Old 09-23-2021, 12:27 AM #1
NWsuperwhiterunner NWsuperwhiterunner is offline
NWsuperwhiterunner is on a distinguished road
Por 15 rattle can
I have a brand new 4runner and am thinking about using some Por 15 rattle can as a preventive measure for rust. I do no live on the coast or the rust belt so i don't need any fluid film style under coat. Has anyone used this stuff before , or have any recommendations as to what to use ?
NWsuperwhiterunner is offline   Reply With QuoteReply With Quote
Old 09-23-2021, 05:31 AM #2
Matt831 Matt831 is offline
Matt831 will become famous soon enough
My suggestion.....POR 15 the welds on the frame then coat the chassis in Fluid Film or Wool Wax.
I would not coat a frame in POR 15 unless I had it out of the truck on a stand and 100% clean.
If the surface is not perfectly prepped and I mean spotless...POR 15 will flake off.
Matt831 is offline   Reply With QuoteReply With Quote
Old 09-23-2021, 06:04 AM #3
Tieyota Tieyota is offline
Tieyota is on a distinguished road
I haven’t made the time to get under the 4Runner, but I did this to my Tacoma. Honesty, all I did was clean up the welds and any spots showing metal or surface rust and used the liquid POR-15 with a brush as it is really easy to apply and no overspray. Having done an entire frame in it on another truck, I’d recommend against doing the entire thing and having a bunch of cans of Wool Wax, I really don’t like the oily coating over everything but some people seem to swear by it.
Tieyota is offline   Reply With QuoteReply With Quote
Old 09-23-2021, 02:53 PM #4
usdmej usdmej is offline
usdmej will become famous soon enough
Por15 only have their primer and top coats available in a rattle can and both of those require you properly prepare the surface you want to spray
i don't suspect it's going to be as easy and convenient as youre thinking
usdmej is offline   Reply With QuoteReply With Quote
Old 09-23-2021, 06:26 PM #5
Charlievee's Avatar
Charlievee Charlievee is offline
Charlievee is a name known to all Charlievee is a name known to all Charlievee is a name known to all Charlievee is a name known to all Charlievee is a name known to all Charlievee is a name known to all
Charlievee's Avatar
I have been down in the central "ssipp" for about three years and used fluid film rattle cans to coat the under carriage 6 months ago. Mostly in preparation for going back to a state that has winter. Did a nice thin coat and it covered well, looks great, simple to apply, but it does catch dirt and makes it messy when wrenching. Did my sliders with the POR system (cleaner, self etch, and primer) and wouldn't want to do it on the frame unless the body was removed. Just my .02.
2018 TRD Off Road Premium. Eibach Pro, JBA, Toyo's, TRD cai.
Charlievee is offline   Reply With QuoteReply With Quote
Old 09-23-2021, 10:53 PM #6
chester4Run chester4Run is offline
chester4Run is on a distinguished road
I e used por-15 on a couple projects and overall I’m not impressed. It forms a very hard, glassy looking finish, and I think this contributes to adherence problems. When metal flexes and the paint on it does not, the paint falls off. I’ve tried aspho treatment followed by marine grade primer with great results.
All of that said, I use rattle-can black paint on all my 4R frames, LCAs, axles, etc annually. I generally get a small amount of new rust each year, but the paint seals it well enough, is cheap/easy, and looks clean.
2011 SR5 4wd
2004 SR5 4wd
1994 SR5 4wd (SOLD)
chester4Run is offline   Reply With QuoteReply With Quote
Old 09-24-2021, 05:53 PM #7
Bmnorm2 Bmnorm2 is offline
Bmnorm2 is a jewel in the rough Bmnorm2 is a jewel in the rough Bmnorm2 is a jewel in the rough Bmnorm2 is a jewel in the rough
Avoid applying anywhere "visible" as POR 15 is not UV resistant. The clear stuff will yellow very quickly. I assume the black fades, but can't say for sure.
Bmnorm2 is offline   Reply With QuoteReply With Quote
fluid , por , rattle , rust , style
Rattle when truck is in Drive (rattle stops in park/reverse/neutral) ETXT4R 4th Gen T4Rs 2 12-19-2017 04:47 PM
what is my new rattle nyvram 3rd gen T4Rs 0 12-19-2013 02:37 PM
A/C rattle? rpearlberg 3rd gen T4Rs 1 12-02-2013 04:45 PM
2000 4Runner Rattle Rattle...help! UrsaAmericanus Problems & Warranty Issues 2 11-17-2004 04:52 AM
