Old 03-11-2020, 11:41 AM #1
El Burro Guapo El Burro Guapo is offline
Real Name: Nick
El Burro Guapo is on a distinguished road
Real Name: Nick
Exclamation Steering Wheel Shake since 6 Miles on my 20' Off-Road Premium!
Just bought a 2020 Black Metallic Off-Road Premium last Friday with 6 miles. Currently at 350 or so. Since I left the lot I have had steering wheel tremble at around 60 to 65 MPH. Took in Monday to have assessed. No big deal right wheel weights were off on three of four wheels. I figured may have fallen off in transit to dealer or test drive etc. Well I picked up and have been driving and now its back again! Has anyone experienced any issues like this? Wondering if it's a bad tire. My truck came with the Dunlop's. One of my buddies who is a Toyota Tech mentioned a local recall on some models with the Wrangler's but I have yet to hear anything on the Dunlop's.
I love my truck, but kind of crazy to have these issues with so few miles. Thoughts?
El Burro Guapo is offline   Reply With QuoteReply With Quote
Old 03-11-2020, 12:00 PM #2
mteolus's Avatar
mteolus mteolus is offline
mteolus is a name known to all mteolus is a name known to all mteolus is a name known to all mteolus is a name known to all mteolus is a name known to all mteolus is a name known to all
mteolus's Avatar
It's been an issue with a lot of people on previous year model's. Usually the balance requires road force. I can't find it right now, but there is a special way to balance Toyota tires too. You would think a dealership would know this though.
Found it. Check out this topic.
And if they still can't get it fixed, ask for a new 4runner. That is unacceptable.
2017 Off-road Premium w KDSS, moon roof, sliding rear cargo deck,3" Toytech Boss lift, SPC upper control arms, Sonoran Steel High Articulation KDSS Trac/PanHard Bar, RCI sliders, RCI skid plates aluminum including gas tank, C4 Fab diff skid plate, SCS Ray 10 Wheels Matte Gray, 285/70R17 BFG KO2 C load RWL, Cali Raised LED 3x2 fog-light pods, Lock'r Down EXxtreme console safe with electronic lock, Auto Heat Shield all windows, Raingler rear cargo net, Canvasback rear covers, LFD Off-Road cross bars aluminum, wind fairing, and Hi-lift jack mounts, Goat Armor.
Old 03-11-2020, 12:40 PM #3
08TxRunner's Avatar
08TxRunner 08TxRunner is offline
08TxRunner will become famous soon enough 08TxRunner will become famous soon enough
08TxRunner's Avatar
I've had my 20 for about six weeks and have a very mild shake as well around the same speed.
08TxRunner is offline   Reply With QuoteReply With Quote
Old 03-11-2020, 12:44 PM #4
Redsoxx1918 Redsoxx1918 is offline
Redsoxx1918 has a spectacular aura about Redsoxx1918 has a spectacular aura about
Itís not the tires. I had it on my 2016 SR5 premium, 2018 ORP and now my 2019 TRD PRO. Itís a known problem with the 4runner and I donít think anyone has ever found an absolute cure.
Redsoxx1918 is offline   Reply With QuoteReply With Quote
Old 03-11-2020, 01:00 PM #5
tm965 tm965 is offline
tm965 has a spectacular aura about tm965 has a spectacular aura about
for me it was the lower control arm bushings. a decent road force balance and replacing the stock control arms completely solved this for me. i think it has something to do with the rubber bushings the stock LCAs use.
tm965 is offline   Reply With QuoteReply With Quote
Old 03-11-2020, 01:03 PM #6
Dynamo's Avatar
Dynamo Dynamo is offline
Dynamo will become famous soon enough
Dynamo's Avatar
My '19 TRD ORP had it BAD when I bought it. Turned out that 2 wheels did not have any weights on them so I assume they weren't even balanced. I took it to the dealer and they balanced them. It was fine for a day then came back so I took it back to the dealer. They did their best to balance and even road force balance them but couldn't make them better so they replaced two tires. I can feel it mildly sometimes but it is mostly gone. It's not bad enough for me to take it back so I am living with it.
FJ Cruisers have the issue as well, and my previous '13 FJC was no exception. It was perfectly smooth when I had Michelin LTX's on it and the last set of tires installed, Terra Grappler G2's.
10 years ago I had a 2005 Infiniti G35 with the stock 20" wheels. It was an issue with them and the solution from the forums was to adjust the rack & pinion for a little more preload. They didn't have a lock ring on them like Toyotas have so I was easy to do. It didn't take much, like an 1/8th turn at the most. Too much and the steering wheel wouldn't return to center on its own. It worked though, make the adjustment and no more steering wheel shake. I realize it didn't fix the imbalance but it definitely made it not noticeable. If our steering racks didn't have that locking ring then I would give it a try. I tried to on my FJC but couldn't loosen it so I gave up.
2019 TRD ORP
Dynamo is offline   Reply With QuoteReply With Quote
Old 03-11-2020, 01:40 PM #7
Real Name: Nick
Real Name: Nick
Thank you for this! At least I will have some ammo now when I go back to the dealer. My 2005 Tahoe drove better than this thing does now.
