Old 03-08-2020, 06:34 PM #1
psa5555 psa5555 is offline
Real Name: Scott
psa5555 is on a distinguished road
Real Name: Scott
Oil Leak?
Hey All,
I just changed the oil in my 2018 T4R about 2000km ago. It was last done at the dealership when I bought it a few months used. I used 0W20 Mobil 1, and factory filters. No issues during the change. I did my previous 2013 T4R for years with no issue.
Just returned from a lengthy week long trip, to find a couple drips of oil on my garage floor. Oil level looks good, but the front of the engine is a mess. I took the plastic cowl off and skid plate tonight to have a look. I appears to be coming from mid engine, passenger side, but there is so much oil everywhere it is hard to tell. Attached are two pictures, one from underneath and one from above. I also have a third one, with a drip coming off, adjacent to the what I believe the power steering pump.
Coolant levels and Power Steering fluids look good. Doesn't appear to be coming from the Filter housing. Vehicle is approx. 18 months old, with 47 000 km. Should be covered from warranty. Just trying to get an idea at what I am looking at here. Any light you can shed, would be great. Thanks!
Above: Google Photos
From Below: Google Photos
Drips, from below: Google Photos
psa5555 is offline   Reply With QuoteReply With Quote
Old 03-08-2020, 07:12 PM #2
Mack1611 Mack1611 is offline
Mack1611 is on a distinguished road
I had a similar leak on my 2016, mine was the front crank seal.
Mack1611 is offline   Reply With QuoteReply With Quote
Old 03-09-2020, 12:12 AM #3
Real Name: Scott
Real Name: Scott
What is the chance that this is a result of me moving from factory toyota oil, to Mobil 1 0w20?
Old 03-09-2020, 09:00 AM #4
Dynamo's Avatar
Dynamo Dynamo is offline
Dynamo has a spectacular aura about Dynamo has a spectacular aura about Dynamo has a spectacular aura about
Dynamo's Avatar
IMO, zero chance. Something is obviously leaking but I think it was merely a coincidence that it happened right after your last oil change.
2019 TRD ORP
Dynamo is offline   Reply With QuoteReply With Quote
Old 03-09-2020, 11:15 AM #5
delloro's Avatar
delloro delloro is offline
delloro is just really nice delloro is just really nice delloro is just really nice delloro is just really nice
delloro's Avatar
The factory oil is made for toyota by exxon/mobil. I cannot imagine the refinery would have such incompatible product lines that leaks could result.
delloro is offline   Reply With QuoteReply With Quote
Old 03-10-2020, 05:44 PM #6
Real Name: Scott
Real Name: Scott
I called Monday and had an appt. for today. Most of the oil was in the vicinity of the power steering pump. They removed the pump to find a bolt behind there covered in oil. They removed and replaced lower oil line gasket.
The technician did a nice job of cleaning up the oil in the engine bay. Was told to watch for the next week or two to confirm there is no new oil appearing and to contact them right away if so. First time I've had either of my T4Rs into the dealership for work. Happy with the services they provided today.
Hope that's a wrap!
Old 03-10-2020, 06:19 PM #7
djeepin djeepin is offline
djeepin is on a distinguished road
Hope that's a wrap!
what exactly was leaking from where and why?
djeepin is offline   Reply With QuoteReply With Quote
Old 03-10-2020, 07:12 PM #8
Real Name: Scott
Real Name: Scott
Appeared to be coming from lower oil line fitting, located behind the power steering pump. They removed and replaced the gasket. They figured bad gasket or wasn't properly seated on original assembly. Put it all back together and cleaned it up... no visible leak currently, but a tough spot to view. Time will tell.
Old 06-06-2020, 01:27 PM #9
Real Name: Scott
Real Name: Scott
Back to shop again on Friday for Safety Inspection and before I went, I checked for oil leaks. With this whole Covid-19 mess I've only put 2500kms on since the work in March. Front end puking oil again... spotted two little drops on the driveway as a heads up.
Same experienced tech got the vehicle again... front crank seal and oil pressure switches have been ordered (they had no stock) for replacement later next week.
coming , drips , engine , good , oil
She's taking a leak! Rear axle seal leak that is.... fightman80 3rd gen T4Rs 76 09-18-2014 04:52 PM
Coolant leak solution, pepper, eggs or liquid aluminum stop leak? BUGSEY General Discussions 1 01-30-2014 01:32 PM
Radiator leak, and oil leak maybe tranny? Not sure what should I do? ironmaidn23 Classic T4Rs 14 06-25-2013 10:34 AM
Gas leak Ekimrm Classic T4Rs 5 10-03-2012 08:35 PM
Coolant leak, whining noise, vacuum leak, alternator, starter, battery issues Max O 3rd gen T4Rs 4 12-03-2009 10:31 AM
