Old 03-12-2020, 11:30 AM #1
Runnin4MO Runnin4MO is offline
Runnin4MO is on a distinguished road
What does this pan contain? It's not engine oil!
So with my mind elsewhere today, of course I do an oil change and drain the wrong damn pan! First i think, why is the oil coming out Purple? Then I think, thats no where near 6.5qt that came out of that pan. Ah, now i recall i have to take a damn plate off to get to the oil pan drain which i've done a 100 fuc@ing times before. $#@
ANYWAY, in the pic attached, what is the pan with the red arrow pointing to that I drained?
Thanks all!
What does this pan contain? It's not engine oil!-2020-03-12-10_23_44-window-jpg
Runnin4MO is offline   Reply With QuoteReply With Quote
Old 03-12-2020, 11:34 AM #2
vipergrhd's Avatar
vipergrhd vipergrhd is offline
vipergrhd is on a distinguished road
vipergrhd's Avatar
Tranny
That is your transmission pan it contains transmission fluid.
vipergrhd is offline   Reply With QuoteReply With Quote
Old 03-12-2020, 11:37 AM #3
stooges459 stooges459 is offline
stooges459 is on a distinguished road
That's your transmission pan. If you were able to catch the ATF as it drained, you can measure and put back the same amount. Might be a good time to check the fluid too (check for color, burnt smell, etc). To be safe/thorough, make sure to do a fluid level check at the proper temp to make sure you're not under/over filled.
2012 SR5 - Salsa Red - Bilstein 5100 - SPC UCA - SCS F5 (bronze) - Falken Wildpeak AT3W 285/75/17 - RSG sliders
stooges459 is offline   Reply With QuoteReply With Quote
Old 03-12-2020, 11:41 AM #4
honda250xtitan is just really nice honda250xtitan is just really nice honda250xtitan is just really nice honda250xtitan is just really nice
hope your day job doesn't require use of your brain.
2016 TE : Grocery Getter, 285/70R17 K02's, Prinsu Rack, 6112, T13, Fox 2.0, DirtKing Fabrication
2017 F250 6.7: ICON, BajaDesigns, DIY Retrofit headlights
Old 03-12-2020, 11:52 AM #5
Perfect, 125k miles on it, needed to change it anyway.
Thanks guys!
Old 03-12-2020, 12:04 PM #6
<<<<'s Avatar
<<<< <<<< is offline
<<<< has a spectacular aura about <<<< has a spectacular aura about
<<<<'s Avatar
Honda250, that was little harsh. We all make mistakes. He owned up to it and totally got my respect. Running, no worries just get trans oil from the dealer put same amount back in and you are good.
Who Dares Wins
2013 TRAIL KDSS / Forged TRD 17x8.5 Wheels / Nitto TG 285/70/17 / Shrockworks Sliders / ASFIR Aluminum Trans Skid / 5000K HID Low HL / 5000K 10000 Lumen LED High HL /3000K LED Fogs / TRD Billet Oil Cap / B&I Carbon Fiber Dash / TRD Black Shift Knob / LED Interior / XUJI Leather Steer Wheel / Aluminum Pedals / Aluminum Battery Holddown / Northstar AGM battery / TRD Carpet Mats / LED floor lights / ARB on-board Air
<<<< is offline   Reply With QuoteReply With Quote
Old 03-12-2020, 12:22 PM #7
spartacus's Avatar
spartacus is a jewel in the rough spartacus is a jewel in the rough spartacus is a jewel in the rough spartacus is a jewel in the rough
spartacus's Avatar
Thanks guys!
you are not alone my neighbor did it to his Tacoma and then filled the engine with twice as much oil and drove without atf fluid until he noticed the transmission slipping. So you did the right thing by asking so kudos.
Old 03-12-2020, 12:50 PM #8
ProLee's Avatar
ProLee ProLee is offline
ProLee will become famous soon enough
ProLee's Avatar
My nephew did this exact same thing on his Lexus ISF, called me to ask why his transmission was slipping after he changed his engine oil.
ProLee is offline   Reply With QuoteReply With Quote
Old 03-12-2020, 12:54 PM #9
So a bit under 3.25qt came out of the Drain Hole (pic)... after reading through some articles I've gathered the following procedure:
-make sure the pan is perfectly level
-add 3.5qt (.25qt more then came out) in the Fill Hole (pic) of TOYOTA ATF WS fluid
-connect Techstream
-start the engine and move from P to D a few times to get the temp up to between 104-113F
-then while the engine is running, use a 5mm allen wrench and slightly unscrew the Overflow Plug (pic) and let any oil drain out, once it starts to drop, close it back up.
Does this sound about right?
Note 1: I also read that another option because i'm at 125k is to remove the pan completely, and clean the screen... then replace pan with a new gasket, and fill with the same above procedure.
