be honest, for this first attempt, the key split rings seem kinda flimsy when pulling on them. Perhaps there is something more robust???
In any event, the split key rings are ~5/8" I.D., two holes (#32 0.116" bit) per ring spaced ~1/2inch apart.
https://i.postimg.cc/wML1DYGw/Rear-W...-Rings2-25.jpg
remove , side , top , trays , wheel
WTB: Stock 4th gen interior pcs. Grab handles an rear quarter trays. 99Runnr Want to Buy/Trade 1 02-23-2019 04:30 PM
Power Trays daveherrmann 5th gen T4Rs 1 12-21-2017 03:10 PM
Cargo Trays discontinued? BigCountryT4R 5th gen T4Rs 6 06-21-2017 11:15 AM
Yakima Railgrab and Bike Trays Installed on 2016 Trail Pseudo-Fed 5th gen T4Rs 3 07-23-2016 03:17 PM
how to remove center cap on wheel? SLBiv 4th Gen T4Rs 8 07-06-2013 10:14 AM
