Old 03-30-2020, 02:30 PM #1
Gerh45 Gerh45 is offline
Gerh45 is on a distinguished road
Brake noise at 58,000 miles
Hi folks,
I have a 2.5 year old 2019 4runner SR5 with 58,000 miles and have been experiencing brake squeak the past 5k miles. I drive about 28k miles per year 90% highway and bought it new. 3 weeks ago left took it for maintenance at dealer and told them about the noise. They told me rotors needed to be resurfaced but pads still had 40% left. So we resurfaced the rotor but noise did not stop. Any ideas how to fix this? Noise sounds loud first miles of the day but still sounds at other times. Should the pads make this noise even if they still have 40% left? Any suggestions?
Thanks, Gus
Gerh45 is offline   Reply With QuoteReply With Quote
Old 03-30-2020, 02:42 PM #2
spartacus's Avatar
spartacus's Avatar
My 2016 does that specially when it's wet or snow on initial drive once it's been driven for a while it's fine.The dealer doesn't think anythig of it, pads and rotors still good at 34k miles.
Old 03-30-2020, 04:15 PM #3
Crikeymike's Avatar
Crikeymike Crikeymike is offline
Crikeymike has much to be proud of Crikeymike has much to be proud of Crikeymike has much to be proud of Crikeymike has much to be proud of Crikeymike has much to be proud of Crikeymike has much to be proud of Crikeymike has much to be proud of Crikeymike has much to be proud of
Crikeymike's Avatar
Pads could be glazed over perhaps from getting too hot. I'd just go ahead and replace those, it's pretty easy to do.
Exit Offroad - Specialist in Dobinsons Suspension & Accessories
Dobinsons | RCI | Powerbrake | Long Range Tanks | Timbren | Overland Vehicle Systems
Youtube Channel | Email Directly
Been in the offroad industry since 1998. Born & raised in Australia - currently in Jax Beach, FL. 2014 4runner Trail, 3/2" Dobinsons MRA Suspension, Shrockworks bumper and sliders, M8000 w/ Treaty Oak winch line, LFD Roof Rails, Dobinsons 2m Awning, RCI skids
Crikeymike is offline   Reply With QuoteReply With Quote
Old 03-30-2020, 04:36 PM #4
LandCruiser's Avatar
LandCruiser LandCruiser is offline
Real Name: Sparky
LandCruiser has much to be proud of LandCruiser has much to be proud of LandCruiser has much to be proud of LandCruiser has much to be proud of LandCruiser has much to be proud of LandCruiser has much to be proud of LandCruiser has much to be proud of LandCruiser has much to be proud of LandCruiser has much to be proud of LandCruiser has much to be proud of
Real Name: Sparky
Mine started squeaking and never stopped. The pads and rotors are fine. Just ignore it if that's the case.
Old and (c)rusty.
LandCruiser is offline   Reply With QuoteReply With Quote
Old 03-30-2020, 05:06 PM #5
Dillusion Dillusion is offline
Dillusion is a glorious beacon of light Dillusion is a glorious beacon of light Dillusion is a glorious beacon of light Dillusion is a glorious beacon of light Dillusion is a glorious beacon of light
If they took the time to resurface should of just changed the pads at the same time.
They are not that expensive I'd just change them.
2018 TRD OFF ROAD
My Build
Dillusion is offline   Reply With QuoteReply With Quote
Old 03-31-2020, 04:47 AM #6
49Runner 49Runner is offline
49Runner will become famous soon enough
I changed mine at 53k, how do the pads look.
49Runner is offline   Reply With QuoteReply With Quote
Old 03-31-2020, 04:52 AM #7
Captsolo Captsolo is offline
Captsolo will become famous soon enough
Take it to a good brake shop.
Captsolo is offline   Reply With QuoteReply With Quote
Old 03-31-2020, 12:17 PM #8
The pads still have 40% left.
Old 03-31-2020, 12:25 PM #9
I will prob replace soon when needed. Is there any way to fix this noise prior to replacing pads?
Old 03-31-2020, 12:25 PM #10
Crikeymike's Avatar
Crikeymike's Avatar
Once a pad is "glazed over" from getting too hot, you need to replace it.
Fresh cut rotors should have also helped the situation by changing the contact area with the brake pads, but since that didn't work, you should just change the pads, and make sure the shims on the back are in proper place, or use "disc brake quiet". I use that stuff and never have had any brake noise.
Old 03-31-2020, 01:29 PM #11
Dynamo's Avatar
Dynamo Dynamo is offline
Dynamo has a spectacular aura about Dynamo has a spectacular aura about Dynamo has a spectacular aura about
Dynamo's Avatar
Take everything apart and clean it. Lube the slide pins and use some sort of disc brake lube/quiet product on the back of the pads. If you are going that far though you might as well install new rotors and pads.
I use Sil-Glyde on the slide pins and Permatex 24115 on the back of the pads. I've never had any brake noise when using it. I don't think the 24115 stuff is still available nowadays though. It's a sticky dark gray grease. CRC has a similar looking product. I spread a thin layer on the back of the pads and it keeps them quiet.
If you do end up replacing your rotors & pads then I would suggest Akebono ProAct pads and Centric premium rotors. Both are good quality parts that aren't too expensive. An added bonus is the Akebono pads don't require any break-in procedure.
2019 TRD ORP
Dynamo is offline   Reply With QuoteReply With Quote
Old 03-31-2020, 01:42 PM #12
nevada's Avatar
nevada nevada is offline
nevada has a spectacular aura about nevada has a spectacular aura about nevada has a spectacular aura about
nevada's Avatar
absolutely. I would question everything that dealer does, if they intentionally neglected to change the pads when the rotors were resurfaced.
1985 pickup: EFI 331/4r70W-Dana 300-42 TSL SXII's/raceline beadlocks-30spl longs-5.29's-spools-sky Hi steer-OBA/4g tank-10.5k RR winch-dual blue tops-200 amp alt-flatbed.
1985 4runner sr5: 22RE/5spd-6" pro-comp suspension-37 BFG at's-5.29 gears-Badlands Basher bumper-8.5k RR winch.
2006 4runner v8 limited: stock. Build Thread YouTube Channel
nevada is offline   Reply With QuoteReply With Quote
brake , left , miles , noise , told
2016 SR5 Rear Differential Noise after 10K miles 4Rman 5th gen T4Rs 38 11-20-2020 03:48 PM
WTB: 3rd gen brake booster with low miles Tucson4runner For Sale: T4R Items 4 08-02-2016 01:08 AM
Brake Noise? MayorBloom 5th gen T4Rs 4 03-15-2016 12:39 AM
Loud noise after 100K miles Vincegf General Discussions 3 02-18-2015 05:35 PM
Brake noise abyen 4th Gen T4Rs 1 08-22-2007 06:01 AM
