Old 03-09-2020, 04:01 PM #1
sjbill17 sjbill17 is offline
sjbill17 is on a distinguished road
Does This Look Right?
Just installed Icon 2.5 Front Coilivers w/ RR & CDCV, Icon 2.5 Rear Shocks w / RR & CDCV along with SPC Upper Control Arms. Just got it out of alignment shop. And because I know absolutely nothing about alignment, I’m want you guy’s opinion on my results.
Does This Look Right?-a18694c5-547e-4c92-a3ae-43ab85af52a2-jpeg
sjbill17 is offline   Reply With QuoteReply With Quote
Old 03-09-2020, 04:03 PM #2
obxbird obxbird is offline
obxbird is on a distinguished road
Looks good to me...how's it driving?
2021 4Runner TRD ORP: Bilstein 5100's all 4 corners, 1" Cornfed spacers in the rear, Firestone Air Bags rear, Poly bushings for sway bars, Scangauge 2, Vent Visors, Pro Comp 32 wheels and Wildpeaks 265-70R17 tires.
obxbird is offline   Reply With QuoteReply With Quote
Old 03-09-2020, 04:47 PM #3
baldrik78's Avatar
baldrik78 baldrik78 is offline
baldrik78 is a glorious beacon of light baldrik78 is a glorious beacon of light baldrik78 is a glorious beacon of light baldrik78 is a glorious beacon of light baldrik78 is a glorious beacon of light baldrik78 is a glorious beacon of light
baldrik78's Avatar
I feel like you should have more Caster.
2017 TRD ORP KDSS IG
Dobinsons IMS w/ 314/325 Coils - JBA UCAs - Durobumps - Firestone 4108
DRKDSS Disconnect Switch - Treaty Oak KDSS Spacers - Eimkeith PCK
SSO Roof Rack - SSO Sliders - SSO Slimline - Smittybilt X20 10k - RCI Skids
TRD Pro Wheels - Spidertrax Spacers - Mickey Thompson Baja Boss A/T 255/85 R17
baldrik78 is offline   Reply With QuoteReply With Quote
Old 03-09-2020, 06:41 PM #4
Drives great. Just didn't know if more caster is needed or anything. I don't know jack about alignment. Installed the suspension myself. Took me two days and a bottle of Aleve for my back, but I got it in. Got the CDCV set at the softest setting for now. Gonna give suspension time to settle and may crank the front up a little more. It has a little bit of forward rake right now with the bigger overlander springs, but plan on installing a Victory 4x4 rear Strike bumper w/ swingouts in the next 30-60 days so my wait for final height adjustment until then.
Old 03-09-2020, 06:43 PM #5
That's what I was thinking but it drives great. I got the Firestone Lifetime Alignment, so I can always have it redone. Running stock tire size at the moment. 285/70/17 General Grabber ATXs going on in two weeks.
Old 03-16-2020, 11:05 PM #6
Ok fellas. Today I made a hard right turn into a parking spot and my right front actually contacted my stock skid plate. My original thought was it contacted my Remote Resi but after inspection I found the right front tire had contacted my stock skid plate. My alignment remains as posted in my original post. And I am still running stock 265s on stock trail rims.
SPC UCA ball joint is in "D" position as stated in the install instructions.
I'm afraid its gonna be worse when I go to 285s.
Any suggestions?
Old 03-16-2020, 11:52 PM #7
ax2021 ax2021 is offline
ax2021 will become famous soon enough ax2021 will become famous soon enough
Any suggestions?
I am not familiar with SPC UCA, but your Caster is low . Try to get it to 3.9 or 4.1 . I am sure you will be good to go for 285’s. Good luck
ax2021 is offline   Reply With QuoteReply With Quote
Old 03-17-2020, 01:42 AM #8
I was just looking at my alignment spec sheet. And I will not claim to no jack $hit about alignment, but from looking at my before measurements, my left caster is at 4.0 and my right caster is at 3.8. It appears to me that the alignment dude *ucked it up by just adjusting the LCA cams to dial in the camber. I can say for a fact that he did not touch the UCA at all.
This whole alignment issue is puzzling me. Just wondering if you guys see the same thing that i'm seeing in the spec sheet.
And again, thanks so much for any info / advice you guys can give.
