Old 04-01-2020, 09:40 AM #1
apache67 apache67 is offline
apache67 is on a distinguished road
Brake Replacement
Hi Guys,
Needing to do pads/rotors (all four wheels) on my 2015 Trail.
Are the pads the same front and back?
Amazon has Hawks LTS $65 a set. Any other vendors you might can recommend?
With rotors are there any upgrades to be had where the price-point is same/similar to factory replacements?
TIA!!
G
apache67 is offline   Reply With QuoteReply With Quote
Old 04-01-2020, 10:28 AM #2
Z4_marin Z4_marin is offline
Real Name: Chris
Z4_marin is on a distinguished road
Real Name: Chris
Pads are different front and rear. Go to the Toyota dealership and buy pads there.(in my opinion). Have you measured your rotors?
Z4_marin is offline   Reply With QuoteReply With Quote
Old 04-01-2020, 10:38 AM #3
Went with the Akebonos through Rockauto.
This Trail is the DD (95% the time on pavement).
Next question:
Any write-ups on brake/rotor replacement?
Cheers,
G
Old 04-01-2020, 10:51 AM #4
Charlievee's Avatar
Charlievee Charlievee is offline
Charlievee is a name known to all Charlievee is a name known to all Charlievee is a name known to all Charlievee is a name known to all Charlievee is a name known to all Charlievee is a name known to all
Charlievee's Avatar
Brake Pad upgrade? (stocks suck imo)
And wanderlost just posted a good how to on tubeyou.
2018 TRD Off Road Premium. Eibach Pro, JBA, Toyo's, TRD cai.
Charlievee is offline   Reply With QuoteReply With Quote
Old 04-01-2020, 11:14 AM #5
KF4R2011 KF4R2011 is offline
KF4R2011 is on a distinguished road
Wagner OEX carbon ceramic.
Front pads are WAY simple. 2 pads, two pins, 4 hairpin clips. Take you longer to get the wheel off than to replace the pads.
Rear pads are more involved... have to remove the whole caliper.
KF4R2011 is offline   Reply With QuoteReply With Quote
Old 04-01-2020, 11:34 AM #6
I am replacing the rotors as well, so all calipers have to come off.
The Wanderlost vid is excellent.
Thanks Everybody!
Cheers,
G
Old 04-01-2020, 02:47 PM #7
ProLee's Avatar
ProLee ProLee is offline
ProLee will become famous soon enough ProLee will become famous soon enough
ProLee's Avatar
I've always use OEM pads and rotors if needed. If you want to go after market I would check out Tirerack, they usually have the most options and the best prices.
I would also offer a word of advise, to get the best turn out of your old rotor have them do it on the truck (if it is still within spec) otherwise replace with OEM.
ProLee is offline   Reply With QuoteReply With Quote
Old 04-01-2020, 02:57 PM #8
Dynamo's Avatar
Dynamo Dynamo is offline
Dynamo has a spectacular aura about Dynamo has a spectacular aura about Dynamo has a spectacular aura about
Dynamo's Avatar
Good choice with the Akebono pads. They work great and don't require any break-in procedures.
For rotors I like Centric premium. Nice quality and not too expensive.
2019 TRD ORP
Dynamo is offline   Reply With QuoteReply With Quote
Old 04-02-2020, 02:54 AM #9
49Runner 49Runner is offline
49Runner will become famous soon enough
Why do you need new rotors?
49Runner is offline   Reply With QuoteReply With Quote
Old 04-02-2020, 03:59 AM #10
flyrv9's Avatar
flyrv9 flyrv9 is offline
flyrv9's Avatar
The Wanderlost video is good. However, I would do one thing they didn't mention. Whenever I do brakes I take the top off the master cylinder and then set it back on without hooking the bale. Doing this makes it easier to push the caliper pistons back in to make room for the new pads.
I usually use the old pad and either a pair of channel locks or a c clamp to push the piston back. This will push fluid back up the lines and into the master cylinder reservoir; so go slow so brake fluid doesn't spill out of the master cylinder because of the loose top.
Inspect everything: condition of the fluid, piston seals, line connections, etc.
If any brake fluid spills clean it up pronto. It will eat through paint in a heartbeat.
