04-02-2020, 04:34 PM
![Nuke's Avatar](https://www.toyota-4runner.org/customavatars/avatar34664_1.gif) |
Replaced plastic filter housing with metal - question fir those that already did
The factory plastic oil housing was pretty tight nearly the entire time I was rotating it off. When i installed the metal one, it spun on easy until it couldn't go any farther. I think it snuggled up barely 1/8th of a turn, if that. It's certainly tight enough that it won't come off by hand. And, yes, I lubed and put the new o-ring on. I drove about 12 miles afterwards to let it heat up and it's not leaking but I'm a bit concerned about it loosening over time.
Anyone else have a similar experience? Normal? Not normal?
Rick
'90 T4R - sold at 205,000 miles
'00 T4R - sold at 152,000 miles
'08 Sport - 178,000 miles & still going strong
'19 ORP - just over 6,000 mi. (garage queen, like my '07 Mustang)
04-02-2020, 05:20 PM
![daytonaviolet's Avatar](https://www.toyota-4runner.org/customavatars/avatar1863_22.gif) |
did you swap the center shaft from the plastic housing over to the metal one? the shaft on the metal ones are too short.
https://www.youtube.com/watch?v=Nsql811cqIU
04-02-2020, 05:26 PM
I noticed the same when I swapped out the plastic housing for the aluminum housing. The plastic screwed on and off with considerable tension while the metal housing screwed on very easily and came to an abrupt stop when torqued to spec. No loosening or leaks in the 4,000 miles since installation.
04-02-2020, 05:36 PM
![delloro's Avatar](https://www.toyota-4runner.org/customavatars/avatar122831_1.gif) |
Same here, several oil changes since, no problems.
04-02-2020, 05:37 PM
![SnowYeti's Avatar](https://www.toyota-4runner.org/customavatars/avatar242265_1.gif) |
Just bought one, good to know. Thanks
Sounds like a win-win to me
2019 ORP, 6112/5160, Eibach load leveling springs #250, Cornfed 1/2 in front spacers, JBA UCA, RCI alum skids, TRD Pro skid, TRD Pro grill, TRD Pro valances, Baja S8 30”, 3x Baja LP4 and Baja fogs, Rays 10, Toyo AT3 185/55, Canvasback, tinted windows, clear mask, UpTop Alpha rack w/ custom fairing, Borla, AFE CAI, URD MAF, Switch Pros, Power Trays, single ARB, rod vault, iKamper X-Cover, 23Zero 270 awning, Baja scene lights, Baja S2 rear fog/camp lights, RSG KDSS skid and sliders, Coco Mats, Ellis shift knobs, C4 ladder, Kenwood DNX696S/iData link, Morimoto XB Gen2, Morimoto Tails, custom 80/20 platform with slider, RokBlokz XL, WeBoost, C4 Low Pro w/ high clearance, Warn VR10 with Factor55, etc
04-02-2020, 05:51 PM
Banned
Real Name: Mark
Banned
Real Name: Mark
That’s the way the aluminum housing snugs up. Just torque it properly. I always leave the skid plate off for a day to ensure there are no leaks. It’s always good
04-02-2020, 06:06 PM
04-02-2020, 06:18 PM
![LandCruiser's Avatar](https://www.toyota-4runner.org/customavatars/avatar92049_3.gif) |
Real Name: Sparky
Real Name: Sparky
Mine is 7 years old and has seen extreme cold and extreme heat in FL, AL, CO, WY, and CA. Idiots and capable people have changed the oil and the plastic filter housing has never been an issue over more than 12 oil changes so far. I question the need for this part.
Old and (c)rusty.
04-02-2020, 09:36 PM
Originally Posted by daytonaviolet
Yes, I did. Thank you.
Rick
04-02-2020, 09:39 PM
I was on the fence since I know of other vehicles with critical, pressure retaining parts made of plastic eventually popping the bed. I bit the bullet. The OE housing is stowed in the event it's needed later.
Rick
04-02-2020, 11:02 PM
![Gclark949's Avatar](https://www.toyota-4runner.org/customavatars/avatar135588_1.gif) |
I installed the metal one recently and it was rather loose feeling to me. And to concern me more is the metal one doesn’t have the little safety clip thing. I am considering going back to plastic on the next oil change as I feel it will be more reliable for harsh off road vibrations.
2016 Trail Edition Premium, Silver with KDSS, 2.5 King lift, T13 rear springs, FN Six Shooter with ST Maxx, BB Skids
04-02-2020, 11:08 PM
![nb rob's Avatar](https://www.toyota-4runner.org/customavatars/avatar122813_1.gif) |
I've had my aluminum one for 2 years. lots of 'harsh offroad vibrations'.
I tighten it by hand only, and usually require the filter wrench to remove it.
The design of the filter housing is to snug the side o-ring. Compression does not make the seal, rather the housing position relative to the properly-seated oring makes the seal.
_______________________
2015 trail edition premium w/ KDSS
OPOR sliders ● 255/75/17 firestone destination AT ●
King coilovers and shocks w/ compression adjust ● Dirtking UCAs ● Icon 2" rear springs
04-03-2020, 12:07 AM
![eelliiss's Avatar](https://www.toyota-4runner.org/customavatars/avatar144882_1.gif) |
Piggybacking off of this thread. Does anyone have difficulty removing the plastic drain extension from the aluminum housing? It's been tremendously difficult to insert and remove for me.
04-03-2020, 12:14 AM
![pDubs's Avatar](https://www.toyota-4runner.org/customavatars/avatar138974_1.gif) |
Bought my 4runner used from a dealer who had just changed the oil. 6k miles later I go to do the first oil change myself and the oil filter must have been torqued to 150 ft lbs. Breaker bar wasn’t budging it. Eventually I snapped the oil filter wrench on my 1/2” breaker bar, had to order another filter wrench. Take 2 resulted in finally breaking the housing loose but cracking it. That’s the only reason I went metal, was $25 on Amazon with 1 day shipping at the time and the truck was stuck in the garage.
OP I noticed same thing. Threading it in until the o ring starts making contact is easier to spin. Been 3+ years and ~40k miles later and zero issues.
2014 SR5P
5100s w/Dobinsons 302/505 springs - SCS F5s - 285/70 Wildpeak AT3W - Prinsu Full Length Rack - Smittybilt Gen 2 RTT - Full RCI skids - RSG sliders - Pedal Commander - Gobi ladder - Rago brackets and 32" LED light bar- TSO TRD Pro grille - 5k HIDs - ARB diff breather - other small stuff
04-03-2020, 12:57 AM
![Rondigs's Avatar](https://www.toyota-4runner.org/customavatars/avatar204868_1.gif) |
Real Name: Ronnie
Real Name: Ronnie
I had the same experience. After my last “free” oil change, I did my first oil change at home. I swear they put that housing on with an impact wrench. I broke one of the tabs off the plastic housing getting that thing off... Now I need to come up with a replacement.
