08-08-2017, 04:43 PM
Water Tanks in Cargo Storage Systems ? // Frontrunner Water Tanks
Hi.
Question for those of you who have made / purchased cargo storage systems:
Are there any of you who have included a water tank as a part of the storage system? While there is available room on a roof rack, i want to avoid putting my potable water inside a plastic bin ("BPA-free" isn't as safe as advertised) which can and will likely heat up in the warmer months. I would like to be as space-efficient as possible and would thus want, also, to avoid losing any seating space.
Does anyone have experience with the Frontrunner Slanted Water Tank https://www.frontrunneroutfitters.co...ater-tank.html ?
The dimensions are 40" W x 14" L x 8"-6" (tapered) H. Of the 35" available depth of the cargo hold, I was entertaining the idea of building a box that would lie flush with the water tank, which would also be flush with the rear seats. This would theoretically leave, if my calculations are correct, about 27" of available space to fit the storage system. This makes it rather complicated, I think, as having a metre of drawer space gives both extra storage and some breathing room for refrigerators / coolers. My 65L Yeti, in this setup, wouldn't be able to fit (appx. 30.5" L) - and as my primary food storage bin, well, that sucks for me.
Frontrunner offers another system which could fit in my specific situation, however, at a slight loss to water capacity. Kinda stinks, but it seems like the most feasible option as of now?
They offer yet another option which fits in the leg-space of the rear seats, but that seems like a colossal waste of space. Defeats the purpose.
Are there any other water storage systems that you all could recommend? I've done a fair bit of research and I haven't found anything.
Would appreciate any feedback, suggestions, or other commentary.
Cheers!
Pasha
08-08-2017, 05:38 PM
Where are you planning to go? I prefer a filter and 5 gallons of water onboard unless I'm heading to remote desert areas. A filter is small and light. Water is bulky and heavy. I avoid carrying a lot unless I'm going to the desert. Just my $.02.
These are 2.5 Gallons each, and cost $3. They're available at every grocery store. They're recyclable and have a lot less risk of making you sick than your water tank that hasn't been cleaned well in 2 years and is full of god knows what kind of bacteria. If anything measure one of these and build a rack for as many as you think you'll need. I almost always carry one extra for hikers/backpackers/bicycles out in desert areas and refill their water too. Helps make for a better relationship. And they're cheap enough it's a group of hikers in a remote area it's easy to give them the extra container long as they agree to pack the container out.
08-08-2017, 05:45 PM
I struggled with this too - especially in terms of space efficiency. After thinking about it I went and built my own tank out of aluminum which holds approx 25 gallons that mounts to the frame where the spare tire used to be. If you're looking to hold a lot of water this may be the best solution for you.
08-08-2017, 09:19 PM
I'll end up doing Front Runner's roof rack mounted water tank, with a hitch mounted Water Port. The FRO 11 gal tank will serve to refill the 3 gallon pressurized Water Port tank.
08-08-2017, 09:22 PM
Real Name: Danny
Real Name: Danny
I use this - https://www.thewaterport.com/ and I am very happy with it..
The only down fall is its only three gallons, with two people its good for about three days. Depending on usage of course.
2010 LE > TE Conversion, Fox 2.5 DSC Front W/ Camburg BJ UCA's Fox 2.5 Resi rear W/ Icons. Method 701's, Cooper S/T Maxx 285/70/17. Shrockworks sliders. LLama Tales
Dual Battery Thread
08-08-2017, 11:42 PM
That is cool, how did you attach it?
08-08-2017, 11:57 PM
Real Name: Danny
Real Name: Danny
I used industrial sized zip ties, Home depot sells them. They come in handy in other situations too, on one of our trips, one of the other guys used the them to hold his sway bar in place after popping one of the sway bar links.
Anyway, the vendor also sells hitch mounts and his own rack mount. Great guy to work with. Follow him on IG and he puts out free shipping/20% off sales
Dual Battery Thread
08-09-2017, 12:42 AM
Real Name: Halko
Real Name: Halko
At $3 a pop it won't take long to hit the cost of a Rotopax, which is what I use for water. Can alway use a few drops of bleach after each use to kill anything in there. I doubt the two gallons of water you'd add costs much from the tap. Then there is the altitude issue, may not be an issue for most but my last two water storage solutions developed leaks because of it.
