Old 04-03-2020, 03:03 AM #16
patkelly4370's Avatar
patkelly4370 patkelly4370 is offline
patkelly4370 is a splendid one to behold patkelly4370 is a splendid one to behold patkelly4370 is a splendid one to behold patkelly4370 is a splendid one to behold patkelly4370 is a splendid one to behold patkelly4370 is a splendid one to behold
Originally Posted by Rondigs View Post
I had the same experience. After my last “free” oil change, I did my first oil change at home. I swear they put that housing on with an impact wrench. I broke one of the tabs off the plastic housing getting that thing off... Now I need to come up with a replacement.
I did see a Dorman metal replacement filter housing at O'Reilly's.
patkelly4370 is offline   Reply With QuoteReply With Quote
Old 04-03-2020, 03:45 AM #17
Banned
Real Name: Mark
ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future
Banned
Real Name: Mark
You’d be better off getting a genuine Toyota part. Others have had leaking problems with aftermarket replacements. I paid around $28 for mine on Amazon.
Old 04-03-2020, 08:34 AM #18
mcat707's Avatar
mcat707 mcat707 is offline
Real Name: MURDERED TRD
mcat707 has a spectacular aura about mcat707 has a spectacular aura about mcat707 has a spectacular aura about
mcat707's Avatar
Originally Posted by pDubs View Post
Bought my 4runner used from a dealer who had just changed the oil. 6k miles later I go to do the first oil change myself and the oil filter must have been torqued to 150 ft lbs. Breaker bar wasn’t budging it. Eventually I snapped the oil filter wrench on my 1/2” breaker bar, had to order another filter wrench. Take 2 resulted in finally breaking the housing loose but cracking it. That’s the only reason I went metal, was $25 on Amazon with 1 day shipping at the time and the truck was stuck in the garage.
OP I noticed same thing. Threading it in until the o ring starts making contact is easier to spin. Been 3+ years and ~40k miles later and zero issues.
They probably didn’t lube the large rubber Oring when they installed the plastic housing.
mcat707 is offline   Reply With QuoteReply With Quote
Old 04-03-2020, 08:41 AM #19
nb rob's Avatar
nb rob nb rob is offline
nb rob is just really nice nb rob is just really nice nb rob is just really nice nb rob is just really nice nb rob is just really nice
nb rob's Avatar
Originally Posted by eelliiss View Post
Piggybacking off of this thread. Does anyone have difficulty removing the plastic drain extension from the aluminum housing? It's been tremendously difficult to insert and remove for me.
me too. It was easy with the plastic housing. It's a major pain with the dorman aluminum one I have now. I made a big mess last time
_______________________
2015 trail edition premium w/ KDSS
OPOR sliders ● 255/75/17 firestone destination AT ●
King coilovers and shocks w/ compression adjust ● Dirtking UCAs ● Icon 2" rear springs
nb rob is offline   Reply With QuoteReply With Quote
Old 04-03-2020, 09:31 AM #20
SparkySparks83 SparkySparks83 is offline
SparkySparks83 is on a distinguished road
Just did my first oil change (first one I've done, the rest were part of the free ones from Toyota) and I decided to switch to the metal housing. I tried the plastic drain in the metal housing before installing it just to see how it worked compared to the plastic housing and I had to nearly destroy the plastic plug to get it out of the metal housing. I ordered a Motivx drain to actual drain the oil from the filter housing and it was nice and easy to install, use and remove.
Amazon.com: Motivx Tools Oil Filter Wrench, Drain Tool, and Advanced Engine Oil Funnel Set for Toyota & Lexus 2.0L - 5.7L Engines with Cartridge Style Oil Filter Systems: Automotive
Oh and just an FYI, I picked up my OEM Metal oil filter housing from the dealership along with two filter and two washer with tax for $46 or $48 and had it the next morning, Amazon was several weeks out due to COVID-19!
SparkySparks83 is offline   Reply With QuoteReply With Quote
Old 04-03-2020, 10:14 AM #21
eelliiss's Avatar
eelliiss eelliiss is offline
eelliiss will become famous soon enough
eelliiss's Avatar
Good to know I'm not the only one. With my aluminum housing, I've resorted to removing the entire housing, disassembling, and then removing the plastic drain from the inside both times I changed the oil.
eelliiss is offline   Reply With QuoteReply With Quote
Old 04-05-2020, 11:33 AM #22
Dm3ga Dm3ga is offline
Dm3ga is on a distinguished road
I second the purchase of the motivx kit. It is very nice and should last more than the lifetime of the vehicle. The filter drain tool makes the job so much cleaner. I also installed the FUMOTO F103S LC-10 Lever Clip... Amazon.com: Fumoto F103S LC-10 Lever Clip FS-Series Engine Oil Drain Valve: Automotive
ref=ppx_pop_mob_ap_share
http://FUMOTO F103S LC-10 Lever Clip...p_mob_ap_share
Dm3ga is offline   Reply With QuoteReply With Quote
Old 04-05-2020, 03:15 PM #23
TheJokingExplorer TheJokingExplorer is offline
TheJokingExplorer will become famous soon enough
I swapped my housing out for the aluminum one but didn't change out the metal center from the plastic housing. Is it that big of a deal?
TheJokingExplorer is offline   Reply With QuoteReply With Quote
Old 04-05-2020, 03:33 PM #24
LandCruiser's Avatar
LandCruiser LandCruiser is offline
Real Name: Sparky
LandCruiser has much to be proud of LandCruiser has much to be proud of LandCruiser has much to be proud of LandCruiser has much to be proud of LandCruiser has much to be proud of LandCruiser has much to be proud of LandCruiser has much to be proud of LandCruiser has much to be proud of LandCruiser has much to be proud of LandCruiser has much to be proud of
Real Name: Sparky
Yes, it affects how the canister seats.
