Old 03-08-2020, 10:08 PM #1
bigair96 bigair96 is offline
bigair96 will become famous soon enough
Toytec HD on TRD pro
Anyone running the toytec superflex hd on trd pro bilstein suspension? The toytec trd pro 2 inch lift comes with the standard superflex springs. I talked to toytec and they discourage unless constant weight in the rear, i.e. steel bumper.
So anyone doing it and can give input?
I have a third row, plate in back, fridge slide and surround, arb roller floor, and recovery gear boxes all the time. Gobi rack, sliders, full skids. Sits fairly level. Full overland packing (fridge) and hitch tire carrier gives some reverse rake. Would be ok with a little rake at baseline and level fully loaded.
Thanks.
2018 sr5P XP Predator. Needed that 3rd row. TRD Pro susp, Toytec trd pro 2inch lift (HD springs), Gobi stealth, Falken at3w 285s, Trd and rci alum skids, Arb breather, Upper grill light source lightbar, slee sliders, wilco high clearance, arb awning, pedal commander, treaty offroad recovery points, alpha rex pro headlights, trd intake/exhaust, goal zero solar setup, greenlane offroad bumper, warn winch. C4 rear bumper coming...
bigair96 is offline   Reply With QuoteReply With Quote
Old 03-10-2020, 02:21 PM #2
MillerPKA's Avatar
MillerPKA MillerPKA is offline
Real Name: Weston
MillerPKA is a jewel in the rough MillerPKA is a jewel in the rough MillerPKA is a jewel in the rough
MillerPKA's Avatar
Real Name: Weston
Thanks.
I would go with the HDs. You have enough weight back there that it should be fine. Expect rake when unloaded and level when loaded down.
Originally Posted by hayali View Post
I've been lifting toys for 30+yrs, about 10 years ago I never lift anything without UCA'S since
That...didn't answer the question. Like at all.
The New - 2019 TRD ORP, Supercharged, Lifted, 285s, armored,
https://www.toyota-4runner.org/5th-g...9-trd-orp.html
The Old - 2000 SR5, Supercharged, E-locker, 35s, 4.88
www.outworldhq.com/2000-toyota-4runner
MillerPKA is offline   Reply With QuoteReply With Quote
Old 03-11-2020, 03:15 PM #3
nickpsomas nickpsomas is offline
nickpsomas is on a distinguished road
If you're looking for an adjustable custom drop in solution, Eibach just released an adjustable rear coilover conversion. You can pick spring rate based on your weight and dial in your height.
Rear Height Adjuster [10+ 4-Runner] – Peak Suspension
nickpsomas is offline   Reply With QuoteReply With Quote
Old 03-11-2020, 03:19 PM #4
mteolus's Avatar
mteolus mteolus is offline
mteolus is a splendid one to behold mteolus is a splendid one to behold mteolus is a splendid one to behold mteolus is a splendid one to behold mteolus is a splendid one to behold mteolus is a splendid one to behold mteolus is a splendid one to behold
mteolus's Avatar
That's pretty cool.
2017 Off-road Premium w KDSS, moon roof, sliding rear cargo deck,3" Toytech Boss lift, SPC upper control arms, Sonoran Steel High Articulation KDSS Trac/PanHard Bar, RCI sliders, RCI skid plates aluminum including gas tank, C4 Fab diff skid plate, SCS Ray 10 Wheels Matte Gray, 285/70R17 Hankook Dynapro AT2 RF11 E-load RWL, Cali Raised LED 3x2 fog-light pods, Lock'r Down EXxtreme console safe with electronic lock, Auto Heat Shield all windows, Raingler rear cargo net, Canvasback rear covers, LFD Off-Road cross bars aluminum, LFD Hybrid bumper, LFD wind fairing, LFD Hi-lift jack mounts, Goat Armor, Blackgate Custom KDSS spacers, Ironman 2.5 awning with quick release mounts, Ironman 12,000 lb synthetic line winch.
Old 03-14-2020, 12:10 PM #5
Thanks, yea I am leaning that way. Its not my daily, so it doesnt get a ton of miles. If it wears out the rear shocks quicker, then it will be time to upgrade the shocks, but just upgrading the rear springs will save me a decent amount for now and hopefully get me the ride height I'm looking for without swapping out the whole suspension (trying to hold off as its been great so far).
Old 03-14-2020, 12:42 PM #6
Sundy Sundy is offline
Sundy has a spectacular aura about Sundy has a spectacular aura about Sundy has a spectacular aura about
The dobinsons variable rate coils seem like they could be a good option for you? They do add 3" but have one for no weight added, 400lbs, 700lbs etc.
Sundy is offline   Reply With QuoteReply With Quote
Old 03-14-2020, 01:02 PM #7
3 inches would be too much for the bilstein. The toytec HD are 2.5 inches assuming a certain amount of weight.
Old 03-14-2020, 09:37 PM #8
doctorres112's Avatar
doctorres112 doctorres112 is offline
doctorres112 is on a distinguished road
I have a set of toytec HD rear springs for sale. They are rated @ 200lbs, I needed more support so I swapped them out. I used them for ~2k miles. Let me know if your intereted.
-Chris
'19 Pro in Voodoo Blue -- Xenondepot HIDS
285/70/17 KO2s -- ToyTec Boss Aluma 2.5 Performance Lift -- FR roof rack
SSO sliders/Low-Pro bumper/high angle clearance & Exp-One rear bumper
instagram: @adventureswith6
doctorres112 is offline   Reply With QuoteReply With Quote
full , pro , rake , toytec , trd
Toytec Ultimate vs Toytec/Bilstein setup adam2562 5th gen T4Rs 47 01-10-2021 11:54 PM
Toytec Boss vs Toytec Ultimate vs Icon stage II MadeInMaine 5th gen T4Rs 8 09-15-2017 11:18 PM
FS: ToyTec RCC2.0 - ToyTec "Superflex" Rear Coils (FJ & 03+ 4Runner) The Giz For Sale: T4R Items 2 04-18-2017 01:49 PM
FS:3rd gen Toytec/Eibach-Bilstein Front,Toytec Superflex Bilstein rear. $750 shipped 05SVRACER For Sale: Suspension/Wheels/Tires 17 10-01-2014 03:06 PM
