Originally Posted by Gerh45
I will prob replace soon when needed. Is there any way to fix this noise prior to replacing pads?
Take everything apart and clean it. Lube the slide pins and use some sort of disc brake lube/quiet product on the back of the pads. If you are going that far though you might as well install new rotors and pads.
I use Sil-Glyde on the slide pins and Permatex 24115 on the back of the pads. I've never had any brake noise when using it. I don't think the 24115 stuff is still available nowadays though. It's a sticky dark gray grease. CRC has a similar looking product. I spread a thin layer on the back of the pads and it keeps them quiet.
If you do end up replacing your rotors & pads then I would suggest Akebono ProAct pads and Centric premium rotors. Both are good quality parts that aren't too expensive. An added bonus is the Akebono pads don't require any break-in procedure.
