Old 06-06-2020, 11:55 AM #1
ahtoxa11 ahtoxa11 is offline
ahtoxa11 has a spectacular aura about ahtoxa11 has a spectacular aura about ahtoxa11 has a spectacular aura about
Rear spring lift height - need your help, please
Hey gang,
I installed the full King 2.5 set up recently with Toytech Superflex 2.0 rear springs.
Here are my post-lift measurements from hub center to bottom of wheel arch:
front - 22.5"
rear - 25"
The issue is that the rear is too high. This is an overall 2.5" of rake at the fenders, where the factory rake is around 2".
I'm not sure why the Superflex 2.0 gave me three inches of lift in the back. The fronts are exactly right - they are 2.5" over stock and I don't want to go higher as I want to retain the down travel.
Need your help with advice on which rear spring should I swap shall this spring not settle much? I've read here that Icons 2.0 also give about 2.5, which would work for me.
Ultimately, I want a rear spring that's a true 2 - 2.5" rather than the 3 actual I got. I usually drive empty, no rear bumper but occasionally do load up with bikes, camping gear and dogs.
ahtoxa11 is offline   Reply With QuoteReply With Quote
Old 06-06-2020, 01:13 PM #2
cmilviper's Avatar
cmilviper cmilviper is offline
cmilviper is just really nice cmilviper is just really nice cmilviper is just really nice cmilviper is just really nice
cmilviper's Avatar
Originally Posted by ahtoxa11 View Post
Hey gang,
front - 22.5"
rear - 25"
In the past, I've had the Superflex 2.0 & the 2'' rear Icon coil springs on the same vehicle/same weight, and both yielded near identical height.
As long as you didn't install the Superflex 2.0 HD springs, then I would just give it some time to settle. I wouldn't be surprised if they eventually settled around an inch, down to around 24''.
2017 4Runner TRD Pro - Cement Icon RR CDCV (700 lb) w/ Icon Delta Joint UCA's/Billet Rear Link Arms || Icon Overland 3'' Rear Springs+Dobinson's 15mm spacers on top || C4 Fab Sliders || CBI Front Bumper || Shrockworks Rear Bumper || Gobi Stealth Rack/Ladder || Baja Designs & Rigid Lighting || 285/75r17 Toyo MT's (34") || Safari Snorkel || ARB Diff. Breather Kit || Spidertrax || ARB Awning 2000 || Maxtrax || XD Philips 4300K HID's || Warn Winch/Factor 55 || IKamper Skycamp 2.0 4X || SCS Ray10's || Durobumps
2015 4Runner TRD Pro - Super White (Wife's) Icon Stage 2 w/ Icon UCA's || Toytec Superflex HD Rear Springs || Expedition One Sliders || 285/70r17 BFG KO2's || Gobi Stealth Rack/Ladder || 40" Rigid Radiance || Spidertrax || XD Philips 4300K HID's || Philips Yellow LED Fogs
cmilviper is offline   Reply With QuoteReply With Quote
Old 06-06-2020, 04:56 PM #3
STLDAVE's Avatar
STLDAVE STLDAVE is offline
STLDAVE is on a distinguished road
STLDAVE's Avatar
Hey gang,
front - 22.5"
rear - 25"
If you can find them, I put the SAW 1.5 rear coils on about 150,000 miles ago and they gave me 2.0 inches of lift at install, and never settled at all.
2011 Salsa Red TE, KDSS, Running boards (not sure what to replace these with), Weathertec mats, Canvasback cargo liner, BudBuilt skid plates, full set of Billy 5100s, Light Racing UCAs, Toytec Ultimate front coilovers (with the "correct" 5th gen 5100s), SAW 1.5 rear coils, ScanguageII...
STLDAVE is offline   Reply With QuoteReply With Quote
lift , rake , rear , spring , superflex
Post your lift height... OME 2895/2895e rear spring users Off2Mtns 5th gen T4Rs 5 01-25-2018 07:52 PM
How much sprung height do the rear spring cones add? eurasiaoverland 3rd gen T4Rs 4 10-31-2016 02:22 AM
rear ride height after lift Aquatic Escape Classic T4Rs 2 04-17-2012 02:35 AM
Tundra TRD Spring/Shock Swap Actual Lift Height? OldSkoolArcher 3rd gen T4Rs 6 03-29-2011 08:51 PM
mixing daystar front lift with rear lift spring??? hdoggie24 3rd gen T4Rs 2 04-27-2010 01:52 PM
