Originally Posted by FM8706
looks like a $135.12 disadvantage to me.
But seriously the TC is a uni ball and the SPC is a ball joint. Ball joint will be less maintenance and most likely longer lasting. The TC has urethane bushings and the SPC has rubber. Urethane would generally be considered better. I believe the SPC allows for a bit more caster adjustment. The other differences are subjective.
