Old 04-04-2020, 08:07 PM #1
Keith M Keith M is offline
Keith M is on a distinguished road
285/70r/17 + Eibach Pro truck @ 1.6 + Tire size info
First off, many, many thanks to @nimby for the time he took to write the review on the Firestone A/T on the other 4Runner forum. The tire and lift combo was exactly what I was looking for so I followed his advice. I am very pleased with the outcome. After a little road time I have found a little rubbing on the fender liner when in reverse at full turn so I'll be doing the fender liner mod in due time. Not even close to a BMC
I have also attached a document I created when researching tires that I was interested in. No heavy mudders will be found here. I was looking for a more conservative tread with good road manners. My heavy off roading days are over.
Hope this helps some of you on the fence. Cheers!
Stats:
Eibach Pro Truck with P285/70r17 Firestone Destination A/T2 tires. Stock TRD/OR wheels
Front
Shocks set to 1.6
36 1/2" ground to bottom edge of fender. +1 7/8" Above stock (Stock was 34 5/8")
Rear
2 OME 10mm spacers, stock coils, stock shocks (Eibach PT delayed in shipping)
38" ground to bottom edge of fender. +1 1/4" Above stock (Stock was 36 3/4")
1 1/2" rake
Caster is set to 2.8L, 2.9R.
285/70r/17 + Eibach Pro truck @ 1.6 + Tire size info-1-img_5296-jpg  285/70r/17 + Eibach Pro truck @ 1.6 + Tire size info-2-img_5291-jpg  285/70r/17 + Eibach Pro truck @ 1.6 + Tire size info-3-img_5294-jpg  285/70r/17 + Eibach Pro truck @ 1.6 + Tire size info-4-img_5295-jpg
30 years of 4runner ownership and counting. #1 1987-2001, 220k, #2 2001-2017, 215k, #3 2017 Off Road 50k, #4 2020 ORP. I'm done.
Keith M is offline   Reply With QuoteReply With Quote
Old 04-04-2020, 11:29 PM #2
2chains 2chains is offline
2chains will become famous soon enough
Looks great on the Classic Silver!
Sold 2015 Canadian TE Magnetic Grey-Toytec BOSS, 285 70 17 Duratracs, Blue Sea fuse block, Gobi Stealth, Morimoto LED fogs, FN Pro(x) Wheels
Sold 1996 4runner Limited Natural White w/ Silver Cloud trim. 265 75 16
2013 Limited Blizzard Pear 3rd rowl - 2.5" Elka 2.0 Coils 650# Springs/0-2" Elka REAR /Dobinson C59-325 Rear Coils/Greenlane Diff Drop/ SPC UCA's
2chains is offline   Reply With QuoteReply With Quote
Old 04-06-2020, 01:06 PM #3
nimby's Avatar
nimby nimby is offline
nimby is a jewel in the rough nimby is a jewel in the rough nimby is a jewel in the rough
nimby's Avatar
Glad to hear it worked out for you Keith and that you're happy with the set-up!
Do the fender liner mod and get your alignment shop to get the caster as close to 4 degrees as they can get it.
It'll ride even better!
Your truck looks awesome!
nimby is offline   Reply With QuoteReply With Quote
Old 04-06-2020, 05:56 PM #4
Akkording's Avatar
Akkording Akkording is offline
Akkording is just really nice Akkording is just really nice Akkording is just really nice Akkording is just really nice
Akkording's Avatar
Looks great! Destination AT2 do run a tad taller than most 285 I've had, they are wonderful tires on road and light off road. When things settle you might have some more rubbing.
2011 Starfire Pearl GX460 stock base ;)
2012 Blizzard Pearl SR5 | 285 Toyo OC AT3 | Level 8 Slam | YotaWerx ActiveDuty | Die Hard AGM w/ArcLightLeds V2 Booster | Borla 40665 | URD Y & MAF Cal TRD | C4 Center LP | Maxbore 2mm TB "loaner from my boy Dave" | X20 10k Factor55 | Shrockworks Armory | RCI LCA skids | TC Gusset | LFD Offroad 7/8 | TJM Airtec dry aFe HPS coupler w/TRD CAI tube | B8 6112 | 650# King | ICON Delta Joint | Fox 2.0 VS| SAW 1.5" |230k|
| 03 DCSB Tacoma OME equipped, +320k Still Truckin |
Akkording is offline   Reply With QuoteReply With Quote
Old 04-06-2020, 07:12 PM #5
LandCruiser's Avatar
LandCruiser LandCruiser is offline
Real Name: Sparky
LandCruiser has much to be proud of LandCruiser has much to be proud of LandCruiser has much to be proud of LandCruiser has much to be proud of LandCruiser has much to be proud of LandCruiser has much to be proud of LandCruiser has much to be proud of LandCruiser has much to be proud of LandCruiser has much to be proud of LandCruiser has much to be proud of
Real Name: Sparky
That will rub at full turn if you stuff that tire. Guaranteed.
