Home Menu
Site Navigation
User Tag List
Reply
Thread Tools Rate Thread Display Modes
Old 03-24-2020, 07:33 AM #1
gearguywb gearguywb is offline
Member
gearguywb is on a distinguished road
Member
Rear12 volt outlet question
I have pretty much finished my storage drawers and plan on putting the fridge back there.
Originally planned to run a hot wire to the back and installing a Blue Sea panel. I would like to have a cover for the opening above the rear wheel well and mount the panel there, but I can fin anything that covers that opening.
Another option may be to convert the current 12v outlet in the rear to permanent power.
Has anyone done that? Thoughts?
__________________
2019 TRD OR Premium. Dobinsons extended travel, Goodyear dura-trac 255/75's, pro wheels, sliders.
gearguywb is offline   Reply With QuoteReply With Quote
Old 03-24-2020, 07:37 AM #2
adrtoy adrtoy is offline
Member
adrtoy is on a distinguished road
Member
That's what I did.
adrtoy is offline   Reply With QuoteReply With Quote
Old 03-24-2020, 09:07 AM #3
jhguth jhguth is offline
Senior Member
jhguth is a splendid one to behold jhguth is a splendid one to behold jhguth is a splendid one to behold jhguth is a splendid one to behold jhguth is a splendid one to behold jhguth is a splendid one to behold
Senior Member
The rear 12V outlet gets enough voltage drop that some fridges don't work well there, so if a fridge is your plan you'll want a dedicated outlet instead of making the existing one full time.
there have been users here that have made custom panels to fill in that area, but i don't know of off the shelf products
i just installed my dedicated 12v outlet beside the existing one
jhguth is offline   Reply With QuoteReply With Quote
Old 03-24-2020, 01:18 PM #4
Rack Rack is offline
Member
Rack has a spectacular aura about Rack has a spectacular aura about
Member
I installed a Blue sea switched 12volt outlet and usb ports on the PS fender well in the cargo area.
Rather than post it all here, Just go into my ALBUM PAGE I wrote the whole process up for others to reference .
__________________
signature not available
Rack is offline   Reply With QuoteReply With Quote
Old 03-24-2020, 02:10 PM #5
flyrv9's Avatar
flyrv9 flyrv9 is offline
Senior Member
flyrv9 is a jewel in the rough flyrv9 is a jewel in the rough flyrv9 is a jewel in the rough
Senior Member
flyrv9's Avatar
Also, all the A/C outlets (at least in the 2013) have no power when the truck is turned off. That's why people are wiring a separate outlet to a circuit that's always hot - and possibly an aux battery setup.
flyrv9 is offline   Reply With QuoteReply With Quote
Old 03-24-2020, 03:31 PM #6
jp.vegas jp.vegas is offline
Member
jp.vegas is a glorious beacon of light jp.vegas is a glorious beacon of light jp.vegas is a glorious beacon of light jp.vegas is a glorious beacon of light jp.vegas is a glorious beacon of light jp.vegas is a glorious beacon of light
Member
Did the tray over the wheel go back in? I've read that they're easy to damage when attempting to pull them out and the mounting tabs are typically busted.
__________________
'20 Army Green 4Runner TRD PRO
'16 Quicksand Tundra TRD PRO Gone
'08 Salsa Red Pearl 4x4Runner SE V6:
Gone
jp.vegas is offline   Reply With QuoteReply With Quote
Old 03-24-2020, 03:57 PM #7
PK930's Avatar
PK930 PK930 is offline
Member
PK930 will become famous soon enough
Member
PK930's Avatar
Not sure what fridge you'll be using, but the one I have would not stay on with the stock wiring ('12 SR5) -- voltage drop was probably too high. This is with the truck left running for a couple hours to test it out.
So I got a Blue Sea panel with 12v outlet, dual USB charging ports, voltage meter, and switch to turn the panel off. I ran a 10 gauge wire from the under hood Blue Sea fuse box all the way back. All wiring at the panel is also 10ga which is tight but doable. There's also a 30a breaker before the panel.
