Old 03-29-2020, 12:58 PM #1
feelingstoned's Avatar
feelingstoned feelingstoned is offline
feelingstoned is on a distinguished road
2020 TRD PRO Lift Kit/Spacers
I've already read multiple threads on this but no one seems to link any actual parts. I love the fox suspension right now but just want to run 275s, what front spacers and wheel spacers do you guys recommend? Everything online says "does not fit PRO models".
Sent from my SM-G975U using Tapatalk
feelingstoned is offline   Reply With QuoteReply With Quote
Old 03-29-2020, 02:15 PM #2
TRD PANTHER's Avatar
TRD PANTHER TRD PANTHER is offline
Real Name: BLACK TRD PRO
TRD PANTHER has much to be proud of TRD PANTHER has much to be proud of TRD PANTHER has much to be proud of TRD PANTHER has much to be proud of TRD PANTHER has much to be proud of TRD PANTHER has much to be proud of TRD PANTHER has much to be proud of TRD PANTHER has much to be proud of TRD PANTHER has much to be proud of
Look up Jason Burtman Industries. He is a vendor on this forum and carries them for all the Pros. Although my Pro is a 2018, I went with a 1.5/1” setup with 275’s and like it.
2020 TRD PRO Lift Kit/Spacers-0eb32343-42e5-4f51-a00c-3c83bbabdc25-jpg
TRD PANTHER is offline   Reply With QuoteReply With Quote
Old 03-29-2020, 02:26 PM #3
daytonaviolet's Avatar
daytonaviolet daytonaviolet is offline
daytonaviolet is a splendid one to behold daytonaviolet is a splendid one to behold daytonaviolet is a splendid one to behold daytonaviolet is a splendid one to behold daytonaviolet is a splendid one to behold daytonaviolet is a splendid one to behold
I have them too 2020 TRD PRO Lift Kit/Spacers. 2/1.5 on 2018 Bilstein TRD pro suspension.
Burtman Industries
daytonaviolet is offline   Reply With QuoteReply With Quote
Old 03-29-2020, 02:33 PM #4
Right on I checked him out and hes got good reviews. What tires are you guys running on the 2/1 setup? I dont wanna get rid of my TRD rims
Old 03-29-2020, 02:36 PM #5
Burtman Industries
Will the 2/1.5 setup require bigger shocks than the stock fox shocks in the front? And if so I would probably go with bilestine. Can you link the TRD pro bilestine? 2020 TRD PRO Lift Kit/Spacers
Old 03-29-2020, 03:11 PM #6
mcat707's Avatar
mcat707 mcat707 is offline
Real Name: MURDERED TRD
mcat707 has a spectacular aura about mcat707 has a spectacular aura about mcat707 has a spectacular aura about
mcat707's Avatar
I went with the 2/1.5 Cornfed spacer kit on my 2015 TRD Pro Bilstein suspension with 285/70/17 Falken Wildpeak MT’s. Had to trim down the fender lip edges with no other modifications done. Once this suspension setup blows out, I’ll probably upgrade to something else, but I expect it will last for years to come.
2020 TRD PRO Lift Kit/Spacers-7d3e4a44-5589-4b18-987b-f16a9e8c9fb0-jpg  2020 TRD PRO Lift Kit/Spacers-29f74d48-61b5-4357-8fe2-83e21d6d4f45-jpg
mcat707 is offline   Reply With QuoteReply With Quote
Old 03-29-2020, 05:01 PM #7
CRB Racing CRB Racing is offline
CRB Racing has a spectacular aura about CRB Racing has a spectacular aura about
TRD PRO 5th Gen
David @Cornfed is the best!
The 2/1 kit are listed for the 19/20 with Fox suspension.
I had 2/1.5 on my 19 and it felt good. Stiffened up the suspension a bit. It still was very compliant off road, but felt stiffer on the street (in a good way) with less body roll.
Fast forward to the 2020...
Installed the 2/1 kit on my 2020 TRDP.
The front feels stiffer than the 2019. Maybe because the 20 has different valving. At times the rear appeared to be slightly lower.
I have since installed a 1.5 spacer and like the way it looks better.
With 2/1, 285/70/17.
CRB Racing is offline   Reply With QuoteReply With Quote
Old 03-29-2020, 06:07 PM #8
If you have 19/20 pro with fox, i believe Burtman makes the leveling kit. Not need to change shocks to the older pro Bilsteins.
Old 03-29-2020, 06:10 PM #9
Originally Posted by mcat707 View Post
I went with the 2/1.5 Cornfed spacer kit on my 2015 TRD Pro Bilstein suspension with 285/70/17 Falken Wildpeak MT’s. Had to trim down the fender lip edges with no other modifications done. Once this suspension setup blows out, I’ll probably upgrade to something else, but I expect it last for years to come.
I had to do small mount of trimming as well as pushing the liners forward. The trimming is not visible unless you look for it.
Old 03-29-2020, 06:58 PM #10
mcat707's Avatar
mcat707's Avatar
I used rubber automotive door edge guards to cover the trimmed edges on the fender. Looks much cleaner to me. I didn’t have to push the liners forward
2020 TRD PRO Lift Kit/Spacers-0a6649c8-7aaa-478b-ba62-703afb2ac328-jpg  2020 TRD PRO Lift Kit/Spacers-5431d76c-4ccb-4ffc-a0d5-b05ecddb5cf8-jpg  2020 TRD PRO Lift Kit/Spacers-a9340cb3-dc0b-49e4-b598-826046c711b4-jpg
Old 03-29-2020, 08:34 PM #11
Love the set up! Do you have a link for the bilestines? And I suppose I can re use the same front coils if using different shocks? Oh and last question...link to Cornfed spacer kit? I want to compare prices 2020 TRD PRO Lift Kit/Spacers
Old 03-29-2020, 08:39 PM #12
T3XAS4Runner's Avatar
T3XAS4Runner T3XAS4Runner is offline
T3XAS4Runner will become famous soon enough
What headlights are those?? They’re awesome
Dobinson 3/2" Lift with UCA. Helo 17x9 + 285/70/17 KO2s
'18 Limited with Redwood leather
T3XAS4Runner is offline   Reply With QuoteReply With Quote
Old 03-29-2020, 08:40 PM #13
Um, why would you replace the Fox with Billies?
Old 03-29-2020, 08:42 PM #14
Wait sorry I already have the link to the last question
Old 03-29-2020, 08:43 PM #15
Well I dont want to but I thought it was required for the 2/1.5? If I don't, can I still run 285s?
275s , front , pro , spacers , wheel
2020 TRD Pro 1" Front Lift 4Hammer 5th gen T4Rs 29 03-27-2021 10:57 AM
Spacers on a 2020 TRD Pro dehoopta 5th gen T4Rs 40 05-13-2020 11:22 AM
FS:2020 TRD Pro Fox Suspension w/CornFed Spacers-Huntsville, AL-$1500.00 gSwift For Sale: Suspension/Wheels/Tires 2 01-24-2020 02:31 PM
FS: 2019-2020 TRD PRO Cornfed 2"/1" Spacers $125 shipped from Memphis, TN EM1Pete For Sale: T4R Items 5 01-19-2020 07:25 PM
