Old 03-27-2020, 07:25 PM #1
Sky Sky is offline
Sky will become famous soon enough Sky will become famous soon enough
Sky Sky is offline
KYB strut mounts- may be counterfeit or ???
Ordered 2 of the SM5640 KYB strut mounts for my Eibach Pro lift kit.
They arrived today and hmmmm...the 2 mounts are different but in identical boxes though.
The one I am suspect of looks like it would work BUT>
The studs are 9.8 strength but the better looking one is 10.9 (stronger).
The supplied nuts have the same interior thread but the flange diameter and wrench size are smaller.
The rubber parts just look like lesser quality.
The one I think is genuine has a part number on the rubber spring seat- no number on the bad one.
The bad one has the greek letter Epsilon with an arc above it and below it and the registered trade mark stamp. A search of the US registered trademark database does not turn this up.
The suspect one has the part number SMT7921 on it- a search cannot find this number anywhere.
Bought at Advance Auto Parts, just got off chat with them- they said to take it to a store and swap it- uh no none of the AA's in my area carry this part- it must be ordered.
I just ordered 2 more- be interesting to see what I get. Once I sort this 2 of them will be returned.
Stay tuned!
2019 4Runner TRD Off Road Premium
2011 FJ Cruiser TRD
1974 FJ40 (wish I still had it)
Sky is offline   Reply With QuoteReply With Quote
Old 03-27-2020, 08:34 PM #2
rdruss's Avatar
rdruss rdruss is offline
Real Name: Ron
rdruss's Avatar
Real Name: Ron
Just replaced the KYB tophats in my 4th gen couple weeks ago. Something I ran into you might also: my originals had no rubber biscuit up inside the "hat", but the new ones have a 5/8" thick rubber biscuit molded in. So need to remove the lower rubber bushing off your shock, leave metal washer in place and install that way or your shock stud won't protrude enough through the hat for bushing/washer/nut on the top side.
Old 04-01-2020, 05:45 PM #3
Sky Sky is offline
Sky Sky is offline
Well the 2 replacement KYB top hats arrived- same lesser quality as the one I referenced in the 1st post of this thread. Weaker studs and undersized nuts.
If I get my stock struts off in time to be in the return window I may just use them with only 800 mi on them.
Then return all of the KYB stuff especially the 3 lower quality parts.
2011 FJ Cruiser TRD
Old 08-11-2023, 11:51 AM #4
slomatt slomatt is offline
slomatt is on a distinguished road
Apologies for resurrecting an old thread, but this is the only one that comes up if you search for SMT7921.
I recently ran into the same issue and reached out to KYB technical support to check if these are in fact real KYB parts. The set I received have the following part numbers on them:
  • SMT7921
  • SA2304 C
KYB responded quickly and confirmed that these are genuine KYB parts, and that the numbers we see match their internal stamping numbers.
Hopefully this helps others who run into this issue in the future.
slomatt is offline   Reply With QuoteReply With Quote
bad , number , ordered , part , strut
Getting strut mounts for my 5100s T4R416 4th Gen T4Rs 3 01-06-2020 09:35 AM
KYB or Monroe Strut Mounts? reelamin 3rd gen T4Rs 23 11-22-2019 10:07 AM
Question on strut mounts Calloway 3rd gen T4Rs 2 12-08-2014 01:30 AM
Need Pic of Stock Strut Mounts Alabamaguy 3rd gen T4Rs 3 09-28-2011 11:20 PM