I'll be switching the 12v for Anderson connectors soon as I don't like how the play is on the cigarette lighter style.
__________________
Something, something, something.
PK930 is offline   Reply With QuoteReply With Quote
Old 03-24-2020, 05:01 PM #8
Member
Member
Take a look at "powerlet" or "Hella" style plugs and outlets. I've been using them for more than 10 years for a mechanically secure connection for my fridge.
__________________
Gone
Old 03-24-2020, 07:41 PM #9
MyanRagahis's Avatar
MyanRagahis MyanRagahis is offline
Member
MyanRagahis will become famous soon enough MyanRagahis will become famous soon enough
Member
Quote:
Exactly why I added mine. Better for me to charge camera stuff when sleeping on trips than to try and load up on a bunch of powerbanks or something. I did think about getting something like a small goal zero or something similar but this will do fine.
__________________
YouTube
MyanRagahis is offline   Reply With QuoteReply With Quote
Old 03-24-2020, 10:31 PM #10
benhalleniii benhalleniii is offline
Member
benhalleniii is on a distinguished road
Member
Try this: Blue Sea/ OGE Auxiliary Power Outlet System with Voltmeter – Off-Grid Engineering
b
e
n
__________________
2017 TRD Off Road
benhalleniii is offline   Reply With QuoteReply With Quote
Old 03-25-2020, 02:11 AM #11
Sky Sky is offline
Member
Sky will become famous soon enough Sky will become famous soon enough
Sky Sky is offline
Member
I too like Anderson connectors but I don't want to be restricted if I need to plug in somewhere else that typically doesn't have them.
If you use the Blue Sea plugs with the Blue Sea outlets they lock in very securely.
__________________
2019 4Runner TRD Off Road Premium
2011 FJ Cruiser TRD
1974 FJ40 (wish I still had it)
Sky is offline   Reply With QuoteReply With Quote
Old 03-25-2020, 07:07 AM #12
Member
Member
Quote:
Originally Posted by benhalleniii View Post
That is exactly what I have.
__________________
Old 03-25-2020, 07:08 AM #13
Member
Member
I did not want to mount it on the DS (if I could help it) as my fridge will be mounted on the PS.
__________________
Old 03-25-2020, 07:16 AM #14
Member
Member
Thank you!!!
__________________
Old 03-26-2020, 06:57 PM #15
Member
Member
Quote:
The tray on the PS can be removed without breaking the screw tabs. Use a flexible screwdriver adapter lift the tray just high enough to guide the Phillips tip flexible head to the screws once your on the screw it break loose in a couple of turns. You can see in the photos in my album I used a plastic pudy knife and pry up on the tray. The tray will go back in but I would not try to reinstall the screws because you will occasionally need to get back in. use some Velcro.
__________________
Reply
Tags
back , opening , outlet , panel , rear
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
115 volt AC Power Outlet BenSD Engines / Suspension / Wheels / Tires / Audio / Accessories 15 09-21-2023 01:59 AM
fusible link 94 volt question panzertank27 Classic T4Rs 2 03-28-2013 12:44 PM
12 Volt outlet Not Working nytefog 4th Gen T4Rs 2 01-31-2013 11:19 PM
Rear 12 volt outlet icefisher 4th Gen T4Rs 1 01-19-2013 05:19 PM
12 volt tap question DonnyB Engines / Suspension / Wheels / Tires / Audio / Accessories 3 10-16-2007 08:52 PM
Powered by vBadvanced CMPS v3.2.2
Copyright ©2000 - 2024, vBulletin Solutions Inc.
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2024 DragonByte Technologies Ltd.
Feedback Buttons provided by Advanced Post Thanks / Like (Lite) - vBulletin Mods & Addons Copyright © 2024 DragonByte Technologies Ltd.
User Alert System provided by Advanced User Tagging (Lite) - vBulletin Mods & Addons Copyright © 2024 DragonByte Technologies Ltd.
Copyright © 2020