Old and (c)rusty.
LandCruiser is offline   Reply With QuoteReply With Quote
Old 04-06-2020, 11:58 PM #6
Thebeastlives Thebeastlives is offline
Thebeastlives has a spectacular aura about Thebeastlives has a spectacular aura about
How you went offroading with that setup?
Thebeastlives is offline   Reply With QuoteReply With Quote
Old 04-07-2020, 06:56 AM #7
Drobs Drobs is offline
Drobs is a glorious beacon of light Drobs is a glorious beacon of light Drobs is a glorious beacon of light Drobs is a glorious beacon of light Drobs is a glorious beacon of light Drobs is a glorious beacon of light
Looks good.
I like your spreadsheet. I'm going to have to put something similar together.
My next tire change, 30k to 40k from now, I plan go to 255/80R17 which is a 33.1 inch tire for Falken weighing in at 52lbs.
https://www.falkentire.com/tires/lig...peaka/t3w-tire
2019 OR - LT285/70R17 Yokohama Geolandar MT, SPC UCA's, BMC, Eibach Pro Truck Lift, Warn VR10 Winch, Warn 100022 Winch Bumper, TRD Skid Plate, Cali Raised Light Bar, Shrockworks Sliders and Skids, LFD Ruggadized Cross Bars, Sprint Booster.
Drobs is offline   Reply With QuoteReply With Quote
Old 04-07-2020, 07:10 AM #8
What off-roading I do anymore is in the low country of Florida and Georgia. My 1st gen and 3rd gen saw time in the mountains.
I'm older now. After 30+ years of owning 4runners they have changed along with me so this vehicle works with my lifestyle today. So for now, I'm okay with not having the capabilities that another 1" of lift and aftermarket UCA's would get me.
Originally Posted by Drobs View Post
Looks good.
Thank you sir. It helped sway my decision. My short list was the General APT, Yoko Geo G015 and the Firestone. All within the same weight range.
K
My 2017 below with Billsteins @ .85 front/0 rear. OEM 265's.
285/70r/17 + Eibach Pro truck @ 1.6 + Tire size info-1-img_3292-jpg
Old 04-07-2020, 12:52 PM #9
EDC4rnr EDC4rnr is offline
EDC4rnr is on a distinguished road
Thanks for the spreadsheet Keith. Wish I had it when researching tires because I probably would have gone with firestone at2 as well. They look to be the lightest 285? Please keep us posted on how they work out for you.
EDC4rnr is offline   Reply With QuoteReply With Quote
Old 04-07-2020, 07:08 PM #10
K
T4R looks awesome! Which of the Eibach kits did you order? Is it the new adjustable coilovers?
PRO-TRUCK LIFT SYSTEM (Stage 1) - TOYOTA 4Runner Base
Old 04-07-2020, 07:52 PM #11
Thank you sir. Front and rear Pro Truck Sport shocks only. Looks like they are currently on sale. Stock coils front and rear.
Old 04-07-2020, 08:49 PM #12
adrummingdude's Avatar
adrummingdude adrummingdude is offline
adrummingdude will become famous soon enough
Man, that looks close. Starting to rethink going 285s and instead do 275s.
2020 TRD PRO - Morimoto 2 stroke LED's - KC flex pillar pods - Rigid rack pods - Goal Zero 100w panel/ Yeti 200X - Rago MOLLE panels and shelf - Thule cargo box - Gobi Ladder - Rotopax
adrummingdude is offline   Reply With QuoteReply With Quote
Old 04-08-2020, 04:28 PM #13
That's where I was too which is why I made the spreadsheet so I could compare sizes. I really didn't want to go with an E rated tire. The only one that was close to Std load was the Kuhmo (6 ply C rated) which was also 12lbs/tire heavier and offered no mileage warranty. I kept coming back to the Firestones.
Liner is pushed forward and did a little more trimming today with a rasp and some 320 sandpaper to smooth it out.
285/70r/17 + Eibach Pro truck @ 1.6 + Tire size info-1-img_5309-jpg  285/70r/17 + Eibach Pro truck @ 1.6 + Tire size info-3-img_5313-jpg
eibach , fender , set , stock , time
Eibach Pro-Truck Lift Tire Size gimlithepirate 4th Gen T4Rs 3 03-28-2020 02:09 PM
Gas mileage (calculated) + tire size/type + gearing info - what are you getting? IrieRider 5th gen T4Rs 19 10-07-2019 03:59 PM
All terrain tire recommendation for full size truck ddnww Off Topic 15 02-03-2018 12:42 PM
Conflict with stock tire size info. Atomic_Dog Classic T4Rs 6 02-13-2012 09:31 PM
Conflicting tire size info on my 4runner.. Help! jrm27 3rd gen T4Rs 3 11-18-2010 01:25 PM
