Old 03-22-2020, 08:12 PM #1
sparkyy192 sparkyy192 is offline
sparkyy192 is on a distinguished road
c1407 code - speed sensor harness?
So I got a lift on my 5th gen and shortly after had an issue with the rear right shock which was replaced by the same mechanic that did the lift.
Shortly after that, my dash lit up like a christmas tree. Pulled the code and got C1407 Open or Short Rear Speed Sensor RH
Since the sensors between front and back are interchangeable, I swapped the right front and rear sensors and went for a drive. Still same code, so I assume the sensor is fine.
This leads me to believe the harness itself was stretched during the lift, maybe broken somewhere.
My question is, what do I do now? How Do I test the harness? I can see the wire from the sensor go along the rear axle and up into the body of the vehicle, but where does it connect? Where do I test it, and has anyone replaced the harness themselves?
Thank you!
sparkyy192 is offline   Reply With QuoteReply With Quote
code , harness , lift , rear , sensor
Broken ABS Speed Sensor Harness Fix tjhaf2007 4th Gen T4Rs 21 12-30-2019 04:31 PM
ABS Wheel Speed Sensor - Rear Harness joemaritime28 4th Gen T4Rs 4 09-03-2019 12:13 AM
ABS speed sensor/harness or Zero Point calibration???? Help please. Jgonz 5th gen T4Rs 37 01-12-2018 04:55 PM
Wheel speed sensor/wheel speed sensor harness replacement Elan_ 4th Gen T4Rs 1 01-03-2018 07:57 PM
4th gen speed sensor harness (drivers side) tjhaf2007 For Sale: T4R Items 4 06-15-2013 10:31 AM
