Old 03-22-2020, 11:25 PM #1
fubarovich fubarovich is offline
fubarovich is on a distinguished road
Damage from shifting to 4lo while in D/P?
Hi, had a senile moment earlier today while trying to shift the transfer case knob from 4H to 4L/N with the transmission in D/P instead of N on my 2019 ORP, the vehicle was stopped with foot on brake. There were some buzzing noises coming from the transfer case shifter and a deeper grinding noise coming from down below. I must have tried 3-5 times before realizing that the transmission shifter needs to be in Neutral. Can someone tell if how much if any damage was done? thank you
fubarovich is offline   Reply With QuoteReply With Quote
Old 03-22-2020, 11:37 PM #2
patkelly4370's Avatar
patkelly4370 patkelly4370 is offline
patkelly4370 is a splendid one to behold patkelly4370 is a splendid one to behold patkelly4370 is a splendid one to behold patkelly4370 is a splendid one to behold patkelly4370 is a splendid one to behold patkelly4370 is a splendid one to behold
I did the same when I first got mine (in November).
Everything seems to still function properly despite my best efforts to mess it up.
patkelly4370 is offline   Reply With QuoteReply With Quote
Old 03-22-2020, 11:50 PM #3
Jetboy's Avatar
Jetboy Jetboy is offline
Jetboy's Avatar
I'd guess none. The gears are pretty robust. If they're not synchronized or stopped they won't mesh. They'll just grind and not engage. Usually the ends of the teeth will be beveled a bit so they just sort of bounce off. You're not the first or the last to do that.
Old 03-22-2020, 11:55 PM #4
JLTD JLTD is offline
JLTD has a spectacular aura about JLTD has a spectacular aura about JLTD has a spectacular aura about
Shouldn't be an issue… If you're worried, you can replace the transmission fluid.
Between outfits.
JLTD is offline   Reply With QuoteReply With Quote
Old 03-23-2020, 06:46 AM #5
BadTrainDriver BadTrainDriver is offline
BadTrainDriver will become famous soon enough BadTrainDriver will become famous soon enough
Originally Posted by JLTD View Post
Shouldn't be an issue… If you're worried, you can replace the *transfer case fluid.
Fixed for ya!
BadTrainDriver is offline   Reply With QuoteReply With Quote
Old 03-23-2020, 08:41 AM #6
jhguth jhguth is offline
jhguth is a splendid one to behold jhguth is a splendid one to behold jhguth is a splendid one to behold jhguth is a splendid one to behold jhguth is a splendid one to behold jhguth is a splendid one to behold
as long as you weren't pushing against the grinding trying to force it in it should be fine
jhguth is offline   Reply With QuoteReply With Quote
Old 03-23-2020, 09:40 AM #7
Originally Posted by BadTrainDriver View Post
Fixed for ya!
Shit. Thanks!
Between outfits.
Old 03-23-2020, 04:54 PM #8
BobsTrail's Avatar
BobsTrail BobsTrail is offline
Real Name: BobH
BobsTrail is a name known to all BobsTrail is a name known to all BobsTrail is a name known to all BobsTrail is a name known to all BobsTrail is a name known to all BobsTrail is a name known to all
BobsTrail's Avatar
Real Name: BobH
When I did that to mine, members told me I was just taking the sharp edges off of the gears and it will work better now. No problems years later
BobsTrail is offline   Reply With QuoteReply With Quote
Old 03-23-2020, 10:40 PM #9
DAW89446's Avatar
DAW89446 DAW89446 is offline
Real Name: Dave
DAW89446 is a glorious beacon of light DAW89446 is a glorious beacon of light DAW89446 is a glorious beacon of light DAW89446 is a glorious beacon of light DAW89446 is a glorious beacon of light DAW89446 is a glorious beacon of light
DAW89446's Avatar
Real Name: Dave
I’ve done that a few times myself. Even went as far as starting to drive off. The truck just drove off, no noise or conniptions, but I also caught sight right away the dash light blinking. So far no issues. I’m sure Toyota built in a few fail safes for exactly this occurance.
Dave
2018 4Runner SR5
2012 Subaru Outback Premium
DAW89446 is offline   Reply With QuoteReply With Quote
Old 03-25-2020, 01:25 PM #10
Blu42's Avatar
Blu42 Blu42 is offline
Blu42 is on a distinguished road
Blu42's Avatar
Well when you're running a switch for the transfer case you're less likely to have an issue. I think what he's talking about is the manual lever transfer case. He basically attempted to yank the gears into place which just isn't possible with the electronic shifter. Driving is doable with the knob because nothing happens if the truck is not in the proper gears first. It throws a blinking light to let you know that you have goofed.
2007 SR5 4WD Driftwood Pearl Totaled 2018
2014 Trail Premium with KDSS - Nautical Blue
Blu42 is offline   Reply With QuoteReply With Quote
case , damage , shifter , transfer , transmission
shifting from 2wd to 4wd James5354 5th gen T4Rs 17 04-18-2015 05:29 PM
Rear Ended, Hitch Receiver Damage --> Frame Damage? osuchasenuts 3rd gen T4Rs 5 12-01-2010 08:16 PM
Shifting into 4WD Nefy 5th gen T4Rs 3 11-14-2010 11:17 PM
Shifting down plumr 4th Gen T4Rs 11 03-03-2008 02:06 PM
shifting in 4LO c12ashhh 4th Gen T4Rs 3 12-09-2005 06:08 PM
