Old 04-01-2020, 04:46 PM #1
Drheim Drheim is offline
Drheim is on a distinguished road
Conflicting information on transmission oil change
I have a 2013 4runner at 100k miles. I called one large Toyota dealer and they said the transmission is universal sealed, or something like that, and it should never need the oil in it changed unless there is an issue. I called another Toyota dealer and they said it needs it($300). Do I need it? Opinions welcome
I looked through the maintenance manual and it is all over the place depending on how often you are off-road. I am on dirt roads maybe 5-6 times/year.
Drheim is offline   Reply With QuoteReply With Quote
Old 04-01-2020, 04:50 PM #2
spartacus's Avatar
spartacus's Avatar
Most here on the forum would recommend changing it including me.
Old 04-01-2020, 04:56 PM #3
spartacus's Avatar
spartacus's Avatar
helpful writeup
Transmission Fluid Change procedure
helpful video
https://www.youtube.com/watch?v=PPhiIxs0VQM&feature=youtu.be
Old 04-01-2020, 04:57 PM #4
LandCruiser's Avatar
LandCruiser LandCruiser is offline
Real Name: Sparky
LandCruiser has much to be proud of LandCruiser has much to be proud of LandCruiser has much to be proud of LandCruiser has much to be proud of LandCruiser has much to be proud of LandCruiser has much to be proud of LandCruiser has much to be proud of LandCruiser has much to be proud of LandCruiser has much to be proud of LandCruiser has much to be proud of
Real Name: Sparky
Do it.
Also do the t-case and diffs if you haven't already.
Old and (c)rusty.
LandCruiser is offline   Reply With QuoteReply With Quote
Old 04-01-2020, 05:01 PM #5
Muff Muff's Avatar
Muff Muff Muff Muff is offline
Muff Muff will become famous soon enough
Muff Muff's Avatar
A "sealed" unit is a misnomer, they have to get fluid in and out somehow. The notion that changing transmission fluid at "high mileage" causes damage is also incorrect, and shows that whomever propagates that myth doesn't understand how autos actually work. Long story short, changing your transmission fluid won't damage your transmission, but it could expose any slippage that was being masked by the old fluid. Old fluid -> more friction -> less slipping. New fluid -> less friction -> more slipping. Again, what causes the slipping is wear in the transmission, not a property of the fluid.
Have your fluid and filter changed. It may not be relatively cheap, but it will ensure your transmission lasts (at least) another 100k miles. There's no reason to believe your current fluid would be masking any wear-caused slippage in your transmission.
Muff Muff is offline   Reply With QuoteReply With Quote
Old 04-01-2020, 05:02 PM #6
Jetboy's Avatar
Jetboy Jetboy is offline
Jetboy's Avatar
There's no evidence I'm aware of that it has any value in prolonging the life of the transmission. You can look around and find that there are basically no failures. So... if it makes you feel better, go for it. It probably won't have any effect on the life of the transmission.
Unless you put the wrong fluid back in, which is farily common both on here and at dealerships. You want Toyota WS. Toyota WS is not backward compatible with T-IV, so if the bottle says it meets both standards, that's not possible. I mean that literally. They have different viscosity that are not overlapping, so one fluid cannot be both standards. Toyota WS is not expensive and there's no reason to use the wrong fluid.
Good luck.
called , dealer , oil , toyota , transmission
Some A750F transmission information kevwolford 5th gen T4Rs 4 01-03-2018 07:59 PM
TBU 231s: conflicting info, need clarification John7M7 3rd gen T4Rs 4 03-13-2017 08:54 AM
Conflicting Info about lift cowaggon 5th gen T4Rs 9 07-14-2011 10:13 AM
Transmission fluid change BadHabit Maintenance/Detailing 2 03-26-2005 04:46 PM