Old and (c)rusty.
LandCruiser is offline   Reply With QuoteReply With Quote
Old 04-05-2020, 04:12 PM #25
My aluminum housing seemed to fit just fine. I had zero issues installing it no leaks ect... I guess ill change my oil a little sooner and fix it.
Old 04-05-2020, 06:09 PM #26
SnowYeti's Avatar
SnowYeti SnowYeti is offline
SnowYeti is a jewel in the rough SnowYeti is a jewel in the rough SnowYeti is a jewel in the rough
SnowYeti's Avatar
I am doing the same thing with the Toyota metal housing in a week or two. Should make it a lot easier and cleaner to just run both tubes into the container
2019 ORP, 6112/5160, Eibach load leveling springs #250, Cornfed 1/2 in front spacers, JBA UCA, RCI alum skids, TRD Pro skid, TRD Pro grill, TRD Pro valances, Baja S8 30”, 3x Baja LP4 and Baja fogs, Rays 10, Toyo AT3 185/55, Canvasback, tinted windows, clear mask, UpTop Alpha rack w/ custom fairing, Borla, AFE CAI, URD MAF, Switch Pros, Power Trays, single ARB, rod vault, iKamper X-Cover, 23Zero 270 awning, Baja scene lights, Baja S2 rear fog/camp lights, RSG KDSS skid and sliders, Coco Mats, Ellis shift knobs, C4 ladder, Kenwood DNX696S/iData link, Morimoto XB Gen2, Morimoto Tails, custom 80/20 platform with slider, RokBlokz XL, WeBoost, C4 Low Pro w/ high clearance, Warn VR10 with Factor55, etc
SnowYeti is offline   Reply With QuoteReply With Quote
Old 08-03-2020, 10:14 AM #27
MidniteTRD's Avatar
MidniteTRD MidniteTRD is offline
MidniteTRD will become famous soon enough
MidniteTRD's Avatar
just attempted to install my OEM Toyota metal housing this weekend during a routine oil change, and with everyone else's success stories it seems like i'm "That Guy" who couldn't get it to work.
i noticed during installation like everyone else has mentioned; there was almost no resistance once the o-ring engaged the filter mount, the housing just bottomed out against the mount and that was it. the center tube was properly swapped, i lubed the o-ring and installed in the right channel, and it was torqued to spec. upon startup i had the presence of mind to leave the skidplates off and observe for any leaks. i immediately saw weeping around the housing-to-mount seam, and wiped it off. within 10 seconds it was filling up the seam with a thin line of fresh oil again:
i figured if it was weeping this much at idle oil pressure, i definitely didn't want to find out what it would do at 60-70psi trying to merge onto the highway at high RPM.
took it back off, checked over my work, and everything looked like it was supposed to. as far as i know its a legit OEM housing, and not a Chinese knockoff (purchased from McGeorge Toyota's online sales). The filter and o-rings were also OEM components bought from Toyotapartsdeal.com, so i feel like everything should have worked since they were factory parts.
i went back to the polymer unit with a fresh o-ring and it snugged up perfectly with no weeping at all. as far as i've been able to tell, i can't find any instance of the standard polymer housing failing in normal use while on a running engine. all the stories of breakage seem to be from installation error. i think i'll take my chances and just keep a second polymer housing around should the need ever arise.
'19 T4R TRD Off-Road | @go_scott_go
MidniteTRD is offline   Reply With QuoteReply With Quote
Old 08-03-2020, 11:45 AM #28
dipNrip dipNrip is offline
dipNrip is on a distinguished road
Smile
There should be some resistance so sounds like the oring isn’t in the right location. Could have installed in wrong location or slipped out of position.
I put a lot of oil on the oring and inside the housing on the engine. I also thread it on the housing till resistance then pull it out to check the oring. I’ll then put more oil to the oring and install. Probably don’t need to check it but I do.
dipNrip is offline   Reply With QuoteReply With Quote
Old 08-03-2020, 12:24 PM #29
Charlievee's Avatar
Charlievee Charlievee is offline
Charlievee is a name known to all Charlievee is a name known to all Charlievee is a name known to all Charlievee is a name known to all Charlievee is a name known to all Charlievee is a name known to all
Charlievee's Avatar
Find myself thinking if there's a conversion kit to use a normal oil filter? What's the logic behind the cartridge system, besides bean counting?
2018 TRD Off Road Premium. Eibach Pro, JBA, Toyo's, TRD cai.
Charlievee is offline   Reply With QuoteReply With Quote
Old 08-03-2020, 12:26 PM #30
08TxRunner's Avatar
08TxRunner 08TxRunner is offline
08TxRunner is a jewel in the rough 08TxRunner is a jewel in the rough 08TxRunner is a jewel in the rough
08TxRunner's Avatar
Can't say I've had that problem with the metal housing. It spins freely until I get to the o-ring, then there is resistance, then it seats. It almost sounds like you guys are experiencing an o-ring issue.
08TxRunner is offline   Reply With QuoteReply With Quote
housing , normal , plastic , tight , time
Plastic Oil filter housing replacement JLTD 5th gen T4Rs 25 10-18-2019 03:44 PM
Oil filter housing upgrade question JAXJeremy 5th gen T4Rs 33 09-30-2019 09:11 AM
Metal Flakes (gold color) in Oil Filter Housing Cap? Woz1976-MT 5th gen T4Rs 10 06-17-2017 03:53 PM
Metal oil filter housing flying fuzz 5th gen T4Rs 7 01-02-2015 08:10 PM
Metal indicator tab on plastic oil filter housing; toyslug 5th gen T4Rs 7 07-09-2012 11:00 AM