Old 03-17-2020, 02:25 AM #9
SpeedyKevin's Avatar
SpeedyKevin SpeedyKevin is offline
SpeedyKevin is a splendid one to behold SpeedyKevin is a splendid one to behold SpeedyKevin is a splendid one to behold SpeedyKevin is a splendid one to behold SpeedyKevin is a splendid one to behold SpeedyKevin is a splendid one to behold SpeedyKevin is a splendid one to behold
The shop most likely doesnt know how to work with the spc arms. Consider taking it elsewhere if they confirm they dont how
2019 ORP - KDSS, Dobinsons C59-302/GS59-700 front and C59-725/IMS59-50701 rear, Dobinsons UCA, DuroBump/Daystar bumpstops, Sonoran Steel High Articulation tracbar, Marlin Crawler LCA frame brace, OGS Lo-Key Bumper w/ Warn VR EVO 10-S, RCI Sliders, fully armored with RCI/C4/Outgear Solutions skids, Falken Wildpeak M/T 285/70/17, LFD SS-Crossbars, ARB breather kit (Rear Diff and Locker), ScanGaugeII, Anytime Front/Backup Camera, onboard ARB Twin compressor MORRFlate kit, and DD SS3 Sport fogs
SpeedyKevin is offline   Reply With QuoteReply With Quote
Old 03-17-2020, 02:54 AM #10
Yea, that's what i'm thinking, but I paid for a lifetime alignment with Firestone so i think i need to take it back. Have them put it back to the original settings and attempt to adjust camber with UCA. I can tell him how to do that, i do know that much. I just feel that my original caster numbers is where I want to be and camber should be easily adjusted with UCA by loosening the top nut and sliding it outward or inward in the slot.
I really need to get under there and look at my cam bolts. If i suspect correctly, i'm expecting my right side front and rear cams to be in the 3 o'clock position and my left side front and rear cams to be in the 9 o'clock position. Because my original camber on left and right was over -1 degree and the only way to fix that is by bringing the LCA inward. Hince my rub on skid plate.
Please correct me if i'm wrong.
Old 03-17-2020, 08:50 AM #11
kenwilliams0803 kenwilliams0803 is offline
kenwilliams0803 has a spectacular aura about kenwilliams0803 has a spectacular aura about kenwilliams0803 has a spectacular aura about
Good luck getting Firestone to adjust caster.
My branch just leaves mine at the 2.5* that it rolls in there every time with since it's just barely "in spec".
kenwilliams0803 is offline   Reply With QuoteReply With Quote
Old 03-17-2020, 09:13 AM #12
MAG GRY TACO15 MAG GRY TACO15 is offline
MAG GRY TACO15 is on a distinguished road
You got the spc i'm assuming for the ability to get more caster. So you need to have them redo it and get your caster up above 3 b/c those uca will easily do that. You could even get to 4 probably. The caster numbers you have are almost achievable with stock UCA's. I wonder if you alignment guy saw stock 4runner specs and tried to get there not knowing you want to get more caster.
MAG GRY TACO15 is offline   Reply With QuoteReply With Quote
Old 03-17-2020, 05:26 PM #13
I got the SPC on recommendation. For the ease of adjustment and range of adjustments.
Yea. I can take responsibility for that. Noobie mistake on my part. I’m still learning as I go.
Anyway I never told him I wanted more caster. So he just did what he’s trained to do. I’m gonna take it back and discuss it with them again. At $200 for Lifetime Alignment, they gonna do something.
Old 03-17-2020, 07:06 PM #14
Bobstoy610 Bobstoy610 is offline
Bobstoy610 is on a distinguished road
First post here so Hi and thank you all for your wealth of knowledge!
I picked up an 18 limited a few months ago and went to work on the suspension so here's how it went. I'm a mercedes tech and I'm quite familiar with alignments and how I want the car to ride and handle. I raised the front 2" and rear 1 to get the height that I wanted and threw it up on the rack. My numbers looked just like yours when I was finished but I HATED the way it darted down the road. Up it went again and I maxed out the caster by sacrificing some camber. Caster was @3. Hated that too. Got and installed UCAs with 3degrees built in. Up on the rack again! Got my camber back to 0 and put the caster at 4.1 on both sides. I'm now very happy with it to the point I can handle it with my knee at 90 (for test purposes only). Hope this helps on your quest. BTW the dancing bananas are supposed to go where I was happy!
Bobstoy610 is offline   Reply With QuoteReply With Quote
Old 03-17-2020, 09:48 PM #15
Thanks for your insight, i'm kinda new here myself.
You using SPC Upper Control Arms? If so what position did you set the ball joint and is it centered in the slot or offset inward or outward?
When I installed mine, I set the ball joint in the "D" position and centered in the slot per the instructions. As you can see by the alignment sheet, my camber was >/= -1.0 which is too much. I'm thinking the tech decreased the caster to get camber to -0.1 on both sides.
I'm thinking I should have marked my LCA cams prior to my alignment visit so I would know where they were set on the initial reading.
absolutely , alignment , cdcv , icon , i’m
