Old 03-26-2020, 08:32 PM #16
sn_85's Avatar
sn_85 sn_85 is offline
sn_85 is a splendid one to behold sn_85 is a splendid one to behold sn_85 is a splendid one to behold sn_85 is a splendid one to behold sn_85 is a splendid one to behold sn_85 is a splendid one to behold sn_85 is a splendid one to behold sn_85 is a splendid one to behold
sn_85's Avatar
Here's my setup. Blue Sea Below Deck Panel wired from an always on ST Blade fuse block hooked up to my aux battery.
Rear12 volt outlet question-blue-sea-below-deck-jpg
2016 Nautical Blue Metallic Trail | SCS | Falken Wildpeak AT3/W | Icon CDCV | Heftyfab Front Bumper | 4x4 Labs Rear | Shrockworks Sliders | RCI Skids | Warn VR10S | OGE Dual Battery System | sPOD | Katzkin
2013 Blizzard Pearl LE 4WD - SOLD!!!
sn_85 is offline   Reply With QuoteReply With Quote
Old 03-27-2020, 03:55 PM #17
jp.vegas jp.vegas is offline
jp.vegas is a glorious beacon of light jp.vegas is a glorious beacon of light jp.vegas is a glorious beacon of light jp.vegas is a glorious beacon of light jp.vegas is a glorious beacon of light jp.vegas is a glorious beacon of light
Originally Posted by Rack View Post
The tray on the PS can be removed without breaking the screw tabs. Use a flexible screwdriver adapter lift the tray just high enough to guide the Phillips tip flexible head to the screws once your on the screw it break loose in a couple of turns. You can see in the photos in my album I used a plastic pudy knife and pry up on the tray. The tray will go back in but I would not try to reinstall the screws because you will occasionally need to get back in. use some Velcro.
Ok so it gets pried up a considerable amount and then you get in there with the flexible adapter to remove the screws before the tray comes all the way out? I'll have to source one of those as I don't currently own one.
Also, what a friggin weird design that is. Wonder why they brothers with the screws when the rest of the interior is nothing but tabs and snaps.
'20 Army Green 4Runner TRD PRO
'16 Quicksand Tundra TRD PRO Gone
'08 Salsa Red Pearl 4x4Runner SE V6:
Gone
jp.vegas is offline   Reply With QuoteReply With Quote
Old 03-27-2020, 06:37 PM #18
Rack Rack is offline
Rack has a spectacular aura about Rack has a spectacular aura about
Yes you could pry it up till it breaks and hope it breaks in the right place.
I just don't roll that way.
I didn't know what other damage would happen.
try Harbor freight for the flexible adapter and trust me it won't be the last time you use this tool.
Click on my album page, my full write up is in there with photos.
signature not available
Rack is offline   Reply With QuoteReply With Quote
Old 03-27-2020, 08:29 PM #19
????? ????? is offline
????? will become famous soon enough
If you don’t feel like making a permanent modification to your vehicle this will work
Amazon.com: BESTEK 300Watt Pure Sine Wave Power Inverter Car Adapter DC 12V to AC 110V with 4.2A Dual Smart USB Ports: Electronics
And here is a test and report of the inverter as well
https://www.youtube.com/watch?v=_MnbfC88TBE&feature=youtu.be
This is the route I’m going to power the fridge through a separate solar battery bank in the rear.
????? is offline   Reply With QuoteReply With Quote
Old 03-28-2020, 09:12 AM #20
jhguth jhguth is offline
jhguth is a splendid one to behold jhguth is a splendid one to behold jhguth is a splendid one to behold jhguth is a splendid one to behold jhguth is a splendid one to behold jhguth is a splendid one to behold
You're powering a fridge with an inverter? That's a really bad idea, inverters are terribly inefficient and will waste power, keep it 12v for the fridge
jhguth is offline   Reply With QuoteReply With Quote
Old 03-28-2020, 10:11 AM #21
BlakeA BlakeA is offline
BlakeA will become famous soon enough
He may be doing what I am doing. Not wanting to make permanent mod, I’m using a Jackery solar generator (battery) charged by the 12 volt outlet in the back. I then have the Dometic fridge plugged into the Jackery (12 volt outlet).
I could also charge the Jackery using the 110 volt inverter in the back, but would have to remember to push the dash button every time I restarted the engine, hence my using the 12 volt side. Not sure why he would need to buy a separate inverter.
BlakeA is offline   Reply With QuoteReply With Quote
Old 03-28-2020, 06:48 PM #22
Yeah, I've been looking at your album. Thanks for that by the way, nice to see how that all worked out. Image 14 and 15 are the ones prompting the questions about how much you lift the tray prior to being able to get the flexible head in there and see what needs to come out.
Gone
Old 03-28-2020, 09:03 PM #23
That is correct.
Hobotech did a video on the Jackery 1000 and found the inverter charges the unit faster compared to a standard car plug.
Old 05-21-2020, 12:15 AM #24
Tj900 Tj900 is offline
Tj900 is on a distinguished road
@Rack I looked at your album (Thanks!) I was able to pry up tray but for life of me I cannot find the screw I am supposed to take out. Anyone have any pics or diagrams?
UPDATE: I found this thread that helps explain the rear tray tabs better: Rear Wheel Well Storage?
Tj900 is offline   Reply With QuoteReply With Quote
Old 05-21-2020, 11:11 AM #25
Here are some photos of how I removed the tray.
It may require a small mirror to locate the screws but they only take a couple of turns to remove them.
The photo of the tray shows the location of the taps where the screws are.
I used a fexable adapter on a 1/4" nut driver with a phillips head.
The screws are phillips head.
I was able to put my hand under the tray to guide the driver onto the head of the screws The tray will flex up enough to allow you to do this without breaking.
Rear12 volt outlet question-img_6199-jpg
back , opening , outlet , panel , rear
115 volt AC Power Outlet BenSD Engines / Suspension / Wheels / Tires / Audio / Accessories 15 09-21-2023 01:59 AM
fusible link 94 volt question panzertank27 Classic T4Rs 2 03-28-2013 12:44 PM
12 Volt outlet Not Working nytefog 4th Gen T4Rs 2 01-31-2013 11:19 PM
Rear 12 volt outlet icefisher 4th Gen T4Rs 1 01-19-2013 05:19 PM
12 volt tap question DonnyB Engines / Suspension / Wheels / Tires / Audio / Accessories 3 10-16-2007 08:52 PM
