Old 08-03-2020, 01:17 PM #31
MidniteTRD's Avatar
MidniteTRD MidniteTRD is offline
MidniteTRD will become famous soon enough
MidniteTRD's Avatar
Originally Posted by 08TxRunner View Post
Can't say I've had that problem with the metal housing. It spins freely until I get to the o-ring, then there is resistance, then it seats. It almost sounds like you guys are experiencing an o-ring issue.
my first thought was that i screwed up the o-ring installation, which is easy to do since there's a big gap between the end of the threads and the actual channel where the o-ring sits...so its easy at first glance to get it in the wrong place.
when i took it back off the o-ring was right where it should be. there appeared to be nothing wrong with the installation and i really checked over everything carefully because so many people had no issue with this so i was sure i had done something wrong.
Originally Posted by dipNrip View Post
There should be some resistance so sounds like the oring isn’t in the right location. Could have installed in wrong location or slipped out of position.
I put a lot of oil on the oring and inside the housing on the engine. I also thread it on the housing till resistance then pull it out to check the oring. I’ll then put more oil to the oring and install. Probably don’t need to check it but I do.
there was zero resistance when it was getting tightened down. the ring was in the right place so i wonder if it did manage to catch and shift out of position due to a lack of lube on the inside of the housing. what i don't understand is that the polymer housing had no issue seeing resistance and seating properly when i cleaned up the housing the exact same way. maybe it was a bum o-ring, but i feel like the odds of that are pretty low for an OEM product.
i may give it another shot on another oil change but its been a real PITA so far for a mod that the truck doesn't necessarily need, provided the stock unit isn't overtightened.
'19 T4R TRD Off-Road | @go_scott_go
MidniteTRD is offline   Reply With QuoteReply With Quote
Old 08-03-2020, 01:39 PM #32
08TxRunner's Avatar
08TxRunner 08TxRunner is offline
08TxRunner is a jewel in the rough 08TxRunner is a jewel in the rough 08TxRunner is a jewel in the rough
08TxRunner's Avatar
At this point then I'd replace that housing. That's definitely not right.
08TxRunner is offline   Reply With QuoteReply With Quote
Old 08-03-2020, 04:24 PM #33
Hans Moleman Hans Moleman is offline
Hans Moleman has a spectacular aura about Hans Moleman has a spectacular aura about Hans Moleman has a spectacular aura about
The Motivx oil filter socket sucks because it has loose tolerances around the flats and relies on the tabs which break.
I use this forged filter socket that has no slots for the ears and has close tolerances on the flats which will not slip.
Amazon.com: Tool Guy Republic Forged Chrome Vanadium Oil Filter Wrench Socket for Toyota, Lexus, Scion, Type Oil Filter Housings - 64mm 14 Flats: Automotive
After 2 'free' oil changes, my filter canister was stuck on pretty good. This filter socket had no troubles removing it and did not slip or mangle up the flats on the caniser.
2018 SR5 Premium MGM
TRD Pro wheels
LT265/70/17C BFG KO2
Hans Moleman is offline   Reply With QuoteReply With Quote
Old 08-03-2020, 05:10 PM #34
08TxRunner's Avatar
08TxRunner's Avatar
This is the one I bought and it's worked fine so far:
Amazon.com: TOYOTA Genuine Parts - Cap Assy, Oil Filter (15620-31060): Automotive
Old 09-18-2020, 06:30 PM #35
Banned
Real Name: Mark
ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future
Banned
Real Name: Mark
I ran into the same issue that you did. But I’ve reached a different conclusion. I’ve done three oil changes after installing the metal filter housing and have had no perceived leakage until this time.
Unlike the plastic housing that snugs up tightly to the engine, when you spin the metal one on until it stops, the rubber o-ring provides the tension to hold it in place as well as seal the oil. You don’t get a real good feeling of snugness with the torque wrench. This time when I started to remove the filter drain plug, which I previously torqued to the proper 10 ft-lbs, it wouldn’t break free but the whole housing turned. I could have held the housing in place with a large wrench while unscrewing the drain plug , but instead I performed the gallon-ziplock-bag-as-a-condom method to catch all the contained oil while unscrewing it by hand. The whole filter and housing was oiled up in the process.
Then I cleaned it up, put it in a vise, removed the drain plug, installed a new small o-ring, installed drain plug, new large o-ring, new filter element, oiled up the o-ring really well, and installed it. After wiping everything down I started the 4R and checked for leaks. After adjusting the oil level I went on a test ride and ran some errands. When I got back I checked the filter for leaks and saw an area of the filter was oily and seepage around the rim. I wiped it all clean and especially around the rim. After a few minutes it still seemed to continue to seep out a little so I kept cleaning it repeatedly for several more minutes. I found my old plastic housing and was going to replace the next day, but when I checked the next morning it wasn’t leaking any more. I took another test drive and checked it again. It stayed pretty clean, except if I ran a paper towel around the perimeter at the engine interface with a fingernail I would detect a little smear of oil. I left the skids off for a few more days and continued to check it this way each time after driving around. I can still detect a little smear of oil if I press in with a fingernail.
So, I believe the housing sealed properly but since I had a lot of oil on the threads it looked like a leak until it all gradually seeped out at the open end of the thread. And took several days to work it all out. Maybe that’s what happened in your case.
Next oil change:
-Hold housing steady with channel lock pliers, remove plug and drain.
-Oil the o-ring but clean all oil off filter threads and engine threads. before re-installing.
-Keep skids off for a day or two to verify for no leaks.
Old 09-20-2020, 11:34 PM #36
MidniteTRD's Avatar
MidniteTRD's Avatar
hey thanks for letting me know! at least now i know i'm not crazy. i definitely didn't clean off the inside of the housing so its possible some oil got on the threads and was just draining off of them like you described.
i'll give it another shot sometime and see if its just a matter of allowing the residual oil to seep out. i still don't like the design being like that, but it sounds like its not harmful, really.
Old 02-02-2021, 12:42 AM #37
Banned
Real Name: Mark
Banned
Real Name: Mark
I just changed my oil and filter, paying special attention to completely clean the threads of the filter housing and the threads on the engine side. I screwed on the metal filter housing by hand. It snugs right up solidly and takes no additional torqueing. After a day of driving and observing there was absolutely no leakage.
housing , normal , plastic , tight , time
Plastic Oil filter housing replacement JLTD 5th gen T4Rs 25 10-18-2019 03:44 PM
Oil filter housing upgrade question JAXJeremy 5th gen T4Rs 33 09-30-2019 09:11 AM
Metal Flakes (gold color) in Oil Filter Housing Cap? Woz1976-MT 5th gen T4Rs 10 06-17-2017 03:53 PM
Metal oil filter housing flying fuzz 5th gen T4Rs 7 01-02-2015 08:10 PM
Metal indicator tab on plastic oil filter housing; toyslug 5th gen T4Rs 7 07-09-2012 11:00 AM
