Old 04-11-2020, 12:47 AM #1
UTKSmokey's Avatar
UTKSmokey UTKSmokey is offline
UTKSmokey is on a distinguished road
UTKSmokey's Avatar
Ceramic brakes and the effect on crawl/traction control
I need to get some new brakes. I am an OEM-ist, provided cost isn’t insane. Akebono comes with a whole lot of high praise and so do the OEM’s. Cost is the same (Since local dealer didn’t want to price match online and shipping made it null) and brake dust & noise have not been an issue.
Also there are 2 different part #s for the oem, one one the car at purchase and the one installed if they do maintenance? Why? Are they accounting for test drives?!!
My inference is that oem is semi-metallic & Akebono ACT is ceramic (correct me if I’m wrong about oem). Through my research the pros and cons of each are there & it’s a toss up with trade offs either way.
So I was going to go with Akebonos, but I had a thought and can’t find any info on how the change in material affects the traction/crawl control. Does it screw with the programs that control those systems? Do they adapt?
Google ain’t been my friend. Anybody have some thoughts or directions toward informative material?
UTKSmokey is offline   Reply With QuoteReply With Quote
Old 04-11-2020, 01:05 AM #2
00Sebby's Avatar
00Sebby 00Sebby is offline
Real Name: Mark
00Sebby is just really nice 00Sebby is just really nice 00Sebby is just really nice 00Sebby is just really nice 00Sebby is just really nice
00Sebby's Avatar
Real Name: Mark
Metallic pads tend to have the best grip and provide the most grip without having to be warmed up. But most street ceramic pads have similar grip and warm up quickly, so that's not much of an issue. In a way, given how the crawl/traction controls work, the ceramic pads might be better on the rotors, last longer and resist heat fade longer with the constant brake pulsing.
As for the traction/crawl systems, they are only detecting wheel spinning and traction loss. So if a grippier steel pad stops the wheel from turning and it begins to slide, the ABS system will release the brake to restore traction. On the less grippy ceramic pad, all things being equal, the wheel will may continue to turn without engaging the system, at least until a bit more pedal pressure is applied and causes wheel lock up. Regardless, you get the same result. In a stop situation, slightly more brake pressure would be required for the ceramic pad before engaging ABS.
From a stop or on slick surface, the traction control/LSD senses the spin and applies as much brake force as necessary to stop it and send power to the wheel with traction. This is done without driver input and the system would not care what the pad type is.
I would go with the Akebonos. I've ran their ceramic pads on multiple vehicles and they work well. Less brake dust too.
Current: 2004 Land Cruiser Thundercloud Metallic
Former: 2020 ORP Silver. BFG AT KO2s, TRD Skid Plate, added Rear Sliding Deck, Pro LED fogs, Infinity REF-3032CFX dash speakers.
In Between: 2020 Jeep Wrangler Unlimited Rubicon with almost all options. Got tired of worrying about it disintegrating and ending up setting at the dealer for weeks and months.
Former: 2010 TE Silver w/ C4 Fab Rock Sliders, TRD skid plate, ECGS bushing upgrade, Bilstein 5100s, and BFG AT KO2 tires.
00Sebby is offline   Reply With QuoteReply With Quote
Old 04-11-2020, 01:16 AM #3
UTKSmokey's Avatar
UTKSmokey's Avatar
Thank you for filling in the gaps on that. I was thinking that way but wasn’t really sure if they physical interface would screw with the electronic. Thanks Boss!
brakes , ceramic , control , material , oem
Let me tell you about Crawl Control trayscool 5th gen T4Rs 16 11-16-2019 11:33 AM
20 mph crawl control? DreamsOfDirt 5th gen T4Rs 6 07-08-2018 10:34 AM
Crawl Control 4RunnerTrail 5th gen T4Rs 61 05-29-2018 12:19 AM
Just a Crawl Control Pic bernardmwrangle 5th gen T4Rs 5 08-01-2016 10:55 PM
Ceramic brakes WU7X 3rd gen T4Rs 5 12-20-2012 02:19 AM
