09-07-2020, 06:14 PM
#61
According to Toyo's website, the LT265/70R17 E tires weigh 48 lbs.
The P265/70R17 SL tire in BSW is 39 lbs.
09-11-2020, 07:21 PM
#62
So far, so good
Just put a set on today. 265/70/17s SLs.
Too soon for objective data points. However, subjectively the AT IIIs look more aggressive than the previous version, and maybe a touch quieter. We'll be taking a trip out to Colorado towards the end of the month and will likely get them muddy and snowy.
2016 Magnetic Grey TE
1998 Green SR5 4WD - Sold
09-12-2020, 09:05 AM
#63
Considering these myself in stock size P metric. They look pretty good on yours. I’ll be interested to hear your thoughts as you use them more. Please follow back up on this thread!
2020 4Runner Venture
2002 4Runner SR5 4WD (sold)
1998 BMW M3/4/5
09-12-2020, 10:53 AM
#64
hmm I need a road hazard incident and jump on board these at3s
2011 Starfire Pearl GX460 stock base ;)
2012 Blizzard Pearl SR5 | 285 Toyo OC AT3 | Level 8 Slam | YotaWerx ActiveDuty | Die Hard AGM w/ArcLightLeds V2 Booster | Borla 40665 | URD Y & MAF Cal TRD | C4 Center LP | Maxbore 2mm TB "loaner from my boy Dave" | X20 10k Factor55 | Shrockworks Armory | RCI LCA skids | TC Gusset | LFD Offroad 7/8 | TJM Airtec dry aFe HPS coupler w/TRD CAI tube | B8 6112 | 650# King | ICON Delta Joint | Fox 2.0 VS| SAW 1.5" |230k|
| 03 DCSB Tacoma OME equipped, +320k Still Truckin |
09-19-2020, 02:57 AM
#65
Real Name: Luke
Real Name: Luke
Got mine the other day in P285/70R17. I didn't realize how smooth going back to P would be over the LT C I had been running. My off-roading is limited, but the truck will still be the primary driver in the Rust Belt Winters.
There's some rubbing even with the lift (which is only about 2"). I trimmed about 1/2" off of the bumper on both sides and had to push the passenger side front wheel well liner forward too. The driver's side is rubbing a little on the mud flap. I don't want to cut the mud flap until I'm sure it's just the mud flap and not working on the body mount.
09-19-2020, 12:18 PM
#66
Don't know when it was added but Toyo now has Pizza Cutters in the III.
LT255/80R17 121/118R E BSW - 355750 6.5-7.0-8.5
09-19-2020, 01:27 PM
#67
On Discount Tires website:
E-Load 285/70-R17 = 56lbs
C-Load 285/70-R17 = 56lbs
Doesn't make sense to me.
2017 Off-road Premium w KDSS, moon roof, sliding rear cargo deck,3" Toytech Boss lift, SPC upper control arms, Sonoran Steel High Articulation KDSS Trac/PanHard Bar, RCI sliders, RCI skid plates aluminum including gas tank, C4 Fab diff skid plate, SCS Ray 10 Wheels Matte Gray, 285/70R17 Hankook Dynapro AT2 RF11 E-load RWL, Cali Raised LED 3x2 fog-light pods, Lock'r Down EXxtreme console safe with electronic lock, Auto Heat Shield all windows, Raingler rear cargo net, Canvasback rear covers, LFD Off-Road cross bars aluminum, LFD Hybrid bumper, LFD wind fairing, LFD Hi-lift jack mounts, Goat Armor, Blackgate Custom KDSS spacers, Ironman 2.5 awning with quick release mounts, Ironman 12,000 lb synthetic line winch.
09-19-2020, 02:45 PM
#68
I have the P285/70R17 on my pro. They are unbelievably better than the Nittos that came stock so far for me although I only have about 500 miles on them. I could not be happier with my decision.
According to my tire guy these are some of the best road force numbers he has seen for a truck tire. He also talked a lot about checking the DOT dates to make sure you get a recent set. A lot of the tires from Discount sit in a warehouse for a long time and they have issues with balancing (that’s what he said at least).
