Old 04-06-2020, 09:16 PM #1
DrewPeakoc's Avatar
DrewPeakoc DrewPeakoc is offline
DrewPeakoc is on a distinguished road
DrewPeakoc's Avatar
'20 headlight wiring diagram
I'm replacing my headlight assembly with an aftermarket assembly and can't find a Chilton or Haynes manual anywhere. I did find some rebuild diagrams, but they're all the way back at the fuse box and I don't want to undo the entire bundle to trace the wire.
Can anyone help me identify the wires closer to the bulbs?
DrewPeakoc is offline   Reply With QuoteReply With Quote
Old 04-06-2020, 10:28 PM #2
EddieV4runnin's Avatar
EddieV4runnin EddieV4runnin is offline
EddieV4runnin is a jewel in the rough EddieV4runnin is a jewel in the rough EddieV4runnin is a jewel in the rough EddieV4runnin is a jewel in the rough
What’s the difference between those headlamps and the OEM units?? The connectors should plug right into the after market ones. Unless you have a set that have a sequential turn signal feature.
Mods are loading.......
EddieV4runnin is offline   Reply With QuoteReply With Quote
Old 04-07-2020, 12:28 AM #3
flyrv9's Avatar
flyrv9 flyrv9 is offline
flyrv9's Avatar
You should be able to figure it out with a meter. It would be a good idea to anyway; and then check that your new assembly matches before applying power.
Old 04-07-2020, 06:49 AM #4
DrewPeakoc's Avatar
DrewPeakoc's Avatar
That's exactly what it is.
Old 04-07-2020, 06:51 AM #5
DrewPeakoc's Avatar
DrewPeakoc's Avatar
I could meter it, yeah, but I'm checking if anyone has a wiring diagram because it's easier and straightforward.
assembly , back , find , headlight , undo
97 4Runner ECU/ECM wiring diagram/PIN diagram Dawgz 3rd gen T4Rs 5 02-20-2023 03:04 PM
JBL Amp Wiring Diagram Helix26404 5th gen T4Rs 16 10-08-2022 11:10 PM
wiring diagram Lucky4R Classic T4Rs 0 08-03-2015 10:31 PM
Anyone got the diagram for connector G18 (electric wiring diagram) jicko 5th gen T4Rs 0 04-03-2015 10:01 PM
Wiring Diagram chiraz111 Engines / Suspension / Wheels / Tires / Audio / Accessories 0 05-27-2006 05:46 PM
