Old 04-13-2020, 04:09 AM #1
AlblineStar808 AlblineStar808 is offline
AlblineStar808 is on a distinguished road
3" rear spring options?
other than the icon overlands are there any other options for a larger spring in the rear other than metal techs long travel ones? I already icon 2.5s in the rear and they aren't long travel shocks so I have to stick with non long travel now......looking for the most comfortable rear spring, I don't normally have a lot of weight in the rear so im thinking the overland would be too stiff for my taste
AlblineStar808 is offline   Reply With QuoteReply With Quote
Old 04-13-2020, 04:58 AM #2
JSparky's Avatar
JSparky JSparky is offline
JSparky is a jewel in the rough JSparky is a jewel in the rough JSparky is a jewel in the rough
JSparky's Avatar
AllPro used to make 3.5" rear lift coils for 4runner's/FJ Cruisers. Taller and 15% increase in spring rate over stock. I ran them for awhile and they are nice, but ended up up-rating since I have a rear bumper/carrier. I may have still have them in the garage if you're interested, I can't remember if I ever sold them. Otherwise I'm sure there's some pairs floating around. You could also throw some cheap poly spacers in on top of your existing springs.
Keep in mind, the shocks are typically the articulation limiter on these vehicles, so a running a progressive/dual rate/long travel coil with standard length shocks wouldn't be the end of the world, the coils are just a pain to install because you have to pull more stuff off to get them in (axle has to droop lower).
67' Land Rover 109, 97' FZJ80, 16' 4Runner Limited
http://www.toyota-4runner.org/5th-ge...-jr-build.html
http://www.overlandcookery.com
http://www.schaubphoto.com
JSparky is offline   Reply With QuoteReply With Quote
Old 04-13-2020, 07:08 AM #3
Sundy Sundy is offline
Sundy has a spectacular aura about Sundy has a spectacular aura about Sundy has a spectacular aura about
Dobinsons makes multiple 3" rear springs you'd have to confirm with CrikeyMike if you can run without extended travel shocks.
The spring I was thinking of is the C59-675V - Variable rate comfort option, stock rear weight, 3" lift.
HTML Code:
www.toyota-4runner.org/5th-gen-t4rs/231576-dobinsons-5th-gen-t4r-suspension-options-lots-choices
Sundy is offline   Reply With QuoteReply With Quote
Old 04-13-2020, 01:54 PM #4
Crikeymike's Avatar
Crikeymike Crikeymike is offline
Crikeymike has much to be proud of Crikeymike has much to be proud of Crikeymike has much to be proud of Crikeymike has much to be proud of Crikeymike has much to be proud of Crikeymike has much to be proud of Crikeymike has much to be proud of Crikeymike has much to be proud of
Crikeymike's Avatar
HTML Code:
Thanks for posting the link.
Yeah, we have 4 different rear 3" lift coils to suit different weights.
Exit Offroad - Specialist in Dobinsons Suspension & Accessories
Dobinsons | RCI | Powerbrake | Long Range Tanks | Timbren | Overland Vehicle Systems
Youtube Channel | Email Directly
Been in the offroad industry since 1998. Born & raised in Australia - currently in Jax Beach, FL. 2014 4runner Trail, 3/2" Dobinsons MRA Suspension, Shrockworks bumper and sliders, M8000 w/ Treaty Oak winch line, LFD Roof Rails, Dobinsons 2m Awning, RCI skids
Crikeymike is offline   Reply With QuoteReply With Quote
Old 04-13-2020, 01:55 PM #5
Crikeymike's Avatar
Crikeymike's Avatar
Here's the thread for the 4 rear 3" lift options.
Dobinsons rear long travel variable rate flexi coils
Old 04-14-2020, 11:56 AM #6
TotalAutomotiveLV TotalAutomotiveLV is offline
TotalAutomotiveLV has a spectacular aura about TotalAutomotiveLV has a spectacular aura about TotalAutomotiveLV has a spectacular aura about
Dobinsons and OME are definitely the most popular 3" rear coil options.
Check out the Dobinsons link above to find the right fit for your build.
_
TotalAutomotiveLV is offline   Reply With QuoteReply With Quote
Old 04-14-2020, 05:17 PM #7
dade73 dade73 is offline
dade73 will become famous soon enough
I recently put a Dobinsons 3" lift on my truck with long travel in the rear.
They have various height and weight options.
3" rear spring options?-20200402_084250-jpg
Humankind cannot gain anything without first giving something in return. To obtain, something of equal value must be lost.
dade73 is offline   Reply With QuoteReply With Quote
Old 04-15-2020, 03:49 AM #8
thanks for the responses guys, im looking into Dobinsons now. I was also told my icons rear 2.5 all though isn't the long travel ones can still accomadate a long travel rear setup....tryn to decide which way to go now
icon , long , rear , spring , travel
Spring options for the rear TheBFA Classic T4Rs 0 03-24-2019 03:24 PM
Rear Spring Options tenguns 4th Gen T4Rs 7 05-15-2017 04:07 PM
SAS 3rd gen rear spring options and PSC options. manesfesto Engines / Suspension / Wheels / Tires / Audio / Accessories 4 08-29-2016 12:13 PM
Bumpin Front Billies to 2.5. Best Rear spring options Az4runnin 4th Gen T4Rs 17 07-13-2016 11:54 AM
Tall & heavy Rear Spring options (4th gen) RaceTRaCk 4th Gen T4Rs 12 01-29-2016 11:47 PM
