Old 03-11-2020, 04:32 PM #16
2112 R's Avatar
2112 R 2112 R is offline
2112 R will become famous soon enough 2112 R will become famous soon enough
2112 R's Avatar
If you already have tires get the skids ... and some sliders.
I've got the full RCI aluminium skid plate set including gas tank.
The only piece I'm missing is the diff and that was because they didn't have the KDSS version when the group buy was on.
I've beat the hell out of them, come down hard on rocks, scraped them all up, dented the gas tank one from a misplaced rear tire on a rock (tire slid off and the gas tank skid took the full weight of the vehicle).
Highly recommend them. If the aluminum ones are this good I can guarantee the steel ones must be insane.
Went with aluminium due to weight and my 4r is my DD.
Super easy to install in a single afternoon. It can be done solo, but much easier and faster with a buddy and some beer.
2112 R is offline   Reply With QuoteReply With Quote
Old 03-11-2020, 04:49 PM #17
Drobs Drobs is offline
Drobs is a glorious beacon of light Drobs is a glorious beacon of light Drobs is a glorious beacon of light Drobs is a glorious beacon of light Drobs is a glorious beacon of light Drobs is a glorious beacon of light
Unless all your off roading consists of is beach driving, expect there to be rocks.
2019 OR - LT285/70R17 Yokohama Geolandar MT, SPC UCA's, BMC, Eibach Pro Truck Lift, Warn VR10 Winch, Warn 100022 Winch Bumper, TRD Skid Plate, Cali Raised Light Bar, Shrockworks Sliders and Skids, LFD Ruggadized Cross Bars, Sprint Booster.
Drobs is offline   Reply With QuoteReply With Quote
Old 03-11-2020, 05:11 PM #18
blackened_offroad blackened_offroad is offline
blackened_offroad has a spectacular aura about blackened_offroad has a spectacular aura about blackened_offroad has a spectacular aura about
i dented the shit out of my fuel tank skid this weekend in moab. hit all of the other ones too. I was doing some decent steps, around 6.5/10 level difficulty. I plan on going to Moab a few times this year, at least. might have to upgrade to some more substantial steel ones.
blackened_offroad is offline   Reply With QuoteReply With Quote
Old 03-11-2020, 05:11 PM #19
SpeedyKevin's Avatar
SpeedyKevin SpeedyKevin is offline
SpeedyKevin is a splendid one to behold SpeedyKevin is a splendid one to behold SpeedyKevin is a splendid one to behold SpeedyKevin is a splendid one to behold SpeedyKevin is a splendid one to behold SpeedyKevin is a splendid one to behold SpeedyKevin is a splendid one to behold
Out of all the skids, the Diff one was the most PITA to install for me lol. Kept dropping the bolt into the skid. Had to remove the skid to get it back lol. If you decide to get the diff skid, use tape to hold the bolts in place when you're tightening them!
2019 ORP - KDSS, Dobinsons C59-302/GS59-700 front and C59-725/IMS59-50701 rear, Dobinsons UCA, DuroBump/Daystar bumpstops, Sonoran Steel High Articulation tracbar, Marlin Crawler LCA frame brace, OGS Lo-Key Bumper w/ Warn VR EVO 10-S, RCI Sliders, fully armored with RCI/C4/Outgear Solutions skids, Falken Wildpeak M/T 285/70/17, LFD SS-Crossbars, ARB breather kit (Rear Diff and Locker), ScanGaugeII, Anytime Front/Backup Camera, onboard ARB Twin compressor MORRFlate kit, and DD SS3 Sport fogs
SpeedyKevin is offline   Reply With QuoteReply With Quote
Old 03-11-2020, 05:17 PM #20
comtn4x4's Avatar
comtn4x4 comtn4x4 is offline
comtn4x4 is a splendid one to behold comtn4x4 is a splendid one to behold comtn4x4 is a splendid one to behold comtn4x4 is a splendid one to behold comtn4x4 is a splendid one to behold comtn4x4 is a splendid one to behold
comtn4x4's Avatar
Originally Posted by DeltaWhiskey View Post
I guess I don't see the overkill part, these should help with possible cv boot punctures shouldn't they?
I've never heard of anyone puncturing a CV boot by an object going through the A arm. The A arms are not a weak point in my opinion, they're plenty tough and unless you are rock crawling you're not likely to do anything to them. I'd spend that money on ABS guards. I've damaged the ABS sensors twice but never done any damage to my A-arms.
Rear link guards are a good investment too
comtn4x4 is offline   Reply With QuoteReply With Quote
Old 03-11-2020, 05:18 PM #21
delloro's Avatar
delloro delloro is offline
delloro is just really nice delloro is just really nice delloro is just really nice delloro is just really nice
delloro's Avatar
I have decided to upgrade the skid plates on my 4R. I am looking at RCI since they currently have a 15% discount and reasonable shipping. Initially I plan to order the full skid set (engine, trans,transfer case) and the A arm skids. I am stuck on choosing aluminum or steel. The steel clearly is stronger, but at a 25% weight disadvantage as well as potential rust makes the aluminum consideration worthy. My off road trips will be enough to justify these, but I am looking to see what others RCI owners chose and why. As far as intended use, no rock crawling or tackling major ledges.
I have RCI's aluminum skids and I like them. I use them occasionally and unintentionally. If I was intending to drag them across rock, then I would have got steel.
These cars are not light to begin with. Saving weight is a good idea, and it adds up
delloro is offline   Reply With QuoteReply With Quote
Old 03-12-2020, 01:24 AM #22
EddieV4runnin's Avatar
EddieV4runnin EddieV4runnin is offline
EddieV4runnin is a jewel in the rough EddieV4runnin is a jewel in the rough EddieV4runnin is a jewel in the rough EddieV4runnin is a jewel in the rough
You’ll never notice any difference in acceleration from aluminum to steel on your 4Runner. I went with RCI steel skids and love the fit and finish. I ran over a pack of coyotes two weeks ago and was surprised to find no damage to the bottom of the 4Runner and likely how easily all the fur and blood cleaned came off the powder coat.
