Old 03-09-2020, 07:20 PM #1
Ronniej Ronniej is offline
Ronniej is on a distinguished road
2011 4runner Brake Pads question
Hi,
I just replaced front and rear brakes on my 2011 4runner today. After I was done, I noticed that there was a clip that was attached to one of the old rear brake pads (picture enclosed). After watching many videos, nobody addresses this clip. What is it for and is it needed? If so where does it go?
Thanks in advance,
Ronnie
2011 4runner Brake Pads question-brake-clip-jpg
Ronniej is offline   Reply With QuoteReply With Quote
Old 03-09-2020, 07:42 PM #2
yotantexas's Avatar
yotantexas yotantexas is offline
yotantexas is on a distinguished road
yotantexas's Avatar
That is designed to squeal when the pad wears down to even with that tab. Its more of a wear indicator for your ears.
yotantexas is offline   Reply With QuoteReply With Quote
Old 03-09-2020, 08:38 PM #3
chester4Run chester4Run is offline
chester4Run is on a distinguished road
As previously noted, that's a wear indicator. It will cause a chirping noise when it hits the rotor when your pad wears down. It's usually positioned on the inside caliper such that forward rotation of the wheel pulls it toward the pad rather than away. That said, I've seen it put on both ways and it's probably fine so long as it doesn't contact anything.
2011 SR5 4wd
2004 SR5 4wd
1994 SR5 4wd (SOLD)
chester4Run is offline   Reply With QuoteReply With Quote
Old 03-10-2020, 12:05 AM #4
I didn't put these clips on the back brakes. Do I need to redo everything and put them on?
Old 03-10-2020, 12:57 AM #5
revlimiter-t4r revlimiter-t4r is offline
revlimiter-t4r is on a distinguished road
nope
revlimiter-t4r is offline   Reply With QuoteReply With Quote
Old 03-10-2020, 06:25 AM #6
yota1976's Avatar
yota1976 yota1976 is offline
yota1976 is on a distinguished road
yota1976's Avatar
If you inspect your brake pads every so often, when you rotate your tires, you won't need those tabs. I'm sure those were invented for people who never check anything. It lets the driver know when the pads are about to be gone and it will be metal to metal soon.
2019 TRD Off Road, Barcelona Red, Predator Steps, Sprint Booster V3
yota1976 is offline   Reply With QuoteReply With Quote
Old 03-10-2020, 09:16 AM #7
MannMade82 MannMade82 is offline
Real Name: Jason
MannMade82 is on a distinguished road
Real Name: Jason
What pads?
What pads did you install? Typically a set of 4 pads will include 2 with wear indicators to be installed one on each side. I change pads before they get any where near worn to those indicators...
2015 SR5 Premium 4x4 Super White
TRD CAI - n-fab Nerf Steps - Philips X-treme LED fogs - XenonDepot Philips HID Low Beam - Interior & Exterior LEDs - Bilstein 5100 All Around: Front 1.75", Rear 1" Cornfed spacers - Prothane/Whiteline front & rear sway bar bushings - General Grabber ATX 265/70/17 - ARB On Board Air
MannMade82 is offline   Reply With QuoteReply With Quote
Old 03-10-2020, 10:57 AM #8
I installed both front and rear brake pads. After finishing, I picked up one of the old rear brake pads and saw the clip in the picture. I never noticed the clip while I was changing the brakes. I thought OMG do I have to redo everything to put these clips in. Thanks to everyone for the responses.
Old 03-10-2020, 11:41 AM #9
Ukie's Avatar
Ukie Ukie is offline
Ukie is on a distinguished road
Ukie's Avatar
Originally Posted by Ronniej View Post
Hi,
Ronnie
That's a plenty of pad left. How many miles on your 2011 4Runner?
2011 4Runner SR5 4x4, Black, Sand Beige Leather, 3rd row.
AVS Bugflector II, OEM Mudguards, SPAREBUMPER SP424 - Black, Infinity Kappa 32.9cf Dash Speakers,
GY Wrangler Silent Armor, 265/70R17, Load C, Weathertech side visors, Husky WeatherBeaters, ~16.5 MPG
Ukie is offline   Reply With QuoteReply With Quote
Old 03-10-2020, 12:03 PM #10
Ukie's Avatar
Ukie's Avatar
Hi,
Thanks in advance,
Ronnie
Picture attached.
2011 4runner Brake Pads question-3-10-2020-11-50-28-am-jpg
Old 03-10-2020, 03:47 PM #11
I have 70K miles. I was starting to hear squealing noises when I hit the brakes. I did notice that I had a bit of pad left while replacing the brakes but I already purchased the pads and had time to replace them.
4runner , brake , clip , pads , rear
Tundra brake caliper leaked brake fluid all over pads, replace or clean pads? Srt4runner 3rd gen T4Rs 8 10-30-2015 12:42 AM
brake pads. my brake pads r squeeling. want to know if Thermo quiet will work spartacus 3rd gen T4Rs 4 04-21-2012 08:00 AM
2003 4runner brake pads? Red Devil 4th Gen T4Rs 1 06-13-2009 01:06 PM
Question -- Highlander Brake Pads Jeff Kleb 4th Gen T4Rs 24 04-05-2006 09:54 PM
Changing Brake Pads on an 03' 4Runner msanta Maintenance/Detailing 6 05-09-2004 03:48 AM
