Old 01-06-2021, 03:57 PM #121
Stabbi Stabbi is offline
Stabbi is on a distinguished road
Originally Posted by Espresso_OI View Post
Out of curiosity - but for those running the ATIIIs, what tire pressure are you running (on the road) ?
new AT3s installed last week, 265/70/R17 SL at 38PSI. Ride has been excellent, but I was coming from some bad Nitto TG (originals) so... MPG appears to be slightly higher, but haven't really driven enough yet to confirm any change.
Stabbi is offline   Reply With QuoteReply With Quote
Old 01-06-2021, 07:31 PM #122
MIKE969 MIKE969 is offline
MIKE969 will become famous soon enough
Why are you running SL tires at 38psi? They should be at 32 cold.
2021 TRDORP/KDSS
OEM Pro Grille, Fifteen52 Turbomac HD Graphite (17x8.5 ET 0), Falken Wildpeak AT3W 265/70 SL.
MIKE969 is offline   Reply With QuoteReply With Quote
Old 01-10-2021, 05:26 PM #123
NorthPark NorthPark is offline
NorthPark will become famous soon enough NorthPark will become famous soon enough
Add me to +1 side wall gouge, didn't fail but I guess I'll be ordering a replacement tomorrow. 2k miles on them
10ply e-load 285s
NorthPark is offline   Reply With QuoteReply With Quote
Old 01-10-2021, 07:18 PM #124
They aired them to 38psi from Discount tire when they installed them, so just left it at that for now. I drove on them about 300 miles this week/weekend all highway. 38psi seems fine to me. Now, keep in mind when they aired them to 38 psi, it was about 50 degrees out. This week we are in the 20s at night...mid 30s in the day time, so not concerned about 38psi.
MPG is the same so far.
Old 01-16-2021, 03:33 PM #125
janoslc janoslc is offline
janoslc is on a distinguished road
Any comparison of these tires to nitto ridge grappler ?
Want to try P metric
Now i am running ko2 load E
Too stiff and heavy 60 lbs each
Enviado desde mi iPhone utilizando Tapatalk Pro
janoslc is offline   Reply With QuoteReply With Quote
Old 01-16-2021, 06:14 PM #126
5thToy 5thToy is offline
5thToy is just really nice 5thToy is just really nice 5thToy is just really nice 5thToy is just really nice
The concern over time would be uneven center wear. It would be interesting to do a chalk test to see if you are getting a full contact patch.
5thToy is offline   Reply With QuoteReply With Quote
Old 01-16-2021, 06:15 PM #127
Toyo Open County AT III (AT3)
38 PSI cold is likely too high and will result in premature and uneven wear down the center line of the tread.
Having worked in the service department of a dealership I can guarantee you that most tire guys don’t know jack shit about tire inflation pressures. It should be 32-33 PSI.
This is from Toyo’s site but applies to any brand:
https://www.toyotires.ca/sites/defau...s_20170203.pdf
2021 TRDORP/KDSS
Old 01-17-2021, 10:01 AM #128
they'll be quieter. also from E to P load its gonna get way softer which sounds like what youre after.
Old 01-17-2021, 09:53 PM #129
Yeah, I agree, I lowered them to 34lbs the other day. I may lower again to 32lb after some driving.
Old 01-21-2021, 03:30 PM #130
flyguy303 flyguy303 is offline
Real Name: Morgan
flyguy303 is on a distinguished road
Real Name: Morgan
Just put a set of 285 70 17 C load on my rig and so far they are great. Tracks REALLY straight and smooth, feels quieter than my old ko2s, and the C load seems to be a plusher ride. They look great, while not quite as aggressive with the sidewalls as the ko2s, I don't think they are lacking at all. Will update when they have seen snow, should get some next week.
Imgur: The magic of the Internet for pictures
flyguy303 is offline   Reply With QuoteReply With Quote
Old 01-21-2021, 03:38 PM #131
d1nguyen d1nguyen is offline
d1nguyen will become famous soon enough
Any reason hey C and E loads has different speed ratings? C Load shows Q speed rating and E Load shows S speed rating.
d1nguyen is offline   Reply With QuoteReply With Quote
Old 01-21-2021, 04:27 PM #132
I'm guessing, but I would think more mass and higher density equates to reduced ability to dissipate heat.
Old 02-19-2021, 10:21 PM #133
SilverTEP's Avatar
SilverTEP SilverTEP is offline
Real Name: Luke
SilverTEP will become famous soon enough SilverTEP will become famous soon enough
SilverTEP's Avatar
Real Name: Luke
Quick review of AT3s coming from E rated KO2s. I got Toyos in 285/70/17 C rated, they are as quiet and comfortable as KO2s. They are amazing in the rain, much much better than KO2s, zero hydroplaning, great stopping power, super confident in the rain with these.
KO2s were better in the snow, they seemed to grip better, but not by a wide margin. On pure rock it's hard to tell still, need few more trips, so far they seemed on par.
The sidewalls look great, and the rain performance makes them worth it for me, snow trips are just for fun for me.. but we get plenty of rain, and KO2s were sketchy on freeway off ramps and needing to stop really quick.
2018 TRD ORP w/ KDSS, Hefty Front Bumper, Ironman4x4 Pro Foam Cell, RSG Sliders, Nitto RGs 285/75/17 E, Victory 4x4 full steel armor, Diode Dynamics Fogs
SilverTEP is offline   Reply With QuoteReply With Quote
Old 02-22-2021, 03:32 PM #134
sawman1's Avatar
sawman1 sawman1 is offline
sawman1 is on a distinguished road
sawman1's Avatar
Agree with above.
I did a lot of research before changing out to Toyos. I ran 275/70/17 BFG KO2's for 16k miles on my Limited, and just swapped out here recently to 285/70/17 Toyo AT3s. They are P-rated, and I am SO much happier with them from a ride standpoint. I think the 275 E rated was overkill for my use - for me, they rode awful on a 4R and performed poorly/unpredictable in wet weather. Made the move for 1) Wet weather capability, 2) Ride quality and 3) A little larger. BFGs did kill it in the snow, I expect similar from the Toyos.
sawman1 is offline   Reply With QuoteReply With Quote
Old 02-22-2021, 10:44 PM #135
SilverTEP's Avatar
Real Name: Luke
SilverTEP's Avatar
Real Name: Luke
Awesome, had same 275/70 KO2s rated E because I didn't want to deal with rubbing and chopping the mount.. Felt so heavy, but were bulletproof on the trail esp sharp rocks. I finally got the chop and went with the AT3s at 285/70 rated C and now i have room to push my tires out for that instagram look lol.
KO2s killed it in the snow for me, didn't even had to air down, and had more grip in the snow then cars with bigger MTs. AT3s need to be air down to like 20PSI and then they are fine, obviously much better than stocks no matter what. I'm guessing similar would be in loose sand, since i think KO2s are made for that.
at3 , county , put , toyo , toys
FS:TOYO open county 295-70-R17 tires/Trail edition wheels w/general 265 tires 97supratt For Sale: Suspension/Wheels/Tires 17 01-07-2020 03:09 PM
Toyo Open Country H/T in 285/70/17 4RunnerAU 5th gen T4Rs 0 08-31-2016 07:36 AM
Toyo Open Country MT on 4th gen hobosapien 4th Gen T4Rs 9 05-06-2016 11:41 AM
