Originally Posted by VBRover
That trim piece does pop off. I had a 2019 with the same issue which I sanded and painted, once dry I applied 3m clear tape where the trim contacts the paint to reduce the rubbing which I think accelerates the corrosion.
I did the same thing the month after I picked my 2021 up. The sharp edge on the bottom of the plastic trim tends to wear through the paint. I sanded the lower edges of the trim piece and added clear plastic clear bra material.
