Old 04-02-2020, 02:17 PM #1
406 4runner 406 4runner is offline
406 4runner is on a distinguished road
Steering weird after lift and alignment
Hey everyone!
So I am hoping to get some input on my rig. I installed the Bilstein 6112 at the highest setting and netted about 2.5" after the most current alignment.
I also installed Dirt King UCA's
The alignment tech is a friend so he tried to dial it in per the specs I gave him- mainly that I wanted as much caster as possible while keeping everything else in spec..
I am running Nitto RG's in a 285 70 17 on Icon compression 8.5 wheels with 0 backspace..
Currently I have Icon rear 2.0 shocks and 52700 rear springs installed- but am switching to dobinson medium load since I have too much sag after I loaded up all my gear..
anyhoo- here is where I am needing input. The steering feels somewhat darty especially in rutted roads. Just kind of unpredictable unless the road is perfectly smooth and there is no wind.
It almost feels like the sway bars are fighting themselves- which leads me to wonder if I need need to install aftermarket end links or address them in some other way.
Has anyone else had the same issue? Look over my alignment specs and see what ya'll think
Steering weird after lift and alignment-4runner-alignment-specs-jpg
406 4runner is offline   Reply With QuoteReply With Quote
Old 04-02-2020, 02:53 PM #2
LandCruiser's Avatar
LandCruiser LandCruiser is offline
Real Name: Sparky
LandCruiser has much to be proud of LandCruiser has much to be proud of LandCruiser has much to be proud of LandCruiser has much to be proud of LandCruiser has much to be proud of LandCruiser has much to be proud of LandCruiser has much to be proud of LandCruiser has much to be proud of LandCruiser has much to be proud of LandCruiser has much to be proud of
Real Name: Sparky
If you're sagging in the end, your weight distribution may be all jacked up.
Old and (c)rusty.
LandCruiser is offline   Reply With QuoteReply With Quote
Old 04-02-2020, 03:12 PM #3
Thats a good point- my frame is about a half inch lower in the back right now..
Old 04-04-2020, 12:19 AM #4
Dbentley's Avatar
Dbentley Dbentley is offline
Real Name: Dillon
Dbentley is on a distinguished road
Dbentley's Avatar
Real Name: Dillon
My steering felt a little off after lifting my 4Runner as well....put a set of Kings on and during the install I noticed my rear sway bar links were angled towards the rear. I knew they needed to be replaced because of torn boots but did some research and found that even with lift kits you’ll still need to consider replacing your sway bar links with aftermarket sway bar links to get the feel good articulation you’re looking for. I noticed my cross axle flex felt rather shallow and cornering center of gravity felt high compared to what I though would be normal. I got a full set from a member (mike) that makes asjustable links, and the articulation now matches my suspension lift. Can really tell while fully loaded, and cornering feels way more grounded. My two cents, but hope it helps some....also noticed you’re going with dobinson rear springs, and I know they have some rear adjustable links. They could shed some light on the issue. Anywho, links to the adjustable links mike makes and sells below.
Sway Bar Links - Eugene, OR
Dbentley is offline   Reply With QuoteReply With Quote
alignment , feels , icon , rear , specs
Weird clunk after alignment Runn4est 4th Gen T4Rs 5 02-02-2017 12:51 PM
weird fender and door alignment raynyc Classic T4Rs 4 08-13-2016 05:54 PM
Steering wheel alignment off after body lift -prior to having it aligned. tehCoop 4th Gen T4Rs 7 10-01-2013 08:59 AM
Steering Wheel Alignment w/ Steering Column UncleOOPS 3rd gen T4Rs 2 07-13-2012 04:17 PM
Weird *dragging* after 5100 suspension install and alignment Border411 Engines / Suspension / Wheels / Tires / Audio / Accessories 0 11-30-2010 08:27 AM
