03-16-2020, 10:14 AM
Cons of 255/75 Tire ?
Looking for those with long term experience (6mts+, not just the honeymoon phase) of a 255/75 on stock 5th gen no lift. On road use, not offload. Yes the visual look gets you 32 but at what cost. Ride quality, steering stability at highway speed, bump steer, drift, transmission hunting or feeling funky? Heavy truck on tall skinny tires sometimes feels like it might tip/roll easier? Just looking for what others have experienced. And whether they stuck out the 255s forever or went back to stock 265/70. Thanks
03-16-2020, 11:40 AM
Might find your answer here;
255/75/17 KO2 Pizza Cutters
2015 Magnetic Gray SR5P
03-16-2020, 11:46 AM
I'm running 255/75/17 Goodyear Duratrac's in an SL load rating on the wife's 5th gen Limited. Truck is mostly stock (cornfed 1" front spacer, 1.25" wheel spacers, on FJ Cruiser wheels), XREAS suspension, no extra weight. We've had the tires on for over a year now.
I had many of the same concerns, this is a P-rated sidewall (the only sidewall option in this tire size for Duratracs), and I was concerned they would feel squirmy with that much light duty sidewall. There have been no negative attributes to this tire for our on-road use, great traction in the winter, feel great on on/off ramps, and look great.
'93 Toyota LandCruiser VX Ltd 4.2TD - 3X e-lockers, winch, factory fridge, 285/75/16E Duratracs, ICON Stage 1 3" lift, GTurbo Grunter Extreme
'04 Lexus GX470 Ultra Premium - Dobinsons 2F/1R lift, Tandem 612's w/ 265/70/17 Wildpeaks, XD HID lows
'15 Lexus GX460 - FJC 6-spokes w/ 265/65/17C Duratracs Weathertech HP & Canvasback liners
'15 4Runner Limited - 1" Cornfed level, 255/75/17SL Duratracs on FJC 8-holes, XD HID lows, Sprint Booster, Canvasbacks & Husky Liners - SOLD
'96 Toyota Hilux Surf SSR-G 3.0TD RIP - 265/75/16C Duratracs, '99 tall fronts, OME 906's rear
03-16-2020, 11:50 AM
I’m not going to run spacers, so I’m losing .5 width on each side / total of 1” less width running track. Spacers negate that by helping you gain track width back but have their own risks I don’t want to run into.
03-17-2020, 07:31 AM
Running the Duratracs as well. A bit of noise (compared to a true highway tire). Other than that, no negatives.
2019 TRD OR Premium. Dobinsons extended travel, Goodyear dura-trac 255/75's, pro wheels, sliders.
03-17-2020, 08:47 AM
A narrower surface on rock will give you less traction and you will not be able to air down as much.
2017 Off-road Premium w KDSS, moon roof, sliding rear cargo deck,3" Toytech Boss lift, SPC upper control arms, Sonoran Steel High Articulation KDSS Trac/PanHard Bar, RCI sliders, RCI skid plates aluminum including gas tank, C4 Fab diff skid plate, SCS Ray 10 Wheels Matte Gray, 285/70R17 Hankook Dynapro AT2 RF11 E-load RWL, Cali Raised LED 3x2 fog-light pods, Lock'r Down EXxtreme console safe with electronic lock, Auto Heat Shield all windows, Raingler rear cargo net, Canvasback rear covers, LFD Off-Road cross bars aluminum, LFD Hybrid bumper, LFD wind fairing, LFD Hi-lift jack mounts, Goat Armor, Blackgate Custom KDSS spacers, Ironman 2.5 awning with quick release mounts, Ironman 12,000 lb synthetic line winch.
03-17-2020, 09:18 AM
I have always thought this was interesting regarding tire width:
https://www.youtube.com/watch?v=9h3T_QicRqg
03-17-2020, 10:37 AM
I ran these tires before I had the wheel spacers as well, the tires didn't handle any differently, but it sure looks a lot better with the wheel spacers.
03-18-2020, 07:59 AM
Thanks. Decided to stick with stock size and save $200 by not having to buy a 5th tire spare. Went with Bridgestone Revo 3's
