Old 03-14-2020, 10:24 AM #1
tflux tflux is offline
tflux is on a distinguished road
Do the tires on a Limited have to be the exact same size?
1) Does toyota recommend/require all 4 tires (on the full-time 4wd, i.e., Limited models) to be within a certain tire diameter spec?
(I know subaru does with their AWD system. Meaning, if you have 30,000 miles on all 4 of your tires and 1 tire gets ruined, you are supposed to buy 4 new tires so the tire diameters are the same.)
I didn't see any mention of this in the 4runner manual, but I read somewhere on this forum that you should keep the tire diameters the same (like the subaru).
Thanks!
2015 4Runner SR5 4x4 White (sold)
2019 4Runner Limited 4x4 Silver
tflux is offline   Reply With QuoteReply With Quote
Old 03-14-2020, 10:53 AM #2
Cndnmax Cndnmax is offline
Cndnmax will become famous soon enough Cndnmax will become famous soon enough
The reason you change all the tires on an AWD car is due to the way their traction control systems work. The whole “send power to the wheel with traction” thing gets confused when different wheel spins faster/slower.
Although, If you’re using 3 bald tires and one new one you could see unwanted results on any car.
Here’s The manual recommendations:
● Do not mix tires of different makes, models or tread patterns. Also, do not mix tires of remarkably different treadwear.
●Do not use tire sizes other than those recommended by Toyota.
●Do not mix differently constructed tires (radial, bias-belted or bias-ply
tires).
●Do not mix summer, all season and snow tires.
●Do not use tires that have been used on another vehicle.
Cndnmax is offline   Reply With QuoteReply With Quote
Old 03-14-2020, 12:33 PM #3
BobsTrail's Avatar
BobsTrail BobsTrail is offline
Real Name: BobH
BobsTrail is a name known to all BobsTrail is a name known to all BobsTrail is a name known to all BobsTrail is a name known to all BobsTrail is a name known to all BobsTrail is a name known to all
BobsTrail's Avatar
Real Name: BobH
Subaru is crazy to recommend buying all 4. There are tire shops that will shave a new tire to match the wear of the existing ones for cases like this.
BobsTrail is offline   Reply With QuoteReply With Quote
Old 03-14-2020, 01:30 PM #4
Whippersnapper02's Avatar
The Limiteds have a Torsen limited slip center diff and because of it you most definitely need to have the same diameter size tires all around or you'll burn up the center diff. Any 4wd AWD vehicle should have the same diameter size all around.
Old 03-14-2020, 01:43 PM #5
You can have one tire slightly different thread without the center diff noticing anything. The point is that 4wd (part time or full time) doesn’t care about minor differences (by minor i do not mean bald or different size tires). AWDs traction systems are much more sensitive to different wheel speed and is the reason why the tolerance is so small.
Old 03-14-2020, 01:53 PM #6
llDemonll llDemonll is offline
llDemonll is a glorious beacon of light llDemonll is a glorious beacon of light llDemonll is a glorious beacon of light llDemonll is a glorious beacon of light llDemonll is a glorious beacon of light
i don't know exact specs but subaru and mitsubishi say no more than ~1/8" diameter difference between tires.
i would expect toyota awd is about the same
llDemonll is offline   Reply With QuoteReply With Quote
Old 03-14-2020, 03:27 PM #7
03_4x4Runner's Avatar
03_4x4Runner 03_4x4Runner is offline
03_4x4Runner has a spectacular aura about 03_4x4Runner has a spectacular aura about 03_4x4Runner has a spectacular aura about
I would think there are a lot of limiteds out there that the owners do not check there tire pressure very often. I would think one tire being 4 psi lower than the others would cause more of a diameter difference than one tire with the tread worn more. My experience with the torsen diff on my old 4th gen and my 5th gen limited is not to worry about it. The torsen diff handles it just fine. If it could not we would only be able to drive on perfectly straight roads with no curves so the tires always went the same speed. Where I live it is hard to find straight road other than the interstate highways. Zero issues in 17 years with torsen diffs.
03_4x4Runner is offline   Reply With QuoteReply With Quote
diameters , limited , subaru , tire , tires
FS: 5th Gen: 5 Full Size 2017 Limited Wheels and Tires - Southern California bbcrusher For Sale: Suspension/Wheels/Tires 1 07-20-2017 03:53 PM
What size tires do you put in your limited? Tuferlife 5th gen T4Rs 2 01-07-2015 09:56 PM
FS: 2011 Limited Tires and Full Size Spare LocoTaco For Sale: Suspension/Wheels/Tires 1 06-12-2012 07:18 PM
anyone know what size tires are on 99 4R Limited? airbag 3rd gen T4Rs 8 07-06-2006 11:34 AM