Note 2: Then in another thread, they say to just drain the pan and refill like the procedure above, 3-4 times at 100 mile intervals to thin out the oil tranny fluid because their a full 12qt. in there. WTF?
Also, in the pic, is the arrow with the Fill Hole, correct? I can't find any pics of the damn bolt for the fill hole anywhere so I assume this is it.
What does this pan contain? It's not engine oil!-2-jpg
Old 03-12-2020, 12:55 PM #10
97BlackAckCL's Avatar
Real Name: Chris
97BlackAckCL is a splendid one to behold 97BlackAckCL is a splendid one to behold 97BlackAckCL is a splendid one to behold 97BlackAckCL is a splendid one to behold 97BlackAckCL is a splendid one to behold 97BlackAckCL is a splendid one to behold 97BlackAckCL is a splendid one to behold 97BlackAckCL is a splendid one to behold
Real Name: Chris
That's the blinker fluid reservoir
2017 Nautical Blue SR5 Premium - Black Emblem Overlays, AFE TB Spacer, AFE Momentum GT Intake, URD MAF Calibrator, Borla Touring Cat-Back Exhaust, Morimoto MLED 2.0 Headlight Retrofit, Morimoto Black LED Fogs, Eagle Eye Smoked Black Tail Lights, FyreFlys LED Interior, Meso Puddle Lights, Smoked CarTrim Mirror Turn Signals, Smoked Amber Raptor Lights, Odyssey 34 Battery, 32" LED Bar with Rago Hidden Brackets, Rago Molle Panels, Side Shooter LED Ditch Lights, sPod w/ PowerTray, Raceline Matte Bronze Wheels w/ Cooper Discoverer RTX, N-Fab Side Steps, BajaRack Full Length Roof Rack, 6 MB Quart Door Speakers, JBL 3.5's in dash, JL 8w3v3 in JBL Enclosure, Husky Weather Beaters, CanvasBack Liners, ScanGauge, Blackvue DR900S Dash Cams
Old 03-12-2020, 01:46 PM #11
spartacus's Avatar
spartacus's Avatar
-connect Techstream
you have them marked correctly in the pics. Keep in mind that if you dont want to do it
Transmission fluid service. At the dealer is like 200 bucks not bad if you ask me. Frustration when working on cars is inevitable but I just get a drink and a breather and then go at it.
Old 03-12-2020, 01:53 PM #12
spartacus's Avatar
spartacus's Avatar
@Runnin4MO this might help
https://www.youtube.com/watch?v=PPhiIxs0VQM&feature=youtu.be
Old 03-12-2020, 02:30 PM #13
Originally Posted by spartacus View Post
Exactly what i've been looking for. Thanks!
Old 03-13-2020, 08:17 AM #14
kenwilliams0803 kenwilliams0803 is offline
kenwilliams0803 will become famous soon enough kenwilliams0803 will become famous soon enough
I think it's more like $99 at my dealer whereas a brake flush is $199.
I've always done mine in the past and do it on all my other vehicles, but with no dipstick, and the whole trans temp. mode thing I just let them do it every 30-40k for $100.
kenwilliams0803 is offline   Reply With QuoteReply With Quote
Old 03-13-2020, 01:03 PM #15
Jivewalker's Avatar
Jivewalker Jivewalker is offline
Jivewalker is a jewel in the rough Jivewalker is a jewel in the rough Jivewalker is a jewel in the rough
Jivewalker's Avatar
There is a great post on here somewhere where a member did the same thing, except then dumped 7 new qts of oil in and backed out of his garage! Posted for help on here, couldn't figure out where his engine oil went. He had 14qts of engine oil in the engine and none in the transmission. Was good humor, it's an easy mistake.
2012 TE w/ KDSS, Black, 265/70R17 C KO2's, 195,000 miles
Inside Fishing Rod Holder Mod
"How can you shoot a poor innocent 3-legged cat?"
"Easy, you just don't lead him as much..."
Jivewalker is offline   Reply With QuoteReply With Quote
$#@ , damn , drain , oil , pan
Engine loud metallic engine rattle @1800 rpm after sitting in traffic protist 3rd gen T4Rs 5 08-17-2019 08:04 PM
Intermittent vehicle/engine shake and vibration with check engine light present lloydster 3rd gen T4Rs 26 09-26-2017 11:58 AM
Rough Idle, Engine Sputtering, Engine Ticking, Flashing CEL Sotovo 3rd gen T4Rs 29 04-18-2016 10:35 PM
Engine,VSC,ABS and Brake lights on, no codes, engine running rough chd2001 4th Gen T4Rs 2 04-22-2014 12:14 PM
Engine swap Question..does L6 engine fit into 1990 Hilux/4runner hjalti_gto Classic T4Rs 29 11-28-2011 09:34 AM
