04-02-2020, 01:00 PM
First 5th gen oil change - semi rant...
C'mon, man!
Toyota, you screwed up. Yeah, when doing oil changes on both my '90 4Runner (2nd gen) and my '00 4Runner (3rd gen), you had to remove the skid plate to get to the oil filter which was a real PITA. Then you wised up on my '08 4Runner (4th gen) and put the filter up high on the drivers side; easy peasy. I go to do my first oil change on my '19 4runner (5th gen) and not only am I removing the skid plate but there's another plastic facade piece that has to come off, too. That's nine bolts plus a push pin just to put your hands on the filter housing. Oh, and this new style filter housing with the o-rings and plastic drain piece (never had to drain an oil housing in addition to a drain pain before). You folks are smokin' something...
Yeah, I know that my Toyota Care offers x number of free oil changes and other minor things but I've been doing my own for over 40 years and between some horror stories I've read about ALL shops phukin' up AND me not wanting to sit in a waiting area with Coronavirus patients, I'll do this myself.
Rant over. I got some wrench time on my new truck and I stayed out of my wife's hair for 2 hours so it's all good...
Rick
'90 T4R - sold at 205,000 miles
'00 T4R - sold at 152,000 miles
'08 Sport - 178,000 miles & still going strong
'19 ORP - just over 6,000 mi. (garage queen, like my '07 Mustang)
04-02-2020, 01:03 PM
I'd be more thankful that they are protecting it.
2018 TRD OFF ROAD
My Build
04-02-2020, 01:07 PM
I agree with the OP... stupid design. They should have put in a removable window on the factory skid to get to it, then just design for a horizontal spin on filter.
04-02-2020, 01:10 PM
Real Name: MURDERED TRD
Any aftermarket skid plates that have a removable window for the oil filter? If not, here is something that someone or some company can come up with.
04-02-2020, 01:15 PM
Real Name: Sparky
Real Name: Sparky
Window is an inherent weakness. I think it's a dumb idea if your skids are actually used to skid over things.
Old and (c)rusty.
04-02-2020, 01:16 PM
RCI makes one with hatches for oil changes.
Engine Skid Plate | 10-Present 4Runner – RCI Off Road
04-02-2020, 01:18 PM
Toyota had to relocate it due to the dual VVT. Compare the pre and post dual VVT engines and you'll see why it had to be moved.
04-02-2020, 01:22 PM
Originally Posted by Blazephantom
Nice, never really looked into other skid plate options, but I’ll keep this one in mind.
04-02-2020, 01:32 PM
Real Name: BobH
Real Name: BobH
It's a pain, but I got used to it after 7 years with my old 2013 TE. I take my time and deal with it.
At least we don't have to hit a bunch of grease fittings. My other ride has 11 grease points and are a pain to reach but the oil change is easy.
04-02-2020, 02:19 PM
I got the RCI aluminum skid plate mainly for the ease of oil change, and I'm ok with that. I may need the skid plate in the near future for more skid-plate-like reasons, but in the mean time it makes my oil swaps much easier.
04-02-2020, 03:33 PM
It's a bit of a PITA to remove the plastic facade and skid plate but having a Dewalt 20V 3/8" impact makes it much easier. One of the best tools I've ever had.
2019 TRD ORP
04-02-2020, 04:03 PM
I use a Milwaukee cordless 3/8 ratchet when I do my oil changes. The TRD Pro skid plate is fairly lightweight but without a car lift and my aching aging body, it’s a chore to lift it up and bolt it back up while laying on the ground.
04-02-2020, 04:13 PM
Yeah it's a PITA for sure...but as stated you get used to it. I'm doing mine once a year or so with a high quality filter made to go the distance.
Don't forget the anti-seize on the bolts when you put it back together....
Between outfits.
04-02-2020, 04:26 PM
Real Name: Ben
Real Name: Ben
I've enjoyed doing my own services, and really don't mind it so much after the first one. I use a couple of ramps to get some room. I coated the skid plate bolts with antiseize to keep them working good. I got rid of the plastic push button on the front plastic piece. I use a 1/4" DeWalt 12V gun to zip everything off, and snug back on. Added a Fumoto drain for the oil, which will take a bit longer to drain out but is much nicer than dealing with an oil drain plug. And I also have the socket and drain tool for the filter housing off Amazon from MotiveX. The drain tool threads right up in so you can drain out the oil without making a bigger mess using the plastic tool.
Yes, it's more than a quick job. But I don't mind the time spent pampering my ride, and solitude in the garage
1992 3.0 Auto - First Project -Sold-
1995 3.0 Manual - Second Project - Sold-
2018 TRD ORP Barcelona Red
04-02-2020, 05:05 PM
yes, several.