2011 Silver LE, 3rd row, 285 GY Duratracs, Elka remote with adjusters/Icon Overland springs, SPC UCA's, RCI skids, Shrockworks step slider with OE Trail rockers, CBI rear bumper, Indel B fridge, SPOD, and more...
Build link:
http://www.toyota-4runner.org/5th-ge...el-thread.html
08-09-2017, 01:10 AM
I've used these Scepter military water containers for years and haven't had a single problem. There's an o-ring sealed pressure release so it pours without glugging, I suppose you could use it to adjust for altitude as well. Use purified water if you want to avoid things growing in your water tanks.
Scepter Water Cans - Scepter Military Water Cans - Scepter Watre Cans for sale, Scepter Military Fuel Cans, Military Water Cans, MWC, (MWC), Scepter 2.5 gallon water cans, Scepter 5 gallon water cans, Scepter 10 liter water cans, Scepter 20 liter wat
08-09-2017, 01:16 AM
Yep, these fit perfect in the cupped side areas behind the wheel wells. Sometimes between grocery stops I cut holes in the tops and fill them up at a campground then duc-tape the top closed again. I've searched for another solution but have yet to find something that justifies the cost and space any of those solutions will occupy.
I'd love something like this that fit in that same area:
https://youtu.be/rmCBigYcVv0
08-09-2017, 10:20 AM
Real Name: Dave
Real Name: Dave
water jugs inside T4R
Originally Posted by Cymon
I have two of the 5 gallon version from REI. I find it's hard to lift 7 gallons into and out of the car. It's too heavy. But these are better than a large tank that's fixed in the cargo space. And you don't have to fill the 7 gallon jugs full, over 5 gallons.
I take the back seats out for camping and put the heavy water and recovery gear behind the front seats on the floor. There it's at the center of the car and down low.
2015 T4R Trail Edition w/KDSS. Baja Rack flat utility rack, Baja Rack ladder, WeatherTech floor mats, Demello rock sliders. RCI skid plates, Falken AT3W LT285/70R17 tires, ICON Stage 7 tubular 2" extended travel lift, ICON Rebound 17x8.5" 0 offset alloy wheels, Baxter Performance remote oil filter adapter. Side exit exhaust, 2nd recovery hook on rear frame corner, DIY wheel well liners with 1/4" neoprene rubber.
08-09-2017, 10:59 AM
Real Name: Michael
Real Name: Michael
Really like this idea! Do you have any diagrams or schematics?
2014 UnLimited
Shrockworks Winch Bumper, 5% Window Tint, Spyder Trax Spacers, Ramsey 9500, Toytec 3" lift, 3rd Row Seating, Entune Navigation, Yakima Skybox Pro 21, 275/65/20 Dura Tracs, Amsteel Synthetic Winch Line, Beaver Step, BMC Mod, MagnaFlow 14", Interior LED, Camelbak Metal Gear Full Rack To be continued......
08-09-2017, 02:54 PM
Oh yea, ARB makes an extended fridge slide as well. If you are or plan to run an ARB fridge with your storage system this could be an option, allowes you to carry among many things a 5 gallon water can behind your fridge. I run it with no complaints and fits a water container with the second row folded up.
http://www.arbusa.com/uploads/PDF/ne...ide_Retail.pdf
08-09-2017, 03:17 PM
I refill them fairly frequently. They aren't usually a one use item for me. But I don't clean em. At most I put some lemonade mix in - acid will keep them bacteria free for a after refill. They have nice, leak free spouts and are large enough for the filter hose. They aren't ideal for filing with a garden hose though.
I have one of these also, but I rarely use it. It's easier IMO to use the smaller ones. Easier to set on a small camp table and move around as needed. And 3 or so of them pack easier than 1 big cube.
Thread Tools |
Display Modes |
Rate This Thread |
Linear Mode
