Old 03-11-2020, 02:58 PM #1
DeltaWhiskey's Avatar
DeltaWhiskey DeltaWhiskey is offline
DeltaWhiskey has a spectacular aura about DeltaWhiskey has a spectacular aura about
upgrading skids
I have decided to upgrade the skid plates on my 4R. I am looking at RCI since they currently have a 15% discount and reasonable shipping. Initially I plan to order the full skid set (engine, trans,transfer case) and the A arm skids. I am stuck on choosing aluminum or steel. The steel clearly is stronger, but at a 25% weight disadvantage as well as potential rust makes the aluminum consideration worthy. My off road trips will be enough to justify these, but I am looking to see what others RCI owners chose and why. As far as intended use, no rock crawling or tackling major ledges.
2019 SW TRDORP
DeltaWhiskey is offline   Reply With QuoteReply With Quote
Old 03-11-2020, 03:02 PM #2
Thrasher_S's Avatar
Thrasher_S Thrasher_S is offline
Thrasher_S will become famous soon enough
Thrasher_S's Avatar
I think it depends on your use. For me, aluminum for sure, but I'm worried about rust and I'm mostly "bashing" snow and sticks.
2018 TRD Off Road Premium - Barcelona Red
Thrasher_S is offline   Reply With QuoteReply With Quote
Old 03-11-2020, 03:09 PM #3
Inv4drZm's Avatar
Inv4drZm Inv4drZm is offline
Inv4drZm's Avatar
I live in KS, so take it from me, don't worry about rust on steel skid plates. I've painted mine once in 3 years, with lots of scrapes on them, and just have very light surface rust on the scrapes. Remember they're 3/16 steel so it'll take years and years and years for them to actually rust through if you don't respray them every 5 years.
I'm still not convinced you should actually buy skids if you don't rock crawl at all. Maybe it depends on your lift amount and tire size but dropping a grand on skids, a t-case is what, $300 to replace?
Keep in mind you're adding weight to the lowest part of the vehicle so you'll actually be lowering the center of gravity. It's the best place to put the weight compared to something like a roof rack.
I guess my vote is for just doing the transmission skid from steel. Buying something else with the savings.
Inv4drZm is offline   Reply With QuoteReply With Quote
Old 03-11-2020, 03:09 PM #4
comtn4x4's Avatar
comtn4x4 comtn4x4 is offline
comtn4x4 is a splendid one to behold comtn4x4 is a splendid one to behold comtn4x4 is a splendid one to behold comtn4x4 is a splendid one to behold comtn4x4 is a splendid one to behold comtn4x4 is a splendid one to behold
comtn4x4's Avatar
If you're not scraping your belly much I'd go with aluminum. No need for extra strength if you're only worried about incidental hits. You'll appreciate the weight savings
And skip the A-arm skids. They're pointless overkill
comtn4x4 is offline   Reply With QuoteReply With Quote
Old 03-11-2020, 03:16 PM #5
mteolus's Avatar
mteolus mteolus is offline
mteolus is a splendid one to behold mteolus is a splendid one to behold mteolus is a splendid one to behold mteolus is a splendid one to behold mteolus is a splendid one to behold mteolus is a splendid one to behold mteolus is a splendid one to behold
mteolus's Avatar
I went with aluminum, but that was after I got a lift so I scrape a lot less now than stock (stock height is not 9.6 as Toyota claims by the way). If you are not going to be doing a lot of rock crawling, aluminum is the way to go. I recommend still getting the front skid powdercoated (or you can just paint the front part with a rattle can), otherwise the aluminum will start to look tacky after a while. The rest I wouldn't worry about powdercoating. I didn't bother with the lower control arm skids, I didn't think that would be an issue even if they were hit.
Otherwise, just make sure you put anti-seize on all the bolts when installing.
2017 Off-road Premium w KDSS, moon roof, sliding rear cargo deck,3" Toytech Boss lift, SPC upper control arms, Sonoran Steel High Articulation KDSS Trac/PanHard Bar, RCI sliders, RCI skid plates aluminum including gas tank, C4 Fab diff skid plate, SCS Ray 10 Wheels Matte Gray, 285/70R17 Hankook Dynapro AT2 RF11 E-load RWL, Cali Raised LED 3x2 fog-light pods, Lock'r Down EXxtreme console safe with electronic lock, Auto Heat Shield all windows, Raingler rear cargo net, Canvasback rear covers, LFD Off-Road cross bars aluminum, LFD Hybrid bumper, LFD wind fairing, LFD Hi-lift jack mounts, Goat Armor, Blackgate Custom KDSS spacers, Ironman 2.5 awning with quick release mounts, Ironman 12,000 lb synthetic line winch.
Old 03-11-2020, 03:31 PM #6
jp.vegas jp.vegas is offline
jp.vegas is a glorious beacon of light jp.vegas is a glorious beacon of light jp.vegas is a glorious beacon of light jp.vegas is a glorious beacon of light jp.vegas is a glorious beacon of light jp.vegas is a glorious beacon of light
I'd rather have the cheap insurance than risk needing to be rescued from the middle of some desert somewhere with a busted t-case.