Mods are loading.......
EddieV4runnin is offline   Reply With QuoteReply With Quote
Old 03-12-2020, 12:17 PM #23
david05111 david05111 is offline
david05111 will become famous soon enough
Just an aside from a bit of a noob. How good is the stock TRD skidplate found on the Pros? Is it actually effective or is it just basically for looks and worth replacing?
david05111 is offline   Reply With QuoteReply With Quote
Old 03-12-2020, 12:46 PM #24
1100 Remington Man's Avatar
1100 Remington Man 1100 Remington Man is offline
1100 Remington Man is on a distinguished road
Being from Iowa where they salt the roads a lot in winter I would shy away from Steel.
1100 Remington Man is offline   Reply With QuoteReply With Quote
Old 03-12-2020, 12:48 PM #25
ryguytheman's Avatar
ryguytheman ryguytheman is offline
ryguytheman is just really nice ryguytheman is just really nice ryguytheman is just really nice ryguytheman is just really nice ryguytheman is just really nice
I can't answer specifically about the TRD skid, but I still have my stock SR5 one. I have put it through the ringer, and it's held up fine. It's beat to hell, warped, scraped, and rusty where the scrapes are. But still solid. I re-paint it every few months to keep the rust at bay. I imagine that the TRD one is probably better than the SR5 plate.
Aftermarket skids look nice, but I think I'd be inclined to buy a take-off from Craigslist when this one is done. The stock skid is perfectly functional, cheap and almost new secondhand, and easy to get a hold of. Will not perform as well as aftermarket, but I can buy several used stock skids for the amount of a new aftermarket one. Talking about the front skid here.
Build Thread
2015 SR5 Premium | SSO Slimline Bumper | 20" Heise LED Lightbar | 10K LB Smittybilt Winch | 285/70/17 | Shrockworks Sliders with Tread Plate | Toytec BOSS Aluma Series coilovers with 700 lb Coils | HD Superflex Rear Coils | SPC Upper Control Arms | Differential Drop | ARB Twin Compressor | CBI Ditch Light Brackets with Cheapo Amazon LED Cubes | UpTop Bravo Rack | RCI Skids
ryguytheman is offline   Reply With QuoteReply With Quote
Old 03-12-2020, 01:44 PM #26
DeltaWhiskey's Avatar
DeltaWhiskey DeltaWhiskey is offline
DeltaWhiskey has a spectacular aura about DeltaWhiskey has a spectacular aura about
I think I am just going to keep the TRD skid I have and add the RCI conversion plate with a Steel trans and transfer case skid to start. Fuel tank and rear diff in a couple months.
2019 SW TRDORP
DeltaWhiskey is offline   Reply With QuoteReply With Quote
Old 03-12-2020, 02:03 PM #27
-E5J-'s Avatar
-E5J- -E5J- is offline
Real Name: J
-E5J- has a spectacular aura about -E5J- has a spectacular aura about
-E5J-'s Avatar
Real Name: J
+1 for aluminum all the way back past the t-case plus RCI DOM sliders. Phenomenal products and super beefy.
2019 4Runner TRD Pro, Midnight Black Metallic - RCI Sliders & Aluminum skids, WeatherTech Floor mats all around, Toyota wind/bug deflector on hood
2016 4Runner XP, Magnetic Grey Metallic - Sold
2015 4Runner Limited, Classic Silver - Sold
2002 4Runner SR5 Sport Edition, Thunder Cloud Metallic Grey - Sold
-E5J- is offline   Reply With QuoteReply With Quote
Old 03-12-2020, 02:11 PM #28
I already have RSG sliders, and they are beefy as well
2019 SW TRDORP
Old 03-12-2020, 02:13 PM #29
Cymon's Avatar
Cymon Cymon is offline
Real Name: Chris
Cymon is just really nice Cymon is just really nice Cymon is just really nice Cymon is just really nice
Cymon's Avatar
Real Name: Chris
It's 1/4" aluminum, the same that all of the aftermarket aluminum skids are. It holds up pretty well, is wider than the RCI skid but doesn't go back as far. The front RCI skid is the same length as the OEM and TRD front and middle skids. The TRD skid is plenty strong for 99% of the people who drive 4runners. For the other 1% they already have a bumper and aftermarket steel skids.
2015 SR5 Premium 4wd Magnetic Grey w/3rd row: Frontrunner Slimline II 3/4 Rack - Yakima Skybox 16 - Weathertech - 22" Behind Grill Light Bar - TRD Skid w/Full Aluminum RCI Skids - RCI Sliders - Falken AT3 265 SL - Lamin-X - Taxa Cricket
"If I Can Do it You Can" Light Bar Install
ARB Breather Mod
Cymon's Weekend Warrior/MFD Thread
Cymon is offline   Reply With QuoteReply With Quote
aluminum , rci , skid , skids , steel
Need help with upgrading Dark Lord General Discussions 27 01-25-2015 02:51 PM
Upgrading USB from 1.1 to 2.0 or even 3.0 apurvakt 5th gen T4Rs 2 07-31-2012 04:09 PM
Upgrading LCPLHumiston 3rd gen T4Rs 18 10-20-2011 11:38 PM
upgrading seats 05-07 bopyles 4th Gen T4Rs 1 07-18-2008 08:29 AM
rim upgrading BROOKLYN Engines / Suspension / Wheels / Tires / Audio / Accessories 6 01-24-2006 01:20 PM
