Old 03-14-2020, 02:55 PM #1
shrub1's Avatar
shrub1 shrub1 is offline
shrub1 has a spectacular aura about shrub1 has a spectacular aura about
shrub1's Avatar
Weboost Antenna Install help..and done.
Does anyone know of a mount or bracket that can be fitted to the stock roof crossbar that I'd be able to adapt a ram mount to that would support the Weboost antenna (the big black one).
shrub1 is offline   Reply With QuoteReply With Quote
Old 03-14-2020, 03:27 PM #2
4Reak Show's Avatar
4Reak Show's Avatar
I install a good amount of WEboosts on RVs at work and have used a lot of varying bracketry depending on orientation. Number one useful material is 1/8" thick angle aliminum; 1 or 1-1/2" depending. It's strong, light, doesn't rust and is easy to work with and cut and drill and such. And cheap. Like 3' stick from Home Depot is under $10 and then you can do whatever your mind wants to visualize. Depends how creative you wanna be I guess.
Old 03-14-2020, 03:43 PM #3
shrub1's Avatar
shrub1's Avatar
Thanks for the reply, but I was hoping to come across a clamp (wondering if a Yakima clamp will work) that I could attach to the oem crossbar that I could then in turn attach a ball ram mount to and then secure the antenna to that.
How has the feedback been with the Weboosts you've installed?
Old 03-14-2020, 10:38 PM #4
shrub1's Avatar
shrub1's Avatar
Does anyone know of a CB antenna mount that fits the oem roof rail channel?
That might work.
Old 03-14-2020, 10:53 PM #5
Bugser's Avatar
Bugser Bugser is offline
Real Name: Bob
Bugser will become famous soon enough
Bugser's Avatar
Real Name: Bob
Lots to chose from:
Diamond antennas
Comet antennas
Amazon had Chinese knockoffs
I use the Rago hood mount for my 2meter ham radio antenna. That’s a great mount
2018 TRD ORP, MGM, Xpel 35% Tint, Xpel Clear Bra, In-Dash 2m/70cm Icom Radio, Dual-band 1/4 wave antenna with Rago Mount, sPod Bantam, 2 x 32" behind the grille LED lightbars, Cali Raised 3-way Fog Lights.
Sold: 2011 SR5
Bugser is offline   Reply With QuoteReply With Quote
Old 03-15-2020, 11:59 AM #6
shrub1's Avatar
shrub1's Avatar
Originally Posted by Bugser View Post
Lots to chose from:
Diamond antennas
Comet antennas
Will give those a look. Thanks.
Old 03-15-2020, 01:03 PM #7
4Reak Show's Avatar
4Reak Show's Avatar
Oh ok I see.
From what I hear, people are satisfied. I think it helps a lot to amplify an existing cell signal. It's not a miracle cure, but I've heard good things overall. The one we use a lot doesn't require any set up or anything either.
Old 03-15-2020, 02:50 PM #8
shrub1's Avatar
shrub1's Avatar
Oh ok I see.
I've got a bead on a couple mounts that may work.
Yeah, I don't expect to garner a signal where there is no service, just boost from 1X to 3G or perhaps even 4G with two/three bars.
Old 03-18-2020, 04:24 PM #9
keph13 keph13 is offline
keph13 is on a distinguished road
I put two holes in my roof for NMO cell antennas. I'm working on getting a modem up and running to talk to them, but I'll make a post about the outcome at some point. I'm hoping the ground plane will make a big difference in reception.
2010 4Runner SR5 4x4
keph13 is offline   Reply With QuoteReply With Quote
Old 03-19-2020, 09:12 PM #10
shrub1's Avatar
shrub1's Avatar
Soft install done. Roof mount didn't work out very good so I went with a hatch mount that I had to modify a little bit with the bench grinder. Turned out good. Instructions reflect that head of antenna needs to be above roof line. I will move the antenna up if need be in the future. I drove to a spot today that has anywhere between 1X and NO SERVICE for reception. With the Weboost on I got LTE 3/4 bars. Impressed. Real test next week when i head to Bishop area for a few days.
Weboost Antenna Install help..and done.-img_5193-jpg  Weboost Antenna Install help..and done.-img_5192-jpg
Old 07-08-2020, 08:12 PM #11
Hamburgerpimp's Avatar
Hamburgerpimp Hamburgerpimp is offline
Hamburgerpimp will become famous soon enough
How did this end up working out when you went to Bishop?
2014 4runner Trail, KDSS, 6112's w/King 650# springs, 5100, 295/70/17 DuraTrac, 4.88 Nitro Gears, Harrop Front E-locker, ToyTec 2.0 rear springs, Metal Tech Sliders, Full RCI STEEL skids, Prinsu Rack, C4 Fab Fuel Tank Skid, C4 Lo Pro bumper with High clearance, X20 winch, ARB Twin Compressor, Northstar 27F, Precision LED conversion, NoCo onboard charger, Icon Delta Joint UCA's, Dobinson's Rear Drawers.
1989 4Runner: All Stock
Hamburgerpimp is offline   Reply With QuoteReply With Quote
adapt , antenna , mount , ram , weboost
Mounting WeBoost Antenna on Gobi Stealth? moshie 5th gen T4Rs 2 07-05-2020 10:03 AM
Prinsu Rack & Cellular Signal Booster | WeBoost 4G-X OTR youngwas 5th gen T4Rs 0 01-06-2019 04:51 PM
Antenna install fishingjude 3rd gen T4Rs 1 06-30-2015 08:42 PM
Firestik CB Antenna Install Snooperstyle 5th gen T4Rs 9 09-10-2013 12:42 AM
