Old 03-16-2020, 04:51 PM #16
ForRun's Avatar
ForRun ForRun is offline
ForRun is a name known to all ForRun is a name known to all ForRun is a name known to all ForRun is a name known to all ForRun is a name known to all ForRun is a name known to all
ForRun's Avatar
Will this be available as a package deal when the fully adjustable fronts are ready to go?
ForRun is offline   Reply With QuoteReply With Quote
Old 03-16-2020, 05:00 PM #17
DigitalAviatorZ DigitalAviatorZ is offline
DigitalAviatorZ is on a distinguished road
How easy are these to adjust while on the truck?
DigitalAviatorZ is offline   Reply With QuoteReply With Quote
Old 03-16-2020, 05:10 PM #18
Ryan at Eibach's Avatar
Ryan at Eibach Ryan at Eibach is offline
official vendor
Ryan at Eibach is a glorious beacon of light Ryan at Eibach is a glorious beacon of light Ryan at Eibach is a glorious beacon of light Ryan at Eibach is a glorious beacon of light Ryan at Eibach is a glorious beacon of light Ryan at Eibach is a glorious beacon of light
official vendor
Yup!
2019 TRD Off Road
2007 GT3
1982 911 SC
Ryan at Eibach is offline   Reply With QuoteReply With Quote
Old 03-16-2020, 05:37 PM #19
Jetboy's Avatar
Jetboy Jetboy is offline
Jetboy's Avatar
What is the range of adjustment? - ie what is the minimum lift height?
Old 03-16-2020, 05:48 PM #20
FoRunnuh FoRunnuh is offline
FoRunnuh is on a distinguished road
If you get the 200lb. Load range, and have a 200lb load in the back, the minimum lift is 1.5" if I'm reading this right (based on the website):
Load Capacities & Height Ranges
200 lbs/in Loaded Height Ranges
Additional Weight Lift at Full High
0 lbs 2.0"
100 lbs 1.75"
200 lbs 1.5"
250 lbs/in Loaded Height Ranges
200 lbs 2.5"
300 lbs 2.25"
400 lbs 2.0"
300 lbs/in Loaded Height Ranges
400 lbs 2.5"
500 lbs 2.25"
FoRunnuh is offline   Reply With QuoteReply With Quote
Old 03-16-2020, 07:29 PM #21
Keith M Keith M is offline
Keith M is on a distinguished road
My question as well. I pull a boat a few times a year. It would be great to be able to make a quick adjustment before towing.
30 years of 4runner ownership and counting. #1 1987-2001, 220k, #2 2001-2017, 215k, #3 2017 Off Road 50k, #4 2020 ORP. I'm done.
Keith M is offline   Reply With QuoteReply With Quote
Old 03-16-2020, 08:06 PM #22
ForRun's Avatar
ForRun's Avatar
Same here. Be awesome to jack it up off the ground and adjust. I don't tow heavy loads often but would be great as an option. Not really wanting air bags, I read many say the ride is harse
Old 03-16-2020, 11:24 PM #23
ForRun's Avatar
ForRun's Avatar
Forgot to ask, does this come with a spanner wrench or is one available?
Old 03-17-2020, 09:56 AM #24
kvincef kvincef is offline
kvincef is on a distinguished road
those rear bumpstops going to be available seperate?
kvincef is offline   Reply With QuoteReply With Quote
Old 03-17-2020, 10:10 AM #25
Jetboy's Avatar
Jetboy's Avatar
0 lbs 2.0"
100 lbs 1.75"
200 lbs 1.5"
200 lbs 2.5"
300 lbs 2.25"
400 lbs 2.0"
400 lbs 2.5"
500 lbs 2.25"
The heights are just an adjustment for the extra weight, not the adjustment range of the coil seat. With 200lb/in springs, every 100lb of extra cargo will drop the springs about 0.25". There's 2 springs, and each spring moves 1 inch for every 200lb, so if you add 400lb, it drops 1 inch. They're just providing the basic math of spring rate vs load. The measurements tell us the max height I believe - but not the minimum height or the range of adjustment. Visually it looks like about 1" or 1.5" of height adjustment. So my guess is that you can go anywhere from 0.5 to 2" height adjustment with the 200lb springs, and then down from there based on additional load.
All of the springs are probably the same unsprung height. That's why the stiffer springs sit higher with the empty 4Runner.
Old 03-17-2020, 11:21 AM #26
official vendor
official vendor
It's very easy. Jack the car up and use the spanner to go up or down. Probably takes less than 5 minutes a side. I've done it multiple times on my own rig.
2019 TRD Off Road
2007 GT3
1982 911 SC
Old 03-17-2020, 02:27 PM #27
mark@eibach's Avatar
mark@eibach mark@eibach is offline
mark@eibach will become famous soon enough
Yes, it comes with two adjuster tools, one for the perch and one for the base.
mark@eibach is offline   Reply With QuoteReply With Quote
Old 03-17-2020, 02:39 PM #28
Jetboy Nailed it with response below...
So to clarify... the adjuster is 1.5" of height adjustment, so:
Unloaded height of system - 1.5" = minimum installed height.
for example: 200lb kit - 1.5" = +0.5" lift at max low setting with no load.
does that help?
Old 03-17-2020, 03:29 PM #29
Jetboy's Avatar
Jetboy's Avatar
does that help?
Just what I wanted to know. Thanks!
Old 03-17-2020, 09:39 PM #30
ForRun's Avatar
ForRun's Avatar
does that help?
Sorry long day and can't get this. so 200lb rear adjustable unloaded gives how much lift when all the way down? I see 1.5 and 1.5+0.5.
I'm looking to do 1" rear passenger and 1.5 drivers (for the lean)... is that possible? thanks
eibach , lbs , load , seat , spring
Adjustable Height Lift - Suggestions? carlodonz 5th gen T4Rs 5 11-07-2019 11:35 AM
Why no adjustable height suspension? elemint 5th gen T4Rs 21 09-19-2015 08:37 AM
Ahh ... Height control and adjustable tail end height? coconutpete 4th Gen T4Rs 3 02-26-2013 11:49 AM
FS: Height Adjustable Bilsteins with Eibach Springs ASSEMBLED - 4500 miles. ATL4R For Sale: Suspension/Wheels/Tires 6 10-09-2012 01:41 PM
Factory rear leveling system allirunner Engines / Suspension / Wheels / Tires / Audio / Accessories 13 08-22-2005 05:05 AM
