01-31-2021, 12:34 PM
Crushed exhaust pipe
While wheeling in CO, I made some poor line choices while taking my overloaded rig down engineer pass. I ended up with a nice dent in my exhaust pipe. I was going to try to weld a tab to it and pull it out, but im not excited to weld on the pipe (poor skill, potential weaking of metal, holes, future corrosion etc). Ive already ordered skids.
I got to looking at the pipe closer and saw that immediately downstream, the pipe goes from 61mm to 48mm diameter, then the pipe combines to the right side and all 6 cylinders are carried by the 61mm diameter pipe. I think that dent restricts 25% flow (very rough area calculation) but that 48mm pipe restricts 40%.
I think im going to leave it as the dented area is volumetrically larger than the smaller pipe before y junction. I have not seen any drivability issues. Let me know your thoughts. Im sure im way overthinking this, but these rigs are not cheap and i don't want to damage the engine.
01-31-2021, 12:58 PM
Real Name: Bob Wheeler Jr
The only thing I'd think about is that anytime you have airflow through a pipe system and there's a non-smooth or ridged surface you risk some kind of flow issue like a Bernoulli effect happening. It's possible that with the particulate nature of exhaust you'll get a swirling effect caused by the dent. That could cause backup. Just a guess, and probably not likely, but seems possible.
How much would it cost to just replace the pipe at the bolted area? Looks like that's a fairly easy replacement.
01-31-2021, 01:29 PM
Good thought on the swirling effect. Honestly i didn't check on repair from exhaust guy. Im reluctant with a cut and replace job because ive seen aftermarket materials be inferior in long run. Ive replaced exhaust pipe on cars just to see it rust at alarming rate compared to oem. Maybe in long run, ill get some super sweet upgrade system!
01-31-2021, 03:07 PM
Originally Posted by patkelly4370
I agree I’d have it fixed
2020 4Runner SR5 Premium 4x4
Barcelona Red, Graphite/Grey
Sunroof
01-31-2021, 03:12 PM
Real Name: Luke
Real Name: Luke
Not sure about pulling that dent out, but there is a lone aftermarket Y-pipe out there from URD that addresses the flow issue. (Fixed Link for 2010+)
01-31-2021, 04:03 PM
Personally, I'd drive it and watch for any changes. If MPG stays the same, that's probably a good indicator that all is well. Plus, the pipe likely widened at least a little in response to the upward blow. Inspect it periodically. If you do observe any problems, you can get it fixed at that time.
I did a very similar thing to a car many years ago, and never did fix it, and didn't have any noticeable problems, either.
01-31-2021, 04:10 PM
And then add a full suite of skids.
On many trails, hitting/sliding there is simply unavoidable as the breakover angle is what it is.
Rerouting is also a great idea.
01-31-2021, 04:45 PM
Agreed. Also, note that the tubes in and out of the catalytic converters are smaller than this tube. This tube also conveys only half the exhaust, the left cylinder bank.
You might consider a modest lift/leveling kit. Spacers are economical and can raise the front up to 3" which will help in future situations. As others have suggest, a full skid plate, such as those from CBI or RCI could be used.
01-31-2021, 05:46 PM
What dent? Seen worse. Replace if you get an exhaust leak.
Drive on.
Between outfits.
01-31-2021, 06:43 PM
Originally Posted by Friggin Idiot
Not sure about pulling that dent out, but there is a lone aftermarket Y-pipe out there from URD that addresses the flow issue. It says for '03-09, but fits up to current model too.
I thought those Y-pipes aren't compliant. Especially for those who live in states with strict smog/registration compliance laws.
2017 T4R OR Super White
RRW RR4-V bronze wheels, Diode Dynamics SS3 Fog + Ditch, C4 Fab Lo Pro Winch Bumper + Smittybilt 10k synthetic, UpTop Overland Bravo Roof Rack
Dobinson's full suspension 2.5" front 1.5" rear - Dobinson's UCA - DirtKing LCA
Kenwood eXcelon 10.1 headunit + Kenwood speakers
01-31-2021, 07:06 PM
They're certainly not compliant with wallets.
Holy hell.
Dent doesn't look horrible. Sound change? MPG change? If yes, then get it fixed.
Current - 2017 TRD ORP. Nautical Blue
Previous - "TRex" - 2004 Sport Edition V8. 2000 SR5 Sport
01-31-2021, 08:38 PM
Y-pipe
Oceanside , Cali ? Have visual inspection ? Nv does not so why I'm running both my 4r 11'& 14' delete to cats & will not throw code ! Otherwise have muffler shop fabricate a y-pipe or cut that piece out ! Besides heat shields this a bad spot anyhow because it hangs below the transfer case bracket , my 2 cents !
2011 SR5 Mgm 4x4 alpharex pro headlights & depo black tail lights level 8 trackers wheels & p285/70/17 cooper at3s, 6112s all around set 2.5 rear rancho spacer 11/4, FJ coils TRD intake.w/afe-dry filter Urd y-pipe flowmaster super70ii TE roofrails! 2014 Sr5 Superwhite Bils 6112s/eibach 2.5 /1 "rear springs 285s Cooper at3 ms on fj pc-d satin black, Urd y-pipe/Flow delta 50 muffler/all interior led lights & low beams sealights h7 led with laminx yellow fogs & oldreds puddle harness w/2010-13 mirrors
01-31-2021, 09:02 PM
02-01-2021, 08:00 AM
Real Name: Luke
Real Name: Luke
These remove the downstream cat, hence not legal for communist states unless you have the shop weld another cat in. It's also why they're considered an "off-road" y-pipe.