Old 03-11-2020, 02:06 PM #8
kenwilliams0803 kenwilliams0803 is offline
kenwilliams0803 will become famous soon enough kenwilliams0803 will become famous soon enough
For me it was road force balance three times, then put the ones with the most weights on the back, then do NOT ever rotate them.
kenwilliams0803 is offline   Reply With QuoteReply With Quote
Old 03-11-2020, 02:14 PM #9
thennen's Avatar
thennen thennen is online now
thennen is just really nice thennen is just really nice thennen is just really nice thennen is just really nice thennen is just really nice
thennen's Avatar
And then there are others of us who never experience this. My 2019 TRDOR has been smooth as glass since I bought it 40,000 miles ago. Original tires, all pavement miles. Crazy.
thennen is online now   Reply With QuoteReply With Quote
Old 03-11-2020, 03:05 PM #10
Hans Moleman Hans Moleman is offline
Hans Moleman has a spectacular aura about Hans Moleman has a spectacular aura about
Yes it is the tires. It was long battle for me but I was able to resolve it. But I had to go through multiple road force balances on the the stock Dunlops, then multiple force balances and sets of Goodyear Ultra Terrains, then it was completely cured after getting BFG KO2's and balanced on the first try. This was all done under warranty but was still a pain.
2018 SR5 Premium MGM
TRD Pro wheels
LT265/70/17C BFG KO2
Hans Moleman is offline   Reply With QuoteReply With Quote
Old 03-11-2020, 03:16 PM #11
mesooohoppy mesooohoppy is offline
mesooohoppy has a spectacular aura about mesooohoppy has a spectacular aura about mesooohoppy has a spectacular aura about
write all of your dealer visits and interactions down. it will help you later if the dealer refuses to get you a new car and you have to contact a higher up; it will look like you did your homework and tried.
99 4runner limited; imperial jade mica
IG: mesooohoppy
mesooohoppy is offline   Reply With QuoteReply With Quote
Old 03-11-2020, 05:34 PM #12
00Sebby's Avatar
00Sebby 00Sebby is online now
Real Name: Mark
00Sebby has a spectacular aura about 00Sebby has a spectacular aura about 00Sebby has a spectacular aura about
00Sebby's Avatar
Real Name: Mark
Steering wheel shake usually indicates front tire imbalance if actually the tires. If rear tires not balanced, you will feel it more in the seat. If I was chasing this, I would rotate the front wheels/tires to back and vice versa to see if it moves. At least if it does, you can blame the tires. If it doesn't you still have a mystery.
My '10 Trail was glass smooth as long as the tires were balanced. I did get two KO2s one time that would not balance even with Road Force. They were deemed bad and replaced. My '20 ORP was super smooth with the Bridgestones for the first 500 miles, then I replaced them with KO2s. Still perfectly smooth up to 80 or so which is the fastest I've had it so far.
Current: 2020 ORP Silver. BFG AT KO2s, Pro LED fogs, Infinity REF-3032CFX dash speakers.
Former: 2010 TE Silver w/ C4 Fab Rock Sliders, TRD skid plate, ECGS bushing upgrade, Bilstein 5100s, and BFG AT KO2 tires.
00Sebby is online now   Reply With QuoteReply With Quote
Old 03-11-2020, 05:50 PM #13
Real Name: Nick
Real Name: Nick
Update: I brought in today because I couldn’t take it anymore. Was told there was a bulletin released the day I took in for service stating select 4runners with the Dunlop’s like mine need to be brought in. I think it’s something more serious because the dealer service rep said a master tech has to look at it. I’m keeping all of my paperwork in case things get ugly.
Old 03-11-2020, 06:28 PM #14
Gmnorris74 Gmnorris74 is offline
Gmnorris74 is on a distinguished road
Please keep us updated I have a 2020 SR5 with 800 miles and have already been back in to get the tires rebalanced once and get slight steering wheel shake in the same speed range. Just trying to see how long I can deal with it until it goes back in.
2020 SR5 4wd Barcelona Red
Gmnorris74 is offline   Reply With QuoteReply With Quote
Old 03-11-2020, 07:29 PM #15
Muzzle of Bees Muzzle of Bees is offline
Muzzle of Bees will become famous soon enough
Mine does the same thing at 55-60 mph. Did fine after a tire rebalance and rotatable for about a month. It’s happening again. I try and stay above or below 55 or 60 otherwise. I am not concerned about it and I am not going through a rebalance every couple of months. The 4Runner goes off-road and I drive over lots of those traffic bumps.
2016 TEP
Muzzle of Bees is offline   Reply With QuoteReply With Quote
issues , miles , steering , truck , wheel
Steering Wheel Shake stever1000 3rd gen T4Rs 46 08-10-2017 12:36 AM
Steering Wheel Shake sport2004 4th Gen T4Rs 8 07-27-2017 11:21 AM
Steering Wheel Shake nvestor88 3rd gen T4Rs 10 07-13-2014 01:40 PM
Steering wheel shake, need help sina518 4th Gen T4Rs 11 12-19-2012 05:46 PM
steering wheel shake rayny1014 3rd gen T4Rs 1 09-17-2007 09:39 PM