If you have a bad piston seal, it will obviously have to be replaced before you can continue. The hard part is getting the piston out of the caliper; as it's a tight fit around the seal. If you pry on it and scratch anything, it will cause a leak. Here is one way to get the piston out without damage. It will require removing the caliper from the vehicle.
With the caliper on the bench place something soft (like shop rags) in front of the piston. Then use an air hose with a nozzle to blow air into the hole the brake line screws into. The air pressure will force the piston out. Install new seal lubricated with brake fluid and then push the piston back in. You'll have to bleed the line after reinstalling the caliper. May end up having to bleed all the lines.
Old 04-02-2020, 09:19 AM #11
patkelly4370's Avatar
patkelly4370 patkelly4370 is offline
patkelly4370 is a splendid one to behold patkelly4370 is a splendid one to behold patkelly4370 is a splendid one to behold patkelly4370 is a splendid one to behold patkelly4370 is a splendid one to behold patkelly4370 is a splendid one to behold
I personally never do a "pad slap".
I always replace the pads/shoes, calipers/wheel cylinders, and any hardware. Also replace all the brake fluid. I replace rotors/drums as needed.
Yes, a bit more expensive. But it is done correctly and completely. I don't cut corners when it comes to my brakes where my family's (and yours) are at stake.
I was an auto mechanic for many years and I've corrected many shortcuts others made.
patkelly4370 is offline   Reply With QuoteReply With Quote
Old 04-02-2020, 01:37 PM #12
BobsTrail's Avatar
BobsTrail BobsTrail is offline
Real Name: BobH
BobsTrail is a name known to all BobsTrail is a name known to all BobsTrail is a name known to all BobsTrail is a name known to all BobsTrail is a name known to all BobsTrail is a name known to all
BobsTrail's Avatar
Real Name: BobH
In the past there were a lot of posts that recommended going with OEM pads and rotors due to the long life and good service. I have 64K on mine and they do not need to be changed yet.
When It's time, I'm going with OEM from a dealer, but do it myself plus a brake fluid replacement.
BobsTrail is offline   Reply With QuoteReply With Quote
Old 04-02-2020, 01:39 PM #13
LandCruiser's Avatar
LandCruiser LandCruiser is offline
Real Name: Sparky
LandCruiser has much to be proud of LandCruiser has much to be proud of LandCruiser has much to be proud of LandCruiser has much to be proud of LandCruiser has much to be proud of LandCruiser has much to be proud of LandCruiser has much to be proud of LandCruiser has much to be proud of LandCruiser has much to be proud of LandCruiser has much to be proud of
Real Name: Sparky
Colorado killed mine off by 60k miles. I was dumb and didn't change the brake fluid which looked like shit 10k miles later.
Old and (c)rusty.
LandCruiser is offline   Reply With QuoteReply With Quote
Old 04-02-2020, 04:30 PM #14
Elite130 Elite130 is offline
Elite130 is on a distinguished road
I just picked up all new rotors, pads, hardware, pins, etc. from Toyota.... I got 93,000 miles out of the OEM and decided to go all in with all new OEM Toyota stuff. The OEM worked great for me over the past 4 years and figured why do anything different. I'll be doing my brakes this weekend.
2016 4Runner Trail Premium...Delivered 1/22/2016. Mods: OME Lift, Husky WeatherBeaters, Interior/Exterior LED, Console Vault, AVS Hood and Side Window Deflectors, 275/70/17 BFG KO2, Rigid Dually SAE fog lights, Rigid 20" E2 Hyperspot, Garmin Dash Cam 55, ToyTec HIDs, Aiden James Saber Pro LED high-beam bulbs.
Elite130 is offline   Reply With QuoteReply With Quote
brake , recommend , rotors , upgrades , vendors
V8 Brake Pad Replacement bagelsjustbagels 4th Gen T4Rs 5 06-06-2019 12:08 PM
Brake Replacement MattB1 5th gen T4Rs 27 07-31-2017 07:29 PM
Brake pad replacement kai920 4th Gen T4Rs 14 12-22-2011 12:13 AM
Brake Pad Replacement wtn11 4th Gen T4Rs 4 12-19-2011 11:56 AM
Brake Pad Replacement drs.Datsyuk Maintenance/Detailing 6 02-05-2008 11:22 AM