'20 Army Green 4Runner TRD PRO
'16 Quicksand Tundra TRD PRO Gone
'08 Salsa Red Pearl 4x4Runner SE V6:
Gone
jp.vegas is offline   Reply With QuoteReply With Quote
Old 03-11-2020, 03:43 PM #7
Inv4drZm's Avatar
Inv4drZm's Avatar
A buddy I've wheeled with has an FJ without aftermarket skids. He's taken it everywhere I've gone, and everywhere an IFS FJ could go. The only time he hurt his T-case was from sending too much torque through it, cracking it near the input shaft, and even then he JB-welded it and drove it 800 miles home. If you managed to break a t-case in the middle of a desert without doing any tough obstacles you are obviously doing something very wrong. BTW my buddy paid $100 for his new t-case.
I just don't see the use-case for aluminum skids. You either use your skids or you don't. 1/8" steel is a much better and cheaper option than aluminum.
Old 03-11-2020, 03:51 PM #8
Shit happens, simple as that. My back yard is Death Valley and the Mojave desert. Wheeling here is an exercise in surviving the shit that does happen and preparedness is a thing. That road you came in on a week ago could be gone today, washed out from some flash flood or what have you. Skids are cheap insurance and I've always gone with aluminum because I'm not dragging my truck over rocks on purpose but if I have/need to, then I won't sweat it.
Gone
Old 03-11-2020, 03:54 PM #9
I guess I don't see the overkill part, these should help with possible cv boot punctures shouldn't they?
2019 SW TRDORP
Old 03-11-2020, 03:56 PM #10
safdSA safdSA is offline
safdSA is on a distinguished road
I went with their aluminum for weight savings.
safdSA is offline   Reply With QuoteReply With Quote
Old 03-11-2020, 03:57 PM #11
Good info. it seems to me that too much protection is better than too little. The aluminum set weighs 70lbs, the steel 120lbs. The difference isn't that significant in the general scheme of things.
2019 SW TRDORP
Old 03-11-2020, 04:01 PM #12
Inv4drZm's Avatar
Inv4drZm's Avatar
I've literally been trapped by a flash flood before with a group of Toyotas. We waited 30 minutes and drove through the water once it died down. Didn't see any rocks that were moved
Buy whatever makes you sweat less, I just don't see how 1/8" steel has any disadvantage to aluminum.
Old 03-11-2020, 04:08 PM #13
Inv4drZm's Avatar
Inv4drZm's Avatar
If you're like me, you'll eventually want bigger tires, more lift, more capability. Steel will be good to have for the long term.
Old 03-11-2020, 04:12 PM #14
SpeedyKevin's Avatar
SpeedyKevin SpeedyKevin is offline
SpeedyKevin is a splendid one to behold SpeedyKevin is a splendid one to behold SpeedyKevin is a splendid one to behold SpeedyKevin is a splendid one to behold SpeedyKevin is a splendid one to behold SpeedyKevin is a splendid one to behold SpeedyKevin is a splendid one to behold
I personally use an aluminum front skid and steel transmission and tcase (+ Diff skid). Main reason I went steel for the trans/tcase was I like to rock crawl and was worried about slipping off rocks. Can control the front pretty well but not the middle lol.
Been driving all over Death Valley (not particularly difficult terrain) and haven't felt the need yet for having All Steel vs Aluminum yet. Will probably replace the front skid with steel if I land on it one more time lol.
2019 ORP - KDSS, Dobinsons C59-302/GS59-700 front and C59-725/IMS59-50701 rear, Dobinsons UCA, DuroBump/Daystar bumpstops, Sonoran Steel High Articulation tracbar, Marlin Crawler LCA frame brace, OGS Lo-Key Bumper w/ Warn VR EVO 10-S, RCI Sliders, fully armored with RCI/C4/Outgear Solutions skids, Falken Wildpeak M/T 285/70/17, LFD SS-Crossbars, ARB breather kit (Rear Diff and Locker), ScanGaugeII, Anytime Front/Backup Camera, onboard ARB Twin compressor MORRFlate kit, and DD SS3 Sport fogs
SpeedyKevin is offline   Reply With QuoteReply With Quote
Old 03-11-2020, 04:31 PM #15
patkelly4370's Avatar
patkelly4370 patkelly4370 is offline
patkelly4370 is a splendid one to behold patkelly4370 is a splendid one to behold patkelly4370 is a splendid one to behold patkelly4370 is a splendid one to behold patkelly4370 is a splendid one to behold patkelly4370 is a splendid one to behold
One may not be rock crawling, but objects can still be thrown up into the undercarriage. Surprisingly large and hard objects.
patkelly4370 is offline   Reply With QuoteReply With Quote
aluminum , rci , skid , skids , steel
Need help with upgrading Dark Lord General Discussions 27 01-25-2015 02:51 PM
Upgrading USB from 1.1 to 2.0 or even 3.0 apurvakt 5th gen T4Rs 2 07-31-2012 04:09 PM
Upgrading LCPLHumiston 3rd gen T4Rs 18 10-20-2011 11:38 PM
upgrading seats 05-07 bopyles 4th Gen T4Rs 1 07-18-2008 08:29 AM
rim upgrading BROOKLYN Engines / Suspension / Wheels / Tires / Audio / Accessories 6 01-24-2006 01:20 PM