09-19-2020, 03:03 PM
#69
AT3s have only been released since March 2nd, so none have been warehoused too long as of yet...
2014 T4R TE Nav KDSS Super White
Demello Hybrid Bolt On Sliders | Toyo Open Country AT III LT285/70R17 C | Ironman 4x4 Foam Cell Pro Stage 2 | Durobumps | Rago Molle Panels | Leather steering wheel cover | RCI Full Skids (Aluminum) | Drawer less drawer system and sleeping platform. | TRD CAI | RAV4 Sideview Mirrors: 87961-42D20 & 87931-42D50 | Blackvue DR650S-2CH | Cobra 75 WX ST with 4’ Firestik + Magnet Roof Top Mount | MXT275 Midland GMRS radio | 3M Crystalline: Front CR70, A-B CR50, B-Aft CR40 | RRW Leather Seat Covers w/Besond Seat Heaters| 3DMax Floor Mats and Rear Husky Liner | former LT265/70R17 C Duratracs
09-19-2020, 03:28 PM
#70
For sure... but always a good idea to check the DOT
09-21-2020, 12:25 AM
#71
Good idea.
It also looked like they made an attempt to make the outside of the tire more rugged and similar to a K02 but it isn't as thick, perhaps to save weight?
09-21-2020, 09:49 PM
#72
Take the flaps off as a test, if that clears the rub(my 285s did) I took a heat gun and molded the flaps back, they had about 3/4" play to melt them back.
09-22-2020, 10:11 AM
#73
Glad you like Toyo AT 3!
Can you please elaborate on what specifically “unbelievably better” on those vs. Nitto? (Just trying to get as much info as I can ).
And I am assuming you went from stock size Nitto, correct?
2013 Silver Trail (with KDSS)-Nitto TG-G2, Bilstein 5100, Custom lift: front 2.1", rear 1.5" (lift info: [URL=https://www.toyota-4runner.org/2938235-post744.html[/URL] thread #744)
1995 SR5 4x4, 1996 SR5 4x4, 2005 SR5 V8 4x4- All Sold, but not forgotten!
DON'T GET CONFUSED BETWEEN MY PERSONALITY AND MY ATTITUDE. MY PERSONALITY IS WHO I AM...MY ATTITUDE DEPENDS ON WHO YOU ARE
09-22-2020, 10:48 AM
#74
Another note, I think I read that someone was saying that these Toyo's had only a 2 ply sidewall. Just a note about that, my KO2 C-load only has a 2-ply sideway. E-load KO2's have 3 plies, the plies are just not as thick as the ones on the 2-ply but overall thicker since there are 3. BFG explained to me though that it is reinforced with essentially the same material as Kevlar, they just can't call it Kevlar like Goodyear does. Not sure if these Toyo's have as strong as a sidewall as the KO2's but Toyo is a good brand so I would guess they are strong enough for rough off-roading. I still find it interesting that the C-load and E-load weigh the same.
Got an answer back from Toyo. Not sure why they can't just say whether an E load has a stronger sidewall or not. I did ask about its sidewall in comparison to the K02 or the Goodyear Duratrac.
Thank you for contacting Toyo Tires USA. The Open Country ATIII in size LT285/70R17 in C/6 weighs 54.56 lbs. and the E/10 weighs 54.74. Both offer the standard 2 ply sidewall with the E/10 having a stronger tread casing.
We do not have information pertaining to the K02's sidewall information.
Both the C/6 and E/10 offer a 50,000 mile mileage warranty. We do not have testing related to the wear on both as that will be dependent on the application and types of use.
09-22-2020, 05:53 PM
#75
Yes I went from the stock Nittos on the pro to the AT3s. I have less road noise, what feels like better acceleration, and am showing about 0.5 mpg better on the dash. This of course is counterintuitive to having a lift and larger tires put on. I almost wonder if Toyota had aligned it correctly when I bought her.
The biggest difference was during the rain the other day... way stickier than the Terra grapplers. I wonder if all of these things are the reason they updated the tires on the Pro for 2021?
Thread Tools |
Display Modes |
Rate This Thread |
Linear Mode
