Originally Posted by DannyLlama
Bump ...... can't figure out which parts need to be replaced? Just the struts or the entire assembly? Does anyone replace and have info?
I believe only the struts needed to be replaced, unless you need to replace the attached parts on the hood and fender.
I also need to replace the ones on my 2010. I found the OEM part numbers, 534500W190 (Left) and 534400W230 (Right). There are also aftermarket ones for cheaper, like Strong Arm Lift Support. I may just stick with the OEM ones, since they lasted 12 years.
