Old 04-06-2020, 10:15 AM #1
upperleftguy's Avatar
upperleftguy upperleftguy is offline
upperleftguy is on a distinguished road
Tire ‘bump’
Hey T4R!
Yesterday I noticed while pulling out of my driveway that I feel a bump every tire rotation. This is going slow - 5-10 mph and gets harder to feel as the MPH increase. I’m not sure how to explain it other than as a kid if you didn’t even space out the new tube in your bike and when you pump it up you feel that bump every time your bike tire gets to that bulge or spot in the tire.
Tires: 275/70/17 K02’s at 35 psi. Tires are new - they don’t even have 500 miles on them.
I can’t see any visible bulges anywhere and the lugs are tight
Thanks!
upperleftguy is offline   Reply With QuoteReply With Quote
Old 04-06-2020, 11:03 AM #2
nevada's Avatar
nevada nevada is offline
nevada has a spectacular aura about nevada has a spectacular aura about nevada has a spectacular aura about
nevada's Avatar
Originally Posted by upperleftguy View Post
Hey T4R!
Thanks!
that sounds like a separated tire. you feel the bump, but does the steering wheel rock side to side also? if not, that would tell us its a rear tire.
run your hands across the tread. like petting a dog. flat hand. you will probably be able to feel it. after checking all the tread you can reach, roll the rig forward a few feet, so you can get to the section that was on the ground.
1985 pickup: EFI 331/4r70W-Dana 300-42 TSL SXII's/raceline beadlocks-30spl longs-5.29's-spools-sky Hi steer-OBA/4g tank-10.5k RR winch-dual blue tops-200 amp alt-flatbed.
1985 4runner sr5: 22RE/5spd-6" pro-comp suspension-37 BFG at's-5.29 gears-Badlands Basher bumper-8.5k RR winch.
2006 4runner v8 limited: stock. Build Thread YouTube Channel
nevada is offline   Reply With QuoteReply With Quote
Old 04-06-2020, 11:06 AM #3
I do not feel it in the steering wheel. I will try that and let you know!
Old 04-06-2020, 11:36 AM #4
Rack Rack is offline
Rack has a spectacular aura about Rack has a spectacular aura about
Years ago I had a similar issue, it turned out to be a wheel weight inside the tire.
I had just had a tire repair by the" Tire Guy at Sears". At low speed it flops around but at higher speed the centrifugal force held it to the wall of the tire.
You should feel a slight vibration in the steering wheel if its a front tire . not so much if its a rear.
Take it to the tire shop and have them put the truck on a rack and spin each tire slowly to listen for a thump.
signature not available
Rack is offline   Reply With QuoteReply With Quote
Old 04-06-2020, 11:42 AM #5
LandCruiser's Avatar
LandCruiser LandCruiser is offline
Real Name: Sparky
LandCruiser has much to be proud of LandCruiser has much to be proud of LandCruiser has much to be proud of LandCruiser has much to be proud of LandCruiser has much to be proud of LandCruiser has much to be proud of LandCruiser has much to be proud of LandCruiser has much to be proud of LandCruiser has much to be proud of LandCruiser has much to be proud of
Real Name: Sparky
Separated tire when brand new would be a very weird and rare issue unless he did something Dukes of Hazzard with it?
Old and (c)rusty.
LandCruiser is offline   Reply With QuoteReply With Quote
Old 04-06-2020, 12:27 PM #6
nevada's Avatar
nevada's Avatar
I agree. especially with BFG's. but, when I worked tires, I saw brand new tires separated after the first mounting. in fact we would spot them on the balancer.
bike , feel , mph , tire , tires
Energy Suspension 8.9104R rear bump stops in place of front bump stops Akkording 5th gen T4Rs 66 01-16-2024 12:10 AM
All I did was go over a bump !!!! Drama1 5th gen T4Rs 5 03-22-2020 01:30 PM
'Bump' at a stop? iLLWiLL General Discussions 11 04-12-2009 12:34 AM
&*#$(&(@!!! Bump Bump! 4Runner1371 4th Gen T4Rs 3 12-16-2007 03:26 PM
Bump? nauticalniremor Off Topic 2 08-12-2006 11:20 PM
