Old 03-28-2020, 01:33 PM #1
Photogr Photogr is offline
Photogr is on a distinguished road
Steering Issues
I’m in a lifted (3” Toytech Boss) 2014 TEP with KDSS. Yesterday I went for a short errand and found the steering randomly difficult. Almost as if one or both of the front tires was very low, which they weren’t. It’s a bit hard to describe, but I’ll do my best. It’s almost like a front wheel drive vehicle when accelerating and the steering wants to pull straight and you have to overcome that force when turning. Then it gets easier once you get past that force. Only in this case, it’s not just when trying to break it from going straight, but seemingly random when turning. It will fluctuate in difficulty throughout a turn and even when going back to straight. I don’t believe it’s following any particular pattern, meaning it’s seemingly random, though maybe not. For those who recall the days before power steering, it’s kind of like that only intermittent. I hear no unusual noise such as being low on power steering fluid and everything under the hood appears normal. No fluids of any king on the garage floor either. Anyone every run into anything like this before? Thoughts on what it might be?
Photogr is offline   Reply With QuoteReply With Quote
Old 03-28-2020, 03:20 PM #2
08TxRunner's Avatar
08TxRunner 08TxRunner is offline
08TxRunner is a jewel in the rough 08TxRunner is a jewel in the rough 08TxRunner is a jewel in the rough
08TxRunner's Avatar
Do the 5th gens have the same issues with the steering shaft u-joint that the 4th gens and Tacomas have? That might be something worth looking at.
08TxRunner is offline   Reply With QuoteReply With Quote
Old 03-28-2020, 04:17 PM #3
rdruss's Avatar
rdruss rdruss is offline
Real Name: Ron
rdruss's Avatar
Real Name: Ron
My thoughts too.
Old 03-28-2020, 04:28 PM #4
LandCruiser's Avatar
LandCruiser LandCruiser is offline
Real Name: Sparky
LandCruiser has much to be proud of LandCruiser has much to be proud of LandCruiser has much to be proud of LandCruiser has much to be proud of LandCruiser has much to be proud of LandCruiser has much to be proud of LandCruiser has much to be proud of LandCruiser has much to be proud of LandCruiser has much to be proud of LandCruiser has much to be proud of
Real Name: Sparky
What color is your PS fluid?
Mine was acting a bit wonky and I replaced it at 60k and it got better.
Colorado is really bad on fluids.
Old and (c)rusty.
LandCruiser is offline   Reply With QuoteReply With Quote
Old 03-28-2020, 05:46 PM #5
I had a power steering flush a few months ago, so I doubt that's it but I'll check the fluid color this afternoon or tomorrow. That just lead me to a thought though: are there zerk fittings anywhere on the steering shaft which could contribute to this type of problem?
Old 03-28-2020, 06:44 PM #6
flyrv9's Avatar
flyrv9 flyrv9 is offline
flyrv9's Avatar
Look for foam on your PS fluid reservoir. Also could you have a brake dragging?
Old 03-28-2020, 08:16 PM #7
Greydog's Avatar
Greydog Greydog is offline
Greydog is on a distinguished road
Greydog's Avatar
Sounds like the intermediate steering shaft is corroded and seizing up. Spray some penetrating lube in there are worth the steering wheel lock to lock. Then spray or lube with grease.
2019 TRD OffRoad - Fox w/Resi, 650lb Springs, JBA HD UCA, T12 Rear Springs w/DS 5mm Spacer, Odyssey 34R-PC1500T AGM w/Diode Upgrade and CTEK Monitor, NOCO battery charger wired to external port for shore power, Rago Hidden Winch Plate, Comeup Seal 9.5 RSI, RCI Sliders/ Skids, 285/70-17 Cooper AT3 XLT on Fuel Rims, Various LED upgrades, OE Engine Heater w/External Port, XenonDepot Low Beam HID & LED 3k Fogs, ScanGauge, Midland GMRS, Accessory Mount for iPad, mike and Inreach, iKamper Mini 3.0, Custom Kitchen/Cargo system, ARB 50Q, Goose Gear dual drawer, Wilco Solo Tire/Hilift/RotoPax Carrier.
Greydog is offline   Reply With QuoteReply With Quote
Old 03-28-2020, 10:43 PM #8
Jeremy556's Avatar
Jeremy556's Avatar
Mine was doing that a few months ago at 255k miles. P/S fluid looked fine, no bubbles, and I had been replacing it every 100k miles, no P/S pump noises. In my case, a new P/S pump fixed it.
Old 03-29-2020, 10:33 AM #9
TOYO74's Avatar
TOYO74 TOYO74 is offline
TOYO74 has a spectacular aura about TOYO74 has a spectacular aura about TOYO74 has a spectacular aura about
TOYO74's Avatar
Is your shift selector in 4WD ?
TOYO74 is offline   Reply With QuoteReply With Quote
Old 03-29-2020, 02:59 PM #10
I will, thanks. Unlikely the brakes, but anything's possible...
That's a bit beyond my mechanical capacity, unless someone can help with photo's.....I'll google intermediate steering shaft and see what I can find too, thanks.
I'm not familiar with a P/S pump going without making all kinds of a whining/grinding noises when turning, but based on your experience this seems the likeliest scenario so far. Do you recall what you paid to replace it?
No, 2WD for some time. With the snow of a couple weeks ago I was in 4WD and didn't experience any of these symptoms like they are today. So, I'm guessing this is not related to the problem for now. Thanks.
Old 03-29-2020, 11:42 PM #11
Jeremy556's Avatar
Jeremy556's Avatar
I wasn't either, I actually thought it was my steering rack bushings and was planning to replace the rack, but figured the P/S pump was a whole lot easier and cheaper, so gave it a shot, and it worked. $283.20 from Olathe Toyota
Old 03-31-2020, 08:17 PM #12
According to the mechanic, it's the lower steering shaft. Part ordered and will be replaced on Thursday. Close to double your pump unfortunately.
Old 07-23-2021, 03:34 PM #13
8024thGen 8024thGen is offline
8024thGen is on a distinguished road
I had the same issue and was just told $900 for a new intermediate shaft. I bought my 2015 5 months ago and have found nothing but rust issues. Thanks West Virginia
8024thGen is offline   Reply With QuoteReply With Quote
force , it’s , steering , straight , turning
Steering issues w/ UCA's TE! 5th gen T4Rs 4 08-04-2016 10:03 AM
steering/tracking issues 01thunder 3rd gen T4Rs 23 04-29-2016 05:03 PM
Steering issues..... outkast14 4th Gen T4Rs 9 07-15-2015 10:36 AM
Power steering issues fluffeh 3rd gen T4Rs 5 12-24-2012 12:07 PM
power steering issues the great him 3rd gen T4Rs 8 03-05-2012 10:51 PM
